ER-EVK-SIGFOX
ER-EVK-SIGFOX
    LPRS
    LPRS - ER-EVK-SIGFOX - Evaluation Board, for SigFox LPRS RF Modules, u-blox GNSS Receiver, Patch Ant...
ER-EVK-SIGFOX 数据手册
eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS This board can be used for the evaluation and range testing of the following LPRS RF Modules: eRA400, eRA900, eRIC4, eRIC9, eRA-LoRa, eRIC-LoRa and eRIC-Sigfox. The board is provided with a u-blox® GNSS (Global Navigation Satellite System) receiver and patch antenna that allows the board to accurately report its geographical position during range tests. Feature Description eRIC Radio Socket eRA Radio Socket RSSI LED Display Mode Selection Microcontroller ISM Radio USB Interface On/Off Switch Power Indicator GNSS USB Interface GNSS Signal Indicator GNSS Receiver Module GNSS Antenna ISM Radio Antenna ISM Radio Antenna Tx LED (Red) Rx LED (Green) PICKIT Programmer Battery Box Gnd Pin Snap in spring clip socket for all eRIC modules. N.B. Position of Pin 1 Turned pin Single in Line (SIL) sockets for all eRA style modules Bargraph mode 5 x LED display – Received Signal Strength Indication (RSSI) 3 way DIL switch sets Mode of operation on power up (See table) Microchip PIC24HJ32GP302 microcontroller Micro USB connector for Serial Data In/Out for RF modules Board power On/Off slide switch Red LED indicates that board is powered Micro USB connector for serial data output from GNSS module Indicates valid received signal with 1 pulse per second LED output u-blox NEO M8M Global Navigation Satellite System (GNNS) module Patch Antenna for GNSS Module 50R SMA Female RF connector for antenna or test equipment connection to eRIC modules 50R SMA Female RF connector for antenna or test equipment connection to eRA modules Indicates transmit data activity Indicates receive data activity Connector for Microchip PICKIT PIC programmer for microcontroller 3 x AA Pencell battery box. Provides 4.5V power supply for board via On/Off slide switch 0V Gnd reference for ‘scope or other test equipment eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 1 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS The board can be powered either by the host, via the USB connection or by the built in three cell (4.5V) switched battery supply mounted on the reverse side of the board. The u-blox GNSS receiver module serial data can be directly accessed using the second micro USB connector provided. Messages from the receiver can be viewed in any serial terminal software program. Alternatively the u-blox U-Centre evaluation software can be used to exercise and fully explore the device. The on board Microchip™ PIC24HJ32GP302 is pre-programmed with a bootloader and application software which can be selected to perform different functions using the Mode Select switch. (See table) An FTDI USB device provides the serial interface between the board and the host PC USB port. A Microchip™ PICkit compatible Single In Line (SIL) connector is provided to allow re-programming of the on board PIC microcontroller. Application software or firmware can be updated via the board micro USB connector using the pre-loaded bootloader firmware within the microcontroller. easyRadio Companion software can be used to update the microcontroller firmware. (TBA) The Mode Select switch allows up to 8 different operating modes to be selected but only 6 modes are implemented in the current firmware version. The following table describes the different operating modes available: eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 2 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Mode 1 easyRadio UART Set the Mode Switch to Mode1 (as shown). This mode allows serial data on a host PC to be sent and received over-air to and from the selected (matching) RF modules that are plugged into the boards. In this mode, the FTDI USB device, the PIC and the eRIC/eRA module are interconnected by software. The board should be connected to a PC (or laptop) by plugging the micro USB cable between the PC and the board micro USB connector. Terminal software or easyRadio Companion software can be used to communicate with the eRIC/eRA modules. Data or easyRadio Commands can be sent or received by the PC in this mode. Firmware update or user applications can also be uploaded to eRIC and eRA modules using easyRadio Companion software. Mode 1 Automatic Transmit Mode Set the Mode Switch to Mode1 (as above) and place a jumper between Pin4 and Pin5 of the PICkit programming connector (as shown in the picture) before power up or reset. This sets the RF module into Automatic Transmit Mode and the board will send incrementing binary data over-air and display the transmitted data on the LED display (RA0-RA4). The jumper should be removed after tests have been completed. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 3 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Mode 1 Automatic Receive Mode Set the Mode Switch to Mode1 (as above) and place a jumper between Pin3 and Pin4 of the PICkit programming connector (as shown in the picture) before power up or reset. This sets the RF module into Automatic Receive Mode. Upon successful reception of an RF signal from a matching transmitter board set in Mode1_Automatic_Tx mode, the transmitted data will be ‘echoed’ on the receiving board LED display. Should no signal be received then all the LEDs will be extinguished. This mode in conjunction with Mode 0 can be used for performing battery powered range tests between a pair of boards. The jumper should be removed after tests have been completed. Mode 2 GNSS Test Mode This mode allows the GNSS module serial data to be directly accessed by connecting a cable between the board GNSS micro USB connector (note position) and a PC USB port. Any terminal software or easyRadio Companion software can be used to communicate with the GNSS module via a PC. GNRMC NMEA data with time, Active/Invalid, latitude, N/S, longitude, E/W, speed over ground, date is sent by the GNSS module to the PC through the PIC microcontroller. PC UART baud rate for this mode should be set to 19200. The GNSS Evaluation software can be used to locate the current physical position on maps using this mode, which is explained further below. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 4 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Mode 3 RSSI Mode In this mode the RF module ‘Received Signal Strength Indication’ (RSSI) is displayed as a bar graph on LEDs RA0–RA4 which is most useful during practical range testing and site surveys. If there is no valid signal/data for more than 5 seconds then all the LEDS are extinguished. The diagrams below relate the Received Signal Strength to the LED display. For eRIC modules: For eRA modules: Refer to RSSI table in the eRA Datasheet for conversion of the Hex values to dBm which are dependent upon the selected bandwidth. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 5 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Mode 4 GNSS Data + RSSI In this mode, the GNSS module, the PIC microcontroller and the eRIC/eRA modules are interconnected by software. Software in the PIC microcontroller discovers the Baud rate of the chosen eRIC/eRA modules and sets the microcontroller UART to match that of the modules. The raw position data received by the GNSS module is parsed (GNRMC) and the serial number of the (eRIC/eRA) module is appended to the packet. It is then transmitted over-air by the module in the following order: Time, Active/Invalid, Latitude, N/S, Longitude, E/W, Speed over ground in Knots, Date, Module Serial number. A matching board set to Mode 1 easyRadio UART Mode will receive the over-air data and forward the serial data to the GNSS PC application or easyRadio Companion software. If the corresponding receiver board is set to Mode 3 the RSSI is displayed on both boards providing indication of both boards signal strength and therefore ‘Out of Range’ condition. Mode 5 eRIC SigFox Tracker Mode In this mode a board fitted with an eRIC-Sigfox module will wake up every 15 minutes, turn on the GNSS module, acquire its position and transmit the data to the local SigFox network. The data can then be viewed via the Internet on the Sigfox servers. A total of up to 140 messages (maximum limit) per day can be sent. The default transmit timer repetition rate is 15 minutes. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 6 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Changing Transmit Interval Using the supplied jumpers in conjunction with the PICKit header pins the transmission interval can be set between 1-31 seconds or 1-31 minutes. Fitting the jumper between pins 3 and 4 sets the interval in seconds whereas fitting the jumper between pins 4 and 5 sets the interval in minutes. When this jumper is fitted, on power up (or reset) LEDs RA1, RA2, RA3 will initially flash three times to indicate operation in this mode. An internal one second counter then starts and the count is displayed in (5 bit) binary format on LEDs RA0 – RA4. (RA4 flashes once per second) When the desired count is reached the jumper should be removed and the transmission interval timer will remain set to this value until the next power up. Not Implemented Not Implemented Mode 8 Eval Board Firmware Update In this mode, the FTDI USB device and the PIC are connected by software and this mode is used only for updating the Eval board PIC firmware. Use of this mode is further explained below. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 7 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS The table below shows the modes that are applicable to the selected RF module: Mode 1 1 2 3 4 5 6 7 8 Mode Description easyRadio UART Auto Tx to Rx GNSS RSSI GNSS Data + RSSI eRIC-SigFox Tracker Not Implemented Not Implemented Board Firmware Update eRA400 eRA900   N/A   eRIC4 eRIC9   N/A   eRA LoRa   N/A   eRIC LoRa   N/A   eRIC Sigfox N/A  The table below shows interoperability with other LPRS development products: Mode 1 1 2 3 4 5 5 Description easyRadio UART Auto Tx to Rx GNSS RSSI GNSS Data + RSSI eRIC-SigFox Tracker LoRa, eRIC, eRA eRIC_eRA_GNSS_Eval_Board_1.3.docx GNSS GNSS GNSS GNSS GNSS Transmitter eRIC DK USB Dongle eRIC DK W4 eRIC DK GNSS GNSS USB Dongle Receiver eRIC DK USB Dongle eRIC DK SW3 GNSS GNSS GNSS eRIC DK USB Dongle GNSS eRIC DK USB Dongle GNSS GNSS Page 8 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Using the GNNS Evaluation Tool Software: Download the latest GNNS Evaluation software and the firmware files from the LPRS website: http://www.lprs.co.uk/development-tools/easyradio-evaluation-software.html After downloading the files, install the GNNS Evaluation Tool software. At present this is only supported for use on Windows Operating System devices. The GNNS evaluation software window looks similar to the screen shot below: Update Firmware The ‘Update Firmware’ tab provides a function where in the firmware on the Evaluation board PIC microcontroller can be updated. To update the firmware, the Eval board must be set in Mode8 before power up or reset as described earlier. This sets the board in bootloader mode, which is indicated by LED RA0 and LED RA1 flashing three times followed by RA0 LED staying on after power up. Using the application, click on the blue ‘Open file’ icon and load the appropriate hex file by browsing to its saved location and opening the file. This action will set RA1 LED On and the grey shaded box will then display the file path and the file version of the loaded file. The lower white window displays the current bootloader file version (e.g. GNSSE Bootloader V1.2 followed by the auto discovered COM port. The greyed out ‘Flash’ icon will then turn yellow and should be clicked to start the firmware update. Whilst the PC is updating the PIC firmware, RA2 LED will flash continuously to indicate that it is updating. The progress of the update is shown on the PC application as a percentage. After progress is reported at 100% (Success) click the brown ‘Close’ icon to exit the application. Return the Mode select switches to the all off position (Mode 1) or as required and then power cycle the board. Bootloader Update To update the Bootloader the Eval board must be set, as before in Mode8 before power up or reset. Using the application, click on the blue ‘Open file’ icon and load the appropriate bootloader hex file by browsing to its saved location and opening the file. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 9 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS On detecting the new bootloader file RA0 & RA1 LEDs will light and the previously greyed out text of the ‘Upgrade Bootloader’ button will become normal. Click this button to begin the firmware update. The following warning will be displayed which must be heeded to prevent permanent damage to the microcontroller. Click ‘Yes’ to accept and start the update process. The progress of the update is again shown on the PC application as a percentage but this time, will run twice as the existing bootloader is internally backed up and finally over-written. During the update RA3 & RA4 LEDs will flash. Upon successful completion of the update RA0 LED will light. Click the brown ‘Close’ icon to exit the application. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 10 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS There are three ways that the Evaluation Board and the application software can be configured to locate GNNS coordinates on the maps. 1) Manually After installing and running the ‘GPS Evaluation Tool’ select the ‘GNSS Tracking’ tab to display a screen similar to that below: N.B. There is no requirement to connect the Eval Board to the PC in this mode.     On the ‘Maps’ drop down box choose either ‘Bing’ or ‘Google’ maps, as desired. The default is ‘Bing’ maps. If known, the Latitude and Longitude co-ordinates can be entered manually in the ‘Test Lat’ and the ‘Test Long’ boxes. For example, to locate the LPRS Sales office in Witney UK, enter Latitude: ‘51.7786’ and Longitude: ‘-1.4816’. After entering the data, click the ‘Locate’ button to display the location of these co-ordinates on the map. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 11 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS 2) Automatically Plot GNNS Position (Mode 2 GNSS Test Mode)                 Connect the micro USB cable between the board USB connector and the PC USB connector. Set the board for Mode2 operation before power up or reset. Use the ‘Com Port’ drop down box to select the auto detected Com port. Use the ‘Baud’ drop down box to select ‘19200’ Baud rate. After a few moments the red ‘CHOOSE COM PORT’ bar at the bottom of the window should change to a green ‘Connected COM xx 9600’. Where xx is detected Com port. If the co-ordinates need to be updated on the map every second set the ‘Timer mS’ to 1000. The default is 2000. Use the ‘Maps’ drop down box to choose either ‘Bing’ or ‘Google’ maps, as desired. The default is ‘Bing’ maps. Click the ‘Start’ button to begin the location mapping. As soon as the GNSS module receives valid data from the satellites (which may initially take several minutes) the red on-board GNSS_LED will flash once per second and a marker will show the reported location on the maps. Click the ‘Stop’ button to stop locating or the ‘Refresh’ button to clear the current markers. Click the ‘C’ button to centre the map on the first reported location. Click the ‘+’ button to zoom in and ‘-‘ button to zoom out of the map. Tick the 'Show Marker' check box to show an LPRS ‘Wireless Mike’ marker on the map. Untick this box to hide the ‘Wireless Mike’ marker and show a red dot marker on the map. Click on the marker to display its distance from first located co-ordinate and the maximum distance travelled by all the markers. The data can be logged by ticking the ‘Log GPS (GNSS) Data to File’ box and viewed by clicking the ‘Open Log File’. Sigfox positions can also be located by entering valid Sigfox data in the entry box. The picture below shows the location of the LPRS Technical branch in Warrington UK received by the GPS module: eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 12 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS 3) Range Testing Using two Eval boards proceed as follows:     Plug three fresh 1.5V Alkaline AA batteries into the holder on the back of the Eval board(s). Insert an eRIC or an eRA module into the provided socket. Set the board for Mode4 operation before power up or reset. On setting this mode, the PIC software checks the eRIC/eRA baud rates and sets its own baud rate to match. GNNS data received by the GNNS module is collected and processed by the PIC software. The GNNS GNRMC data is then filtered and sent to the eRIC/eRA module which then sends this packet over-air appending the eRIC/eRA module serial number. The packet structure is shown below:   Time, Active/Invalid, Latitude, N/S, Longitude, E/W, Speed over ground in Knots, Date, Serial Number of the (eRIC/eRA) module. This board, being battery powered is portable and can be hand held during walk/range tests. The other board configured as a receiver should be connected to a PC to map the co-ordinates received by the GNNS Evaluation board (Transmitter). The receiver board can be another evaluation board set in Mode1 or any other eRIC/eRA development board. Open com port for receiver board and select baud rates and other settings. Then whenever the module on the receiver board receives GNNS data from transmitter evaluation board, it will display the co-ordinates on maps. eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 13 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS eRIC_eRA_GNSS_Eval_Board_1.3.docx Page 14 of 15 eRA, eRIC, eRA-LoRa, eRIC-LoRa & eRIC-Sigfox Evaluation Board with GNSS Product Order Codes Name Description Order Code Eval Board II eRIC/eRA Evaluation Board (does not include RF Modules) (N.B. A pair of boards are required for range testing) eR-EVK-01 Document History Issue 0.1 1.0 1.1 1.2 1.3 Date January 2017 February 2017 May 2017 June 2017 June 2017 Revision Draft Release Additions, clarifications and amendments Drawings updated Interoperability table added Please contact the Sales office for availability of variants of the standard product. Changes to this Document Copyright Disclaimer Terms and Conditions of Use This data sheet has been updated to reflect changes throughout the range of LPRS modules. Specific changes are recorded in the documentation history above. See: www.lprs.co.uk See: www.lprs.co.uk See: www.lprs.co.uk Contact Information Please contact LPRS or your local distributor Low Power Radio Solutions Ltd. Two Rivers Industrial Estate Station Lane, Witney Oxon, OX28 4BH England eRIC_eRA_GNSS_Eval_Board_1.3.docx Tel: Fax: Web: Email: Technical: +44 (0)1993 709418 +44 (0)1993 708575 http://www.lprs.co.uk info@lprs.co.uk technical@lprs.co.uk Page 15 of 15
ER-EVK-SIGFOX 价格&库存
很抱歉,暂时无法提供与“ER-EVK-SIGFOX”相匹配的价格&库存,您可以联系我们找货
