FMS-K-2M-MP-A
FMS-K-2M-MP-A
    LABFACILITY
    LABFACILITY - FMS-K-2M-MP-A - Thermocouple, Magnetic Strip, ANSI, K, -50 °C, 100 °C, 6.6 ft, 2 m
FMS-K-2M-MP-A 数据手册
ENGLISH Datasheet ANSI Type K Magnetic Strip Thermocouple with Miniature Thermocouple Plug For use on ferro-magnetic surfaces, 2 metres of cable with fitted miniature flat pin plug A flexible magnetic strip thermocouple capable of being attached to most ferro-magnetic surfaces, the large area of the magnet ensures good adhesion allowing simplicity of installation. Useful in a wide range of temperature monitoring applications, particularly in test and development • • • • • Type K thermocouple in a flexible magnetic strip for use on ferro-magnetic surfaces Magnetic strip 50 x 25 x 1 mm Temperature range: -50°C to +100°C 2 metre Teflon® insulated twisted pair lead Fitted miniature flat pin plug Specifications: Sensor type: Construction: Hot junction: Cable: Termination: Temperature range: Type ‘K’ (Nickel Chromium/Nickel Aluminium) to IEC 584 Magnetic strip 50 x 25 x 1mm Positioned/seated in magnetic strip for surface measurement 1/0.3mm Teflon® insulated twisted pair Miniature flat pin plug -50°C to +100°C T/C Type Cable length Temp range order code: K 2 metres -50°C to +100°C XF-1964-FAR
FMS-K-2M-MP-A 价格&库存
很抱歉,暂时无法提供与“FMS-K-2M-MP-A”相匹配的价格&库存,您可以联系我们找货
