AM-K-PCB
AM-K-PCB
    LABFACILITY
AM-K-PCB 数据手册
temperature and process technology ANSI Miniature Thermocouple PCB D ŽƵŶƟŶŐ^ŽĐŬĞƚ Formed in 1971, Labfacility specialize in the field of Temperature and Process Measurement. ͚ ^ƉĞĐŝĂůůLJĚĞƐŝŐŶĞĚĨŽƌWŵŽƵŶƟŶŐ͛ We are the largest UK manufacturer of both temperature sensors and thermocouple connectors         Quality and Service are key ĞůĞŵĞŶƚƐŝŶƚŚĞĐŽŶƟŶƵĞĚŐƌŽǁ ƚŚ of Labfacility. Technical support is always freely available from our experienced technical sales teams and the company has ISO9001 s ĞƌƐĂƟůĞ͕ ŚŝŐŚƋƵĂůŝƚLJ͕ĐŝƌĐƵŝƚďŽĂƌĚŵŽƵŶƟŶŐŵŝŶŝĂƚƵƌĞƐŽĐŬĞƚ ^ƉĞĐŝĂůůLJĚĞƐŝŐŶĞĚĨŽƌWŵŽƵŶƟŶŐ Solid pins for direct PCB mount, 1.3mm diameter pins x 7.9mm pitch WƌŽǀ ŝƐŝŽŶĨŽƌĐŽůĚũƵŶĐƟŽŶƐĞŶƐŽƌ Available in Thermocouple types K, J, T For Types K, J, T contacts are made from true Thermocouple alloys ŽůŽƵƌĐŽĚĞĚŝŶĂĐĐŽƌĚĂŶĐĞǁ ŝƚŚE ^/ƐƉĞĐŝĮ ĐĂƟŽŶ D ĂdžŝŵƵŵĐŽŶƟŶƵŽƵƐŽƉĞƌĂƟŶŐƚĞŵƉĞƌĂƚƵƌĞϮϮϬĚĞŐΣ T/C Type Colour Code (ANSI) нWŽƐŝƟǀ Ğ (alloy type) -E ĞŐĂƟǀ Ğ (alloy type) Labfacility Code K J T Yellow Black Blue +Nickel Chromium +Iron +Copper -Nickel Alloy AM-K-PCB -Copper Nickel AM-J-PCB -Copper Nickel AM-T-PCB Farnell Code ĂĐĐƌĞĚŝƚĂƟŽŶ͘ Contact Details Email sales@labfacility.com Website www.labfacility.com FAR038/0613 ANSI D ŝŶŝĂƚƵƌĞdŚĞƌŵŽĐŽƵƉůĞWD ŽƵŶƟŶŐ^ŽĐŬĞƚ 234-7140 234-7139 234-7141
AM-K-PCB
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率最高可达180MHz。
5. 功能详解:具备高级的DSP功能,支持浮点运算和多种通信接口。
6. 应用信息:广泛应用于工业控制、医疗设备和消费电子产品等领域。
7. 封装信息:采用QFP封装,共有48个引脚,适用于表面贴装技术。
AM-K-PCB 价格&库存
很抱歉,暂时无法提供与“AM-K-PCB”相匹配的价格&库存,您可以联系我们找货
AM-K-PCB
  • 1+44.62427
  • 10+37.20864
  • 25+35.73738
  • 50+34.37291
  • 100+33.74406
  • 500+33.11522
  • 1000+32.46264
库存:640
