010008TD
010008TD
    LABFACILITY
010008TD 数据手册
Industrial Pt100 probe with Terminal Head,Extension& replaceable insert Heavy duty Pt100 probe with an aluminium terminal head,lagging extension and optional,replaceable insert. Specifications Sensor Type Pt100, class B, 4 wire to IEC 60751 Probe material 316 stainless steel, welded tip,6mm x 150mm Extension 12.5mm diameter x 75mm Process connection 1/2 inchBSP,stainless steel thread Optional insert Replaceable,spring loaded insert Tip temperature Rating -50oC to +450o C Terminal Head Aluminium with captive, threaded cover housing a DIN terminal block Assembly rating IP67 Cable entry M20 cable gland Probe dia(mm) 6 Probe length (mm) Farnell code 150 7088449 Data Ref: FAR 30A Lab code 010008TD
010008TD 价格&库存
很抱歉,暂时无法提供与“010008TD”相匹配的价格&库存,您可以联系我们找货
