ER900TRS
ER900TRS
    LPRS
ER900TRS 数据手册
LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Low Power Radio Solutions Ltd “ERx00-02 Series Data Sheet (Rev 2.3).pdf” Modules Included: • ER400TS-02 • ER400RS-02 • ER400TRS-02 • ER900TS-02 • ER900RS-02 • ER900TRS-02 ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 1 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Contents Contents ..............................................................................................................................2 Disclaimer ............................................................................................................................2 Introduction to easyRadio ....................................................................................................4 New ‘02’ Added Features .................................................................................................5 ERx00TS-02 Transmitter .....................................................................................................6 Pin Description .................................................................................................................6 ERx00RS Receiver ..............................................................................................................7 Pin Out .............................................................................................................................7 Pin Description .................................................................................................................8 Application & Operation ERx00TS-02 & RS-02 ...................................................................9 ERx00TRS-02 Transceiver Description .............................................................................10 Pin Description ...............................................................................................................11 Application & Operation ERx00TRS-02 .............................................................................12 Absolute Maximum Ratings ERx00TS-02, ERx00RS-02 and ERx00TRS-02 ....................13 Easy-Radio Configuration Command Set ..........................................................................16 Notes: ................................................................................................................................19 RSSI Output ...................................................................................................................19 Application Notes ...........................................................................................................19 Compatibility...................................................................................................................19 PCB Layout ....................................................................................................................20 Power Supply .................................................................................................................20 Antennas ........................................................................................................................20 Technical Characteristics...................................................................................................21 easyRadio errata notes:.....................................................................................................22 ISSUE1 ..........................................................................................................................22 ISSUE2 ..........................................................................................................................22 ISSUE 3 .........................................................................................................................23 Product Order Codes .........................................................................................................25 Easy-Radio Module Firmware Version...............................................................................25 Document History ..............................................................................................................25 Copyright ...........................................................................................................................25 Certificates of Conformance to EN300-220 Part3..............................................................26 ER400TS-02 and ER900TS-02...................................................................................27 ER400RS-02 and ER900RS-02 ..................................................................................28 ER400TRS-02 and ER900TRS-02..............................................................................29 Disclaimer ..........................................................................................................................30 CONTACT INFORMATION ...............................................................................................30 Disclaimer Low Power Radio Solutions Ltd has an on going policy to improve the performance and reliability of their products; we therefore reserve the right to make changes without notice. The information contained in this data sheet is believed to be accurate however we do not assume any responsibility for errors or any liability arising from the application or use of any product or circuit described herein. This data sheet neither states nor implies warranty of any kind, including fitness for any particular application. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 2 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver EasyRadio modules are a component part of an end system product and should be treated as such. Testing to fitness is the sole responsibility of the manufacturer of the device into which easyRadio products are fitted, as is also the deployment into the field. Any liability from defect or malfunction is limited to the replacement of product ONLY, and does not include labour or other incurred corrective expenses. Using or continuing to use these devices hereby binds the user to these terms. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 3 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Introduction to easyRadio The easyRadio (ER) ERx00TS Transmitter, ERx00RS Receiver and ERx00TRS transceiver incorporate ‘easyRadio’ technology to provide high performance, simple to use radio devices that can transfer data over a range of up to 250 metres Line Of Sight (LOS). Furthermore ‘Easy-Radio’ technology allows frequency, data rate and power output to be optimised for customer specific applications. The embedded software reduces design and development time significantly. ER modules are available in two frequency versions: ER400 series (433-434MHz) & ER900 series (869.85MHz & 902-928MHz). For purposes in this document they will be referred to as ERx00. 2nd Generation Modules (please READ) This Data Sheet covers the new hardware/firmware revisions of the Easy Radio TS, RS & TRS modules. Their Part numbers are the same as before with the addition of “-02” (eg. ER400TRS-02). The “02” modules address issues that have been identified in previous hardware. The primary objectives for its development was to solve two main issues: • Unintentional Loss of user configured settings: o The previously used micro-controller (µC) was susceptible to EEPROM corruption when a ‘brown-out’ condition occurred. Particularly when power cycling the module. This had the effect of triggering the automatic Reset to Default behaviour of the module. • Frequency Stability: o Previous data sheets clearly show a frequency tolerance of +-50ppm. Despite operating within this specification, over some batches of product this has caused some unreliable communication to occur, as frequencies have been too far away from each other. If you are having issues in this area, please contact us. • Back Compatibility: o New Modules can be set to be compatible with any frequency variations in the past. Please contact technical for details or consult evaluation software help file. What improvements are there in ‘02’? 1. The µC has now been changed to one which also has a low-voltage brown-out-detect (BOD) circuit built in. Extensive testing has been done on this, and therefore power cycling techniques to conserve power are now easily achieved without the loss of programmed settings. The new µC also benefits from greater ROM size and peripheral features which means more functionality is being packed into the Easy Radio Modules. 2. The Crystal that controls the RF is now as low as +-10ppm, which guarantees consistent frequency stability over batches and over an extended temperature range of –40°C to +85°C. Of course some specifications have been effected to allow these hardware changes, but we feel it has been a necessary move to improve the product. LPRS are committed to the continued development and enhancement of Easy Radio and enhancements may be made without prior notice. A list of development hardware and software known issues and changes are listed at the end of this document. Please always make sure you are reading the latest document for update information. This data sheet describes the electrical and physical characteristics of the device. Operation of the Easy Radio software and Timing Specifications are described later in this document. Further information is available in the ‘Easy-Radio Demonstration Kit & Programming Software’ guide, which should be read in conjunction with this data sheet. General Features Applications Crystal controlled synthesiser for frequency accuracy High sensitivity receiver – typically –103dBm @ 19.2 Kbps Up to 10mW Transmit Power (at 434MHz) Low operating Voltage – 2.5-5.5 Volts – Single Lithium Cell Low power consumption: Receiver - 21mA Transmitter - 25mA Sleep – 120µA (V2.01.6 + later) User programmable: Frequency of operation Data Rate Output Power Handheld Terminals Environmental Sense & Control Vehicle to Base Station Data Transfer Remote Data Acquisition Electronic Point of Sale equipment Etc ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 4 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver New ‘02’ Added Features • • • • • • • • • • User Customisable RS232 BAUD rate o Literally add any required BAUD rate in the new Easy Radio Evaluation Software and select your new BAUD using the new ER_CMD#U0 command. * RS232 Parity ** o Odd/even parity is supported** FAST ACK feature o Reduce the time to issue ‘ER’ commands, using the HEX06 ASCII ACK character. Default Power Settings o Set your own power defaults for each channel using lowercase ‘p’ command. Customisable Data ID ** o Set a 16-bit ID to prevent communication with other Easy Radio Users. Programmable Encryption ** o Secure your data with a user defined 16-bit seed. User programmable frequencies o Change the channel frequencies to personalised settings. (Via PC Software) DCS (Digital Channel Selection) o Prevent crosstalk between adjacent channels Repeater Mode ** o Extend transmission range 16-bit CRC ** o Increased error checking * Note some BAUD rates may require two stop bits. (See Evaluation Software for details on specific BAUD) ** Available on firmware versions 2.01.6 and above ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 5 of 30 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver LPRS Data Sheet ERx00TS-02 Transmitter Antenna (2) Regulator Vcc (3) Micro Processor TXD (5) RF Transmitter Gnd (4) RF Gnd (1) Figure 1 Block Diagram 4 mm 31.0mm Top View (Transmitter) 12 mm 20.32mm 1 2 3 4 5 Pin Pitch 2.54 mm PCB Hole Size 1.0 mm Figure 2 Physical Dimensions Pin Description Pin No Name Description Notes 1 RF Gnd 2 3 RF Out Vcc 4 5 Gnd TXD RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to Pin 4 50Ω RF output. Connect to suitable antenna Positive supply pin. +2.5 to +5.5 Volts. This should be a ‘clean’ noise free supply with less than 25mV of ripple Supply 0 Volt and Ground Plane Transmit Data Digital Input (SDI) Notes 1. The module operates internally from an on board 3.3 Volt low drop regulator. 2. TXD input will be correctly driven by logic operating at 5 Volts (CMOS & TTL logic levels). Input should not be driven by an analogue source. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 6 of 30 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver LPRS Data Sheet ERx00RS Receiver The ERx00RS-02 Receiver is a complete sub-system that combines a high performance low power RF receiver, a ‘flash’ programmable microcontroller and a voltage regulator (Figure 3). The microcontroller programmes the functions of the RF receiver and provides the interface to the host system via a data output. It also contains programmable EEPROM memory that holds configuration data for the various receiveroperating modes. The microcontroller also relieves the host from the intensive demands of searching for signals within the noise, recovering the received data and then presenting it to the host. A Received Signal Strength Indicator output can be optionally used to measure received signal levels. The module connects to a 50Ω antenna such as a whip, helical or PCB loop. Antenna (1) RSSI Output (3) Vcc (8) Regulator RF Receiver BSY (4) Micro Processor Serial Data Output (5) Serial Data Input (6) RDY (7) Ground (9) RF Ground (2) Figure 3 Easy-Radio Receiver Block Diagram The ERx00RS-02 will receive and decode any Easy-Radio transmission within range and on the same frequency and deliver clean RS232 data to the host system for further processing. The Serial Data Output operates at programmable standard Baud Rates (default/typical 19,200Baud). Key parameters (frequency, power output, serial baud rate etc.) of the module may be programmed using the Easy-Radio PC Software via SDI pin 6. (Easy Radio Configuration Command Set, later in this document) Pin Out 4.0mm 38.0 mm 14.0mm Top View (Receiver) 10.0mm 15.0 mm 1 2 3 4 5 6 7 8 9 Pin Pitch 2.54 mm PCB Hole Size 1.0 mm Figure 4 Physical Dimensions ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 7 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Pin Description Pin No Name Description Notes 1 2 Antenna RF Ground 3 4 5 6 7 8 RSSI BSY Data Out Data In RDY Vcc 9 Ground 50Ω RF input/output. Connect to suitable antenna. RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to other Ground pins. Received Signal Strength Indication - Analogue Output (Low - Ready for data from Host) (High - Not Ready) Received Data Output ER command Input Input (Low – Host Ready to receive data) (High – Not Ready) Positive supply pin. +2.5 to +5.5 Volts. This should be a ‘clean’ noise free supply with less than 25mV of ripple. Connect to supply 0 Volt and ground plane CTS function SDO SDI RTS function Checklist 1. The module operates internally from an on board 3.3 Volt low drop regulator. The logic levels of the input/output pins are therefore between 0 Volt and 3.3 Volts. (See RS Performance Data). 2. All digital inputs and outputs are intended for connection to low voltage logic devices. Do not connect any of the inputs or outputs directly to an RS232 port. The receiver module may be permanently damaged by the voltages (+/- 12V) present on RS232 signal lines. See Application Circuit (Figure 11) for typical connection to an RS232 port via MAX232 interface IC. 3. Outputs will drive logic operating at 5 Volts provided the switching levels are less than 3V. 4. If in handshaking mode, pin (7) of the ERx00RS-02 module should be 0V for data to be delivered. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 8 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Application & Operation ERx00TS-02 & RS-02 Figure 5 shows a typical system block diagram comprising hosts (user’s application) connected to EasyRadio Transmitters and Receivers. Host (A) will be monitoring (collecting data) and Host (B) will be receiving and processing this data. Transmit Data (TXD) Host (A) Receive Data Output RF Link Easy-Radio Transmitter Easy-Radio Receiver Host (B) Figure 5 Typical System Block Diagram The Host (A) should provide the serial data input (up to a maximum 180 characters per packet) to the EasyRadio transmitter. The data should be sent in ‘bursts’ therefore allowing adequate time for transmission and reception over the RF link (See Figure 6). The receiver, upon reception and decoding of the RF transmission immediately sends serial data to the Host B. Data is sent and received in standard ‘RS232’ serial format (logic level only) and there is no restriction on the characters that may be sent. (HEX 00 – FF) A. Host (A) sends serial data to the Easy-Radio Transmitter (A). The data must be continuously streamed at the selected baud rate and it loads an internal transmit buffer until either it is full or a gap of two bytes is detected. B. After detecting either the ‘End of Data’ gap or the ‘Buffer Full’ condition the controller enables RF transmit and sends the data in the buffer using Manchester coding for efficient transmission across the RF link. Any Easy-Radio receivers within range that ‘hear’ the transmission will simultaneously decode the data and place it into their receive buffers. C. After checking the data for integrity, the Data within the receive buffer of Easy-Radio Receiver (B) is then sent continuously to the host at the selected baud rate. There is no ‘RF handshaking’ provided at either the transmitter or receiver. The user should therefore ensure that sufficient time is allowed for the completion of transmission and reception of data. The Timing Specifications detail these requirements (see page 9). Transmitter Host (A) must allow time for the ‘Over Air’ transmission and for the receiving Host (B) to unload (and process) the data before sending any more new data. The receiver Host (B) must always be ‘ready and waiting’ for data to arrive. It should be possible to use fast response ‘interrupts’ without any loss of data. With such a ‘one-way’ (simplex) system there is no confirmation of the satisfactory reception of the data and for added reliability it is recommended that the data be sent, perhaps, repetitively several times. For increased reliability the use of transceivers (which can acknowledge packet reception) is recommended. Easy-Radio services do not provide automatic acknowledgement (or re-tries) but these can be provided by the users application. A Host (A) sends serial data to Easy-Radio (A) Two Byte Delay for 'End of Data' B Easy-Radio (A) Encodes data then Transmits Over Air Easy-Radio (B) Receives & Decodes C Easy-Radio (B) sends serial data to Host (B) Figure 6 Serial Data ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 9 of 30 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver LPRS Data Sheet ERx00TRS-02 Transceiver Description The Easy-Radio Transceiver is a complete sub-system that combines a high performance very low power RF transceiver, a microcontroller and a voltage regulator (Figure 7). . Antenna (1) RSSI Output (3) Regulator Vcc (8) RF Transceiver Micro Processor BSY (4) Serial Data Output (5) Serial Data Input (6) RDY (7) Ground (9) RF Ground (2) Figure 7 Easy-Radio Transceiver Block Diagram The Serial Data Input and Serial Data Output operate at the standard 19,200 Baud and the two handshake lines provide optional flow control to and from the host. The Easy-Radio Transceiver can accept and transmit up to 180 bytes of data, which it buffers internally before transmitting in an efficient over-air code format. Any other Easy-Radio Transceiver within range that ‘hears’ the transmission will decode the message and place the recovered data within a receive buffer that can then be unloaded to the receiving host for processing and interpretation. Transmission and reception are bi-directional half duplex i.e. transmit OR receive but not simultaneously. 38.0 mm 4.0mm Top View (Transceiver) 14.0mm 10.0mm 15.0 mm 1 2 3 4 5 6 7 8 9 Pin Pitch 2.54 mm PCB Hole Size 1.0 mm Figure 8 Physical Dimensions ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 10 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Pin Description Pin No Name Description Notes 1 2 Antenna RF Ground 3 4 RSSI Busy Output 5 6 7 8 Serial Data Out Serial Data In Host Ready Input Vcc 9 Ground 50Ω RF input/output. Connect to suitable antenna. RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to other Ground pins. Received Signal Strength Indication Digital Output to indicate that transceiver is ready to receive serial data from host. Digital output for received data to host Digital input for serial data to be transmitted Digital Input to indicate that Host is Ready to receive serial data from transceiver Positive supply pin. +2.5 to +5.5 Volts. This should be a ‘clean’ noise free supply with less than 25mV of ripple. Connect to supply 0 Volt and ground plane CTS function RTS function Checklist 1. The module operates internally from an on board 3.3 Volt low drop regulator. The logic levels of the input/output pins are therefore between 0 Volt and 3.3 Volts. (See specifications/performance data). 2. The serial inputs and outputs are intended for connection to a UART or similar low voltage logic device. Do not connect any of the inputs or outputs directly to an RS232 port. The transceiver module may be permanently damaged by the voltages (+/- 12V) present on RS232 signal lines. See Application Circuit (Figure 11) for typical connection to an RS232 port via MAX232 interface IC. 3. The ‘Host Ready Input’ should be tied to 0 Volt (Ground) if not used, when handshaking is enabled. 4. The ‘Serial Data In’ should be tied to Vcc if not used. (Receive mode only). 5. Outputs will drive logic operating at 5 Volts and inputs will be correctly driven by logic operating at 5 Volts (CMOS & TTL logic levels). ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 11 of 30 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver LPRS Data Sheet Application & Operation ERx00TRS-02 Figure 9 shows a typical system block diagram comprising hosts (user’s application) connected to EasyRadio Transceivers. The hosts (A & B) will be monitoring (collecting data) and/or controlling (sending data) to some real world application. Serial Data Output Serial Data Input Host (A) Easy-Radio Transceiver (A) Busy Serial Data Output RF Link Easy-Radio Transceiver (B) Serial Data Input Busy Host Ready Host (B) Host Ready Figure 9 Typical System Block Diagram The hosts provide serial data input and output lines and two ‘handshaking’ lines that control the flow of data to and from the Easy-Radio Transceivers. The ‘Busy’ output line, when active, indicates that the transceiver is undertaking an internal task and is not ready to receive serial data. The ‘Host Ready’ input is used to indicate that the host is ready to receive the data held in the buffer of the Easy-Radio Transceiver. The host should check before sending data that the ‘Busy’ line is not high, as this would indicate that the transceiver is either transmitting or receiving data over the radio link. It should also pull the ‘Host Ready’ line low and check that no data appears on the Serial Data Output line. Detailed operation of interfacing, handshaking (including timing) is described in the ‘Easy-Radio Software Guide’. Timing Specifications – Applies to all Easy-Radio Modules. Parameters Min Units Notes Host Serial Input/Output Host Character Format End of Data Delay RF Transmit Buffer Size 2400, 4800, 9600, 19200, 38400 + Custom 1 Start, 8 Data, No Parity, 1 Stop 2 x BAUD BYTE Duration 13.2 + (n Bytes X 0.8) 1-180 baud Bits mS mS Bytes 1 2 &2a 3 4 5 Notes 1. Data is inverted i.e. Start Bit is logic low. The inputs are intended for direct connection to a microcontroller UART or to RS232 inputs and outputs via an RS232 Level translator such as a Maxim MAX232, which invert the logic of the RS232 signals. This allows direct connection to, for example a Microcontroller UART. The data rate is user programmable (Default 19200 baud) and may differ between individual units within a system. (See Application Circuit diagram for logic level to RS232 interface figure 11). 2. 1 start, 8 data, 1 stop = 10 bits @ 104uS/bit = 0.52mS/character at 19200 Baud. (Default) a. Some Custom BAUD rates require 2 stop bits, otherwise some characters may be lost. b. If parity is used, substitute in the above calculation using 11 bits. 3. The ‘End of Data’ delay is fixed at twice the character time. 4. A fixed package overhead of 13.2mS is added to all packets. 5. The buffer size is limited to 180 bytes. Sending more than 180 bytes will cause loss of data. a. CTS pin will go high 2 bytes before the buffer is full. This allows characters already sent to be accepted by the ER module. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 12 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Absolute Maximum Ratings ERx00TS-02, ERx00RS-02 and ERx00TRS-02 Operating Temperature Range Storage Temperature Range -40° C to +85° C -40° C to +85° C Vcc All Other Pins (N.B.) Antenna - 0.3 to + 6 Volts - 0.3 to 3.3 Volts 50V p-p @ < 10MHz Performance Data: ERx00TS-02 Transmitter Supply +5.0 Volt ± 5%, Temperature 20° C DC Parameters Pin Min Typical Max Units Notes Supply Voltage (Vcc) Supply current Interface Levels Data Input Logic 1 Data Input Logic 0 Input Impedance RF Parameters Antenna Impedance RF Frequency 3 3 2.5 5.0 23 5.5 Volts mA 1 RF Power Output 2.0 19.2 (Default) 38.4 ppm KHz dBc Kbps Typical 13 Max 0.2 Pin 2 2 Frequency accuracy FM deviation Harmonics Data Rate Logic Timing Power Up Time Mechanical Size Pin Pitch Weight 434 870 928 +10 +7 Volts Volts KΩ Units Ohms MHz MHz MHz dBm (434MHz) dBm (869MHz) Min 433 868 902 -5 -5 100 Typical 50 434 869.85 915 +10 +7 Max ±10 64 -43 2.4 Pin Min 31 x 12 x 4 2.54 2.5 Units mS Notes See ER Configuration Command set 50Ω load (depends on frequency) Overall Below fundamental Custom Over Air BAUD rates can be set via software Notes 2 mm mm gms Standard 0.1 Inch Notes Measure on full RF power. Current will reduce as power decreases. Time required to ‘lock’ synthesiser from power up. If not previously calibrated or after a channel change, power up time is increased to 70mS. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 13 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Performance Data: ERx00RS-02 Receiver Supply +5.0 Volt ± 5%, Temperature 20° C DC Parameters Pin Min Typical Max Units Supply Voltage (Vcc) Receive supply current 8 8 8 2.5 5.0 19.5 120 5.5 Volts MA Sleep Mode current Interface Levels Data Output Logic 1 Data Output Logic 0 Logic Output Current Data Input Logic 1 Data Input Logic 0 Input Pull-ups RF Parameters Antenna Impedance RF Frequency Receiver Receive Sensitivity LO leakage Data Rate RSSI Output Logic Timing Initial Power Up Time Mechanical Size Pin Pitch Weight µA 3.1 0.1 25 3.6 0.2 2.0 Pin 1 Min 433 868 902 -99 3 2.4 0 Pin Min 100 Typical 50 434 869.85 915 -102 < -60 19.2 Typical 14 38 x 14 x 4 2.54 3.5 Notes Max 434 870 928 Volts Volts MA Volts Volts KΩ Units Ohms MHz MHz MHz 10k load to +Vcc supply 10k load to +Vcc supply Notes See ER Configuration Command set BER = 10-3 Meets EN 300 220-3 38.4 1.2 DBm DBm Kbps Volt Max 75 Units mS Notes 1 mm gms Standard 0.1 Inches -105 See Figure 10 Mm Notes 1. When power is first applied to the module the processor retrieves ‘calibration’ data for the RF section that compensates for temperature and power supply voltage variations. The receiver will then be ready to receive. It would normally be left in this powered state ready to receive data. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 14 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Performance Data: ERx00TRS transceiver Supply +5.0 Volt ± 5%, Temperature 20° C DC Parameters Pin Min Typical Max Units Supply Voltage (Vcc) Transmit supply current Receive supply current Sleep Mode current 8 8 8 8 2.5 5.0 25 21 120 5.5 Volts mA mA Interface Levels Data Output Logic 1 Data Output Logic 0 Logic Output Current Data Input Logic 1 Data Input Logic 0 Input Pull-ups RF Parameters Antenna Impedance RF Frequency Transmitter RF Power Output Frequency accuracy FM deviation Harmonics Over Air Data rate Receiver Receive Sensitivity LO leakage Serial Data Rate RSSI Output Logic Timing Initial Power Up Time µA 3.1 0.1 25 2.0 0.2 Pin 1 Min 433 868 902 1 -5 -5 2400 -99 3 0.3 0 Pin Min Mechanical Size Pin Pitch Weight 100 Typical 50 434 869.85 915 Max 434 870 928 +10 +5 ±10 64 -25 19200 +10 +5 -102 < -60 19.2 -105 Typical 13 38 x 14 x 4 2.54 3.5 Notes Volts Volts mA Volts Volts KΩ Units Ohms MHz MHz MHz 10k load to +Vcc supply 10k load to +Vcc supply 1 Notes See ER Configuration Command set dBm (434MHz) dBm (869MHz) ppm kHz dBc bps 50Ω load Depends on Frequency Overall 38.4 1.2 dBm dBm Kbps Volt BER = 10-3 Meets EN 300 220-3 Host interface. 6 See Figure 10 Max 75 Units mS Notes 2,3 38400 Manchester Encoded Mm mm gms Standard 0.1 Inches Notes 1. The ‘Host Ready Input’ and the ‘Serial Data Input’ have ‘weak’ internal pull-ups enabled. These inputs should not however be left ‘floating’ but should be tied to either Vcc or Ground 0 Volts. 2. When power is first applied to the module the processor retrieves ‘calibration’ data for the RF section that compensates for temperature and power supply voltage variations. The transceiver will then be ready to receive (default) or transmit. It would normally be left in this powered state ready to receive data. 3. During power up the Busy Output line goes high. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 15 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver Easy-Radio Configuration Command Set The programming software sends ‘Text Commands’ to the modules and this action can be performed by terminal software or the host’s Microcontroller using the following list of commands: Note that shaded items are new 02 commands only. Command Function ER400 ER900 Notes Programmable via ER Windows Software RS232 Communication Settings ER_CMD#U0 Custom BAUD rate 300 300 ER_CMD#U1 ER_CMD#U2 ER_CMD#U3 ER_CMD#U4 ER_CMD#U5 ER_CMD#U? UART Data Rate 2400 4800 9600 19200 38400 2400 4800 9600 19200 38400 Get UART Value ER_CMD#H1 ER_CMD#H2 Handshaking ON Handshaking OFF OFF ER_CMD#A70 ER_CMD#A71 ER_CMD#A72 PARITY DISABLE EVEN PARITY ODD PARITY DISABLED BY DEFAULT When enabled data = 1 Start, 8 Data, 1 Parity, 1 Stop ER_CMD#I7 ER_CMD#I8 FAST ACK Enable FAST ACK Disable OFF OFF ER400Series 1mW 2mW 3mW 4mW 5mW 6mW 7mW 8mW 9mW 10mW ER900 Series 0.0625mW (TS) 0.125mW (TS) 0.25mW (TS) 0.5mW (TS) 1.2mW (TS) 1.5mW (TS) 2mW (TS) 3.1mW (TS) 4mW (TS) 5mW (TS) 1mW 2mW 3mW 4mW 5mW 0.0625mW 0.125mW 0.25mW 0.5mW 0mW The module replies echos with the UART value. Eg: ER_CMD#U2 No ACK is required. OFF Only effects RTS Pin. (Upper case i) See notes on “FAST ACK” below. RF POWER Settings ER_CMD#P0 ER_CMD#P1 ER_CMD#P2 ER_CMD#P3 ER_CMD#P4 ER_CMD#P5 ER_CMD#P6 ER_CMD#P7 ER_CMD#P8 ER_CMD#P9 ER_CMD#P? ER_CMD#p0 ER_CMD#p1 ER_CMD#p2 ER_CMD#p3 ER_CMD#p4 ERx00-02 Series V2.3 RF Power Output Sets output power on a channel. Warning! This level will be set to the default setting when the frequency is changed or reset via a Channel command. Get Power Value Set Default RF Power Output. This allows the host to set each channel to a different default Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. 0.0625mW (TRS) 0.125mW (TRS) 0.25mW (TRS) 0.5mW (TRS) 1mW (TRS) 1.2mW (TRS) 1.5mW (TRS) 2mW (TRS) 2.5mW (TRS) 3.1mW (TRS) The module replies with the power value. eg: ER_CMD#P9 No ACK is required. NOTE lower case ‘p’ Page 16 of 30 LPRS Data Sheet ER_CMD#p5 ER_CMD#p6 ER_CMD#p7 ER_CMD#p8 ER_CMD#p9 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver power setting. (Ideal for automatic selection between bands like 869 & 914 etc.) 6mW 7mW 8mW 9mW 10mW 1mW 2mW 3mW 4mW 5mW RF Channel Settings ER_CMD#C0 ER_CMD#C1 ER_CMD#C2 ER_CMD#C3 ER_CMD#C4 Channel 0 Channel 1 Channel 2 Channel 3 Channel 4 433.23 MHz 433.30 MHz 433.45 MHz 433.55 MHz 433.68 MHz 869.9MHz 914.65MHz Not Set Not Set 869.85MHz(i) ER_CMD#C5 Channel 5 433.83 MHz Not Set ER_CMD#C6 Channel 6 433.88 MHz Not Set ER_CMD#C7 Channel 7 434.00 MHz Not Set ER_CMD#C8 ER_CMD#C9 ER_CMD#C? Channel 8 Channel 9 Get Channel Value 434.15 MHz 434.35 MHz Not Set Not Set ER_CMD#C: TS ONLY Set Frequency Bank 1 TS ONLY Set Frequency Bank 2 ER_CMD#C; All channels can now be chosen in software. Custom frequencies can only be set using software available from LPRS. The module replies echos with the power value. Eg: ER_CMD#C9 No ACK is required. : = colon ; = semi-colon MISCELLANEOUS COMMANDS ER_CMD#R1 Reset to Default Settings U4, P9, C7 ER_CMD#A00 ER_CMD#A01 ER_CMD#A10 ER_CMD#A31 DCS OFF (default) DCS ON Encryption OFF (default) Encryption ON CRC16 OFF (default) CRC16 ON Repeater Mode OFF (default) Repeater Mode ON ER_CMD#Fds FREQUENCY SWAP Recommended for new designs where back compatibility to older devices is not required Encryption algorithm is created and owned solely by LPRS. It uses a 16-bit seed that can be set by the developer. The CRC16 routines are more efficient and secure than the old CRC8. For new applications it is recommended. When enabled, this mode will simply echo EVERY message is hears. Therefore no more than 1 repeater should be used UNLESS specific rules are followed. An application note will be available shortly to explain this further. This feature allows you to transmit on a different channel frequency to the receive frequency. e.g. ER_CMD#F07 After reselecting channel 0, the module will listen on CH0 but transmit on CH7. To reset the module to its default, send the same source channel number to the destination: e.g. ER_CMD#F00 Warning DCS should be disabled to use this feature. ER_CMD#A11 ER_CMD#A20 ER_CMD#A21 ER_CMD#A30 ‘d’ = destination ‘s’ = source ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 U4, P9, C0 Copyright LPRS 2005. Factory Default Page 17 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver TEST MODES ER_CMD#T0 ER_CMD#T1 ER_CMD#T2 ER_CMD#T3 Upper FSK Carrier Modulated Carrier Lower FSK Carrier Get Firmware Revision ER_CMD#T4 RAW Data Test Test Mode 0 Test Mode 1 Test Mode 2 Returns Firmware String: eg ER400TRS-02V2.01.5 Out of CTS pin i) Recommended setting for EN300-220 compliance This setting is effective on ALL ER900TRS/RS/TS despatched on or after 5th September 2005. To successfully send a command do the following: 1. Send Command from host: e.g. ER_CMD#U5 2. In the case of a TRS/RS: o Wait for echo of command from module. In the case of a TS: o Wait 20mS 3. Send the ASCII string from the host: ACK (Set UART BAUD to 38400) e.g. ER_CMD#U5 The commands should be sent exactly as shown (case sensitive) with no spaces between characters. The ACK command is sent as three ASCII characters, ACK in sequence. ‘A’’C’’K’ . Note that the TS (transmitter) devices send data ‘over air’ as they are not equipped with a serial data out or handshake pins. This takes approximately 20mS and time should be taken in to account before sending the ‘ACK’ sequence “FAST ACK” In this mode the procedure to update settings is made much faster. In response to an ER_CMD#x string the TRS/RS module will reply with a single HEX 6 (0x06) which is the ASCII ACK value. The host will then issue the same single byte 0x06 in replacement of the Txt version of “ACK”. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 18 of 30 Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver LPRS Data Sheet Notes: RSSI Output The Receiver/Transceiver has a built in RSSI (Received Signal Strength Indicator) that provides an analogue output voltage that is inversely proportional to the RF energy present within the pass band of the receiver. It ranges from 0 Volt (maximum signal, –65dBm) to 1 Volt (minimum signal, -115bBm) and has a slope of approximately 50dB/Volt. This analogue output signal should only be connected to a high impedance load (>100kΩs) and can be used to provide a measure of the signal strength and any interfering signals (noise) within band during the installation and operation of systems. Figure 10 RSSI Output Voltage 1.3 1.2 1.1 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -115 433Mhz 868MHz -110 -105 -100 -95 -90 -85 -80 -75 -70 -65 Received Signal Strength (dBm) Application Notes MAX232 Application 7805 +5V Antenna VO ANT RF GND RSSI BUSY DATA OUT DATA IN HOST RDY VCC GND 1 2 G N D 100n 1 2 3 4 5 6 7 8 3 4 5 6 7 8 9 C1+ VCC V+ GND C1T1OUT C2+ R1IN C2R1OUT VT1IN T2OUT T2IN R2IN R2OUT 16 15 14 13 12 11 10 9 Vin = 8-12V DC VI 1N4148 100n 1 6 2 7 3 8 4 9 5 100n DCD DSR RXD RTS TXD CTS DTR RI GND PC AT MAX232 0 Volt 100n Host Ready Tied Low Figure 11 MAX232 Application Circuit Compatibility The ERx00TS, ERx00RS & ERx00TRS use crystal controlled synthesisers to accurately define transmit and receive frequencies incorporating RS232 protocols, and so should not be used in connection with Non-Easy Radio RF modules unless the firmware allows. ERx00-02 Series V2.3 Datasheet Revision 2.3 Sept 2005 Copyright LPRS 2005. Page 19 of 30 LPRS Data Sheet Easy-Radio ‘02’ (2nd Generation Modules) ER400TS Transmitter, ER400RS Receiver & ER400TRS Transceiver ER900TS Transmitter, ER900RS Receiver & ER900TRS Transceiver PCB Layout The Ground (0 Volt) pins of the receiver should be connected to a substantial ground plane (large area of PCB copper) connected to 0 Volt. It is suggested that a double sided PCB be used with one layer being the ground plane. Power Supply The supply used to power the receiver should be ‘clean’ and free from ripple and noise (
ER900TRS 价格&库存
很抱歉,暂时无法提供与“ER900TRS”相匹配的价格&库存,您可以联系我们找货
