ANT3505B4G0006KM1
ANT3505B4G0006KM1
    HEK(合康电子)
    SMD,5x35mm
    LTE天线
ANT3505B4G0006KM1 数据手册
4G Chip Antenna: ANT3505B4G0006KM1                                                       Application: 698~2690MHz 4G Antenna, Navigation, etc… Features high reliability, ultra Impact, Omni-directional… Part number ANT 3505 (1) R (2) 4G00 (3) 06K (4) M1 (5) (1) Size Code 35x5mm (2) Packing Tape and reel (3) Frequency 698~2690MHz (4) Packing Number 0.6K (5) Code M1 Electrical Specification Working Frequency Bandwidth 698-960 /1710-2690 GHz 140/470 MHz(Typ.) Return Loss 2.8 / 3.5 dB Min. Polarization Linear Azimuth Beamwidth Omni-directional Peak Gain 2.9 dBi (Typ.) Impedance 50 Ohm Operating Temperature - 40~105 ℃ Maximum Power Termination Resistance to Soldering Heats 4W Ag (Environmentally-Friendly Leadless) 260℃ , 5sec. The specification is defined on EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 40.0±0.5 F Feeding point W 5.0±0.30 S Soldering Point T 6.0±0.30 S 2.4±0.2 F 1.6±0.2 4G Chip Antenna: ANT3505B4G0006KM1                                                       Evaluation Board Reference - Regular Layout PCB Dimension Antenna Layout Reference unit :mm Electrical Characteristics Return Loss   4G Chip Antenna: ANT3505B4G0006KM1          Efficiency                                              4G Chip Antenna: ANT3505B4G0006KM1                                                       4G Chip Antenna: ANT3505B4G0006KM1                                                       4G Chip Antenna: ANT3505B4G0006KM1                                                       Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. JUN 2022 Ver.H01
ANT3505B4G0006KM1 价格&库存
很抱歉,暂时无法提供与“ANT3505B4G0006KM1”相匹配的价格&库存,您可以联系我们找货
