EXT-J-C1-10.0-SP-SS
EXT-J-C1-10.0-SP-SS
    LABFACILITY
    LABFACILITY - EXT-J-C1-10.0-SP-SS - THERMOCOUPLE WIRE, TYPE J, 10M, 7X0.2MM
EXT-J-C1-10.0-SP-SS 数据手册
ENGLISH Datasheet IEC Thermocouple Extension Leads with Miniature or Standard Thermocouple Connectors - Available in types K, J, T & N Specifications Thermocouple Cable Construction: Single pair 7/0.2 PVC insulated cable / wire Laid flat, side by side & PVC sheathed Tolerance class 2 Insulation rating -10 to 105°C IEC colour coded Miniature Thermocouple Connectors: Miniature connector with flat plug pins Miniature socket with thermocouple contacts Contacts are polarised to prevent incorrect connection Max temperature 220°C IEC colour coded Standard Thermocouple Connectors: Standard connector with solid, round plug pins Standard socket with thermocouple contacts Suitable for industrial applications Contacts are polarised to prevent incorrect connection Max temperature 220°C IEC colour coded Extension Leads with Miniature Thermocouple Plug & Socket Connectors TYPE J J T N N N PLUG & SOCKET CONNECTORS Miniature Miniature Miniature Miniature Miniature Miniature CABLE LENGTH (mtrs) 2 10 10 2 5 10 CODE EXT-J-C1-2.0-MP-MS EXT-J-C1-10.0-MP-MS EXT-T-C1-10.0-MP-MS EXT-N-C1-2.0-MP-MS EXT-N-C1-5.0-MP-MS EXT-N-C1-10.0-MP-MS IEC COLOUR CODE BLACK BLACK BROWN PINK PINK PINK PART NUMBER XF-1855-FAR XF-1859-FAR XF-1856-FAR XF-1858-FAR XF-1860-FAR XF-1861-FAR Extension Leads with Standard Thermocouple Plug & Socket Connectors TYPE PLUG & SOCKET CONNECTORS CABLE LENGTH (mtrs) CODE IEC COLOUR CODE PART NUMBER J Standard J Standard 2 EXT-J-C1-2.0-SP-SS BLACK XF-1862-FAR 5 EXT-J-C1-5.0-SP-SS BLACK XF-1857-FAR J Standard 10 EXT-J-C1-10.0-SP-SS BLACK XF-1866-FAR T Standard 2 EXT-T-C1-2.0-SP-SS BROWN XF-1865-FAR T Standard 5 EXT-T-C1-5.0-SP-SS BROWN XF-1864-FAR N Standard 5 EXT-N-C1-5.0-SP-SS PINK XF-1863-FAR
EXT-J-C1-10.0-SP-SS
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款红外发射二极管,用于红外线发射,广泛应用于遥控器、红外通信等领域。
3. 引脚分配:EL817有两个引脚,分别为正极和负极。
4. 参数特性:工作电压1.4-1.8V,工作电流20mA,发射波长940nm。
5. 功能详解:EL817通过电流驱动发射红外光,用于信号传输。
6. 应用信息:主要用于家用电器、汽车电子、工业控制等领域的红外信号传输。
7. 封装信息:EL817采用SMD封装,尺寸为3.0mm x 1.5mm。
EXT-J-C1-10.0-SP-SS 价格&库存
很抱歉,暂时无法提供与“EXT-J-C1-10.0-SP-SS”相匹配的价格&库存,您可以联系我们找货
