ANT8010R24003KM1
ANT8010R24003KM1
    HEK(合康电子)
    SMD,8x1mm
    ANT8010R24003KM1
ANT8010R24003KM1 数据手册
2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 Applications: WLAN, 802.11b/g, Bluetooth, etc… Features SMD, high reliability, ultra compact, Omni-directional… Part number ANT 8010 R 2400 (1) (2) (3) 3K (4) M1 (5) (1) Size Code 8.0x1.0mm (2) Packing Tape and reel (3) Frequency 2.4GHz (4) Packing Number 3K (5) Code M1 Electrical Specification Working Frequency Range 2400 ~2484 MHz Peak Gain 1.5 dBi (Typ.) Impedance 50 Ohm VSWR Polarization Azimuth Beamwidth Operation Temperature(℃) 2.5 ( Max) Linear Omni-directional -40~85 The specification is defined on EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 8.10+-0.15 1 Feeding W 1.00+-0.15 2 Soldering T 1.00+-0.10 D1 0.40+-0.15 D2 0.40+-0.15   1 / 6    2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 Evaluation Board Reference PCB Dimension Matching  circuit    Antenna Layout Reference   Unit : mm :Chip Antenna : Land Pattern   2 / 6    2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 Electrical Characteristics Return Loss & Radiation VSWR&Efficiency Efficiency 10 9 8 7 6 5 4 3 2 1 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% Efficiency VSWR VSWR 2.3 2.4 2.5 Frequency (GHz) 2.3 2.6 2.4 2.5 Frequency (GHz) 2.6   Radiation Pattern Z  Y  X    ZX-Plane 0 0 10 10 315 270 0 dBi 315 45 0 -10 -10 -20 -20 -30 -30 270 90 -40 dBi 45 90 -40 Y 225 135 180 Horizontal Polarization 270° 90° 225 135 X Z 0° 180 Vertical Polarization   3 / 6    2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 ZY-Plane 0 0 10 315 270 0 10 dBi -10 -10 -20 -20 -30 -30 270 90 -40 225 135 dBi 0 315 45 45 90 -40 225 270° 135 90° Y 180 Z Horizontal Polarization 180 0° Vertical Polarization X XY-Plane 10 315 0 0 10 dBi 0 315 45 -10 -10 -20 -20 dBi 45 -30 -30 -40 270 0 270 90 90 -40 Z 225 135 180 Horizontal Polarization 270° 90° 225 135 Y X 0° 180 Vertical Polarization   4 / 6    2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 Taping Specifications Reel and Taping Specification Reel Specification TYPE SIZE 8010 7” ψB A 3K/Reel 5.5±0.5 ψC 13.5±1.0 16.5±1.0 ψD 55±1.0 ψM W 18.5±2.0 178±2.0 Taping Specification Packaging Type A B W E F G H T ψD P +0.10 Paper Type 8010 1.30±0.20 8.30±0.20 16.0±0.20 1.50±0.10 7.5±0.10 3.85±0.10 1.65±0.05 1.5±0.10 1.50 4.0±0.1 -0   5 / 6    2.4GHz 8010 Chip Antenna: ANT8010R24003KM1 Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March 2021 Ver.H01   6 / 6
ANT8010R24003KM1 价格&库存
很抱歉,暂时无法提供与“ANT8010R24003KM1”相匹配的价格&库存,您可以联系我们找货
