FC-123-D
FC-123-D
    LABFACILITY
    LABFACILITY - FC-123-D - Compression Fitting, 1/8 " BSPP, Stainless Steel, 2 mm Probe
FC-123-D 数据手册
Datasheet Stainless Steel Compression Fittings • Thermocouple installation fittings • To suit a wide range of mineral insulated and other probe type sensors offered by Farnell • Male in-line stainless steel compression type with nut & olive BSP Parallel: Type Thread Size Thread Type Suits Probe Ø Manufacturers Code Order code St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel 1.0mm 1.5mm 2.0mm 3.0mm 4.0mm 1/4” 1/8” 3/16” FC-129-D FC-132-D FC-123-D FC-140-D FC-203-D FC-144-D FC-139-D FC-137-D 2770783 1633392 XF-1867-FAR 1633393 XF-1381-FAR XF-1868-FAR XF-1386-FAR XF-1380-FAR St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/4” 1/4” 1/4” 1/4” 1/4” 1/4” 1/4” BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel BSP Parallel 1.5mm 3.0mm 4.0mm 6.0mm 1/4” 1/8” 3/16” FC-173-D FC-159-D FC-176-D FC-168-D FC-170-D FC-161-D FC-169-D XF-1485-FAR 2770781 XF-1486-FAR 1633398 2770785 XF-1483-FAR XF-1375-FAR St/Steel 1/2” BSP Parallel 3.0mm FC-199-D 2770786 215.2 St/Steel St/Steel 1/2” 1/2” BSP Parallel BSP Parallel 6.0mm 8.0mm FC-201-D FC-212-D 2770782 XF-1376-FAR BSPT Tapered: Type Thread Size Thread Type Suits Probe Ø Manufacturers Code Order code St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” 1/8” BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered 1.0mm 1.5mm 2.0mm 3.0mm 4.0mm 6.0mm 1/4" 1/8” 3/16” FC-130-D FC-131-D FC-124-D FC-133-D FC-122-D FC-136-D FC-142-D FC-134-D FC-135-D XF-1339-FAR 254630 XF-1869-FAR 254642 XF-1481-FAR XF-1384-FAR XF-1870-FAR XF-1385-FAR XF-1378-FAR St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/4” 1/4” 1/4” 1/4” 1/4” 1/4” 1/4” BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered BSPT Tapered 1.5mm 3.0mm 4.0mm 6.0mm 1/4" 1/8” 3/16” FC-164-D FC-158-D FC-177-D FC-167-D FC-165-D FC-160-D FC-163-D XF-1484-FAR 1633411 XF-1487-FAR XF-1387-FAR XF-1383-FAR XF-1338-FAR XF-1330-FAR St/Steel St/Steel St/Steel 1/2” 1/2” 1/2” BSPT Tapered 3.0mm BSPT Tapered 6.0mm BSPT Tapered 8.0mm FC-209-D FC-200-D FC-210-D 2770784 1633414 XF-1331-FAR Type Thread Type Pitch Suits Probe Ø Manufacturers Code Order Code St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel M8 M8 M8 M8 M8 M8 M8 M8 1mm 1mm 1mm 1mm 1mm 1mm 1mm 1mm 1.0mm 1.5mm 2.0mm 3.0mm 4.0mm 4.5mm 1/8” 3/16” FC-250-D FC-251-D FC-252-D FC-174-D FC-255-D FC-256-D FC-254-D FC-257-D XF-1343-FAR XF-1347-FAR XF-1344-FAR XF-1353-FAR XF-1490-FAR XF-1491-FAR XF-1489-FAR XF-1492-FAR St/Steel St/Steel St/Steel St/Steel M16 M16 M16 M16 1.5mm 1.5mm 1.5mm 1.5mm 3.0mm 4.5mm 6.0mm 8.0mm FC-226-D FC-231-D FC-223-D FC-225-D 2770787 XF-1488-FAR XF-1329-FAR XF-1335-FAR St/Steel St/Steel St/Steel St/Steel St/Steel M20 M20 M20 M20 M20 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 3.0mm 4.5mm 6.0mm 8.0mm FC-271-D FC-273-D FC-276-D FC-278-D FC-280-D XF-1493-FAR XF-1348-FAR XF-1349-FAR XF-1350-FAR XF-1494-FAR 215.2 Type Thread Size Thread Type Suits Probe Ø Manufacturers Code Order Code St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/8" 1/8" 1/8" 1/8" 1/8" 1/8" 1/8" 1/8" 1/8" 1/8" NPT NPT NPT NPT NPT NPT NPT NPT NPT NPT 1.0mm 1.5mm 2.0mm 3.0mm 4.0mm 4.5mm 6.0mm 1/8" 3/16" 1/4" FC-150-D FC-151-D FC-148-D FC-152-D FC-149-D FC-154-D FC-156-D FC-153-D FC-155-D FC-157-D XF-1362-FAR XF-1361-FAR XF-1482-FAR XF-1342-FAR XF-1379-FAR XF-1373-FAR XF-1354-FAR XF-1363-FAR XF-1372-FAR XF-1337-FAR St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/4" 1/4" 1/4" 1/4" 1/4" 1/4" 1/4" 1/4" NPT NPT NPT NPT NPT NPT NPT NPT 1.5mm 4.0mm 4.5mm 6.0mm 8.0mm 1/8" 3/16" 1/4" FC-179-D FC-186-D FC-182-D FC-184-D FC-185-D FC-181-D FC-183-D FC-187-D XF-1371-FAR XF-1359-FAR XF-1357-FAR XF-1358-FAR XF-1370-FAR XF-1356-FAR XF-1355-FAR XF-1360-FAR St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel St/Steel 1/2" 1/2" 1/2" 1/2" 1/2" 1/2" 1/2" NPT NPT NPT NPT NPT NPT NPT 3.0mm 4.5mm 6.0mm 8.0mm 1/8" 3/16" 1/4" FC-240-D FC-241-D FC-242-D FC-243-D FC-245-D FC-246-D FC-247-D XF-1366-FAR XF-1367-FAR XF-1368-FAR XF-1364-FAR XF-1336-FAR XF-1365-FAR XF-1369-FAR 215.2
FC-123-D 价格&库存
很抱歉,暂时无法提供与“FC-123-D”相匹配的价格&库存,您可以联系我们找货
