FW-J-2.0-C4-SP-Z Z=CABLE CLAMPS
    LABFACILITY
    LABFACILITY - FW-J-2.0-C4-SP-Z Z=CABLE CLAMPS - Thermocouple, Washer Eyelet, IEC, J, -60 °C to 350 °...
FW-J-2.0-C4-SP-Z Z=CABLE CLAMPS 数据手册
ENGLISH Datasheet Washer Thermocouple Type K or J IEC With Cable Clamps and Terminating in a Standard Plug           Thermocouple housed in a washer eyelet Grounded tip for quick response Washer with 6mm clearance hole 2 Metre glassfibre insulated, stainless steel over braided extension lead,7/0.2mm Glassfibre insulated flat pair construction, conductors laid flat, Glassfibre insulated with Glassfibre jacket, silicone varnished throughout + stainless steel overbraid for added protection and mechanical strength Fitted with cable clamps and standard thermocouple plug Good temperature resistance but not suitable where fluids are present Tolerance Class 2 to IEC-584 Insulation rating -60°C to 350°C (short periods up to 400°C) Colour code (cores & jacket) to IEC-584-3 T/C Type Conductors Cores Length order code K J 7/0.2mm 7/0.2mm +Green/-White +Black/-White 2 metres 2 metres XF-1961-FAR XF-1962-FAR
FW-J-2.0-C4-SP-Z Z=CABLE CLAMPS 价格&库存
很抱歉,暂时无法提供与“FW-J-2.0-C4-SP-Z Z=CABLE CLAMPS”相匹配的价格&库存,您可以联系我们找货
