ANT2012R24005KL2
ANT2012R24005KL2
    HEK(合康电子)
    ANT2012R24005KL2
ANT2012R24005KL2 数据手册
2.4GHz 2012Chip Antenna: ANT2012R24005KL2             Application: WLAN, 802.11b/g, Bluetooth, etc…   Features SMD, high reliability, ultra compact, Omni-directional… Part number ANT 2012 (1) R (2) 2400 (3) 5K L2 (4) (5) (1)Size Code 2.0x1.2mm (2) Packing Tape and reel (3) Frequency 2.4GHz (4) Packing Number 5K (5)Code L2 Electrical Specification Working Frequency Range 2400 ~2484 MHz Peak Gain 0.8dBi (Typ.) Impedance 50 Ohm VSWR 2.5(Max) Polarization Azimuth Beamwidth Operation Temperature(℃) Linear Omni-directional -40 ~85℃ The specification is defined on HEK EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 2.00±0.15 1 Feeding W 1.20±0.15 2 Ground T 0.50±0.10 D 0.20±0.15 1 / 6    2.4GHz 2012Chip Antenna: ANT2012R24005KL2             Evaluation Board Reference PCB Dimension Matching  circuit    Antenna Layout Reference Unit : mm : Chip Antenna : Land Pattern  2 / 6    2.4GHz 2012Chip Antenna: ANT2012R24005KL2             Electrical Characteristics VSWR&Efficiency Efficiency 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% Efficiency(%) VSWR VSWR 10 9 8 7 6 5 4 3 2 1 2.3 2.4 2.5 2.6 2.3 Frequency (GHz) 2.4 2.5 Frequency (GHz) 2.6   Radiation Pattern   X  Z Y    ZX-Plane 10 315 0 0 dBi 45 -10 -20 -30 -40 270 270 90 Y 225 135 180 270° 90° X Z 0° Horizontal Polarization 3 / 6    4GHz 20 012Chip p Antenna: ANT T2012R R24005K KL2 2.4          ZY-Plane XY--Plane 4 / 6    2.4GHz 2012Chip Antenna: ANT2012R24005KL2             Taping Specifications Reel and Taping Specification Reel Specification TYPE SIZE 2012 7” 5K/Reel A ψB ψC ψD 2.0±0.5 13.5±1.0 21±1.0 60±1.0 ψM W 11.5±2.0 178±2.0 Taping Specification Packaging Type Paper Type 2012 A B W E F 1.50±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05 G 4.0±0.10 H T ψD +0.10 2.0±0.05 0.75±0.10 1.50 P 4.0±0.1 -0 5 / 6    2.4GHz 2012Chip Antenna: ANT2012R24005KL2             Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March. 2020 Ver.H01 6 / 6
ANT2012R24005KL2 价格&库存
很抱歉,暂时无法提供与“ANT2012R24005KL2”相匹配的价格&库存,您可以联系我们找货
