ANT-433MR
ANT-433MR
    LPRS
ANT-433MR 数据手册
Low Power Radio Solutions Data Sheet Flexible Whip Antenna 433MHz Flexible Whip Antenna ANT-433MS ANT-433MR Product Overview Whip antennas are for portable and fixed applications requiring omni-directional communications. A single-element antenna that can be used with an unbalanced feed line such as coaxial cable, or attached directly to a wireless transmitter, receiver, or transceiver. SMA straight or right-angled Male connector. Low cost antenna. Nominal impedance: 50 Ω. Maximum input power:50W. Gain: 3dBi. VSWR: ≤1.5. Connector: SMA straight ot right-angled Male. Dimensions: 130mm x 9mm (MS), 130mm x 17mm (MR). Weight: 7g (MS) 9g (MR). Applications Omni-directional radiation pattern. Frequency range: 433-470MHz. Mechanical Specifications Vertical polarisation. Electrical Specifications Features Product Specifications This antenna is suitable for portable & fixed applications that require omni-directional communication. Ambient temperature: -40ºC to 60ºC. Version 1.3 - ANT-433MS ANT-433MR T: +44 (0) 1993 709418 | W: www.lprs.co.uk | E: sales@lprs.co.uk info@lprs.co.uk Low Power Radio Solutions | Two Rivers Industrial Estate | Station Lane | Witney | OX28 4BH | UK 1 Low Power Radio Solutions Antenna Propogation Product Order Code Name Description Order Code Flexible Whip Antenna 433MHz Flexible Whip Antenna, Straight / Right-Angled. ANT-433MS ANT-433MR Acccessories Description Order Code PCB Mount SMA Connector SMACONNECTOR Right Angled PCB Mount SMA Connector SMARACONNECTOR SMA Bulkhead Jack SMAENDBLKHD-JK UFL to SMA Female Jack 100mm ARW-CAB-SMA-UFL-10 Copyright See www.LPRS.co.uk for copyright statement. Discalimer See www.LPRS.co.uk for disclaimer statement. Terms & Conditions of Use See www.LPRS.co.uk for Terms and Conditions of Use statement. Contact Information For further information please visit www.lprs.co.uk or call +44 (0) 1993 709418. Version 1.3 - ANT-433MS ANT-433MR T: +44 (0) 1993 709418 | W: www.lprs.co.uk | E: sales@lprs.co.uk info@lprs.co.uk Low Power Radio Solutions | Two Rivers Industrial Estate | Station Lane | Witney | OX28 4BH | UK 2
ANT-433MR 价格&库存
很抱歉,暂时无法提供与“ANT-433MR”相匹配的价格&库存,您可以联系我们找货
ANT-433MR
    • 1+40.39528
    • 2+40.11410
    • 5+38.80196
    • 10+38.01051
    • 20+37.26071
    库存:153
