ANT8060R55001KM1
ANT8060R55001KM1
    HEK(合康电子)
    SMD,6x8mm
    ANT8060R55001KM1
ANT8060R55001KM1 数据手册
UWB 8060 Chip Antenna: ANT8060R55001KM1                     Application: UWB indoor location, Smart Key, etc… Features SMD, high reliability, ultra compact, Omni-directional… Part number ANT 8060 R 5500 (1) (2) (3) 1K (4) M1 (5) (1) Size Code 8.0x6.0mm (2) Packing Tape and reel (3) Frequency 5500MHz (4) Packing Number 1K (5) Code M1 Electrical Specification Working Frequency Range 3500~8500 MHz Peak Gain 3.5 dBi (Typ.) Impedance 50 Ohm VSWR Polarization Azimuth Beamwidth Operation Temperature(℃) 3.0 ( Max) Linear Omni-directional -40 ~85℃ The specification is defined on HEK EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 8.0+-0.15 1 Feeding W 6.0+-0.15 2,3,4,5,6 Soldering T 1.0+-0.10 UWB 8060 Chip Antenna: ANT8060R55001KM1                     Evaluation Board Reference PCB Dimension Matching  circuit      Antenna Layout Reference        Unit : mm :Chip Antenna : Land Pattern Electrical Characteristics UWB 8060 Chip Antenna: ANT8060R55001KM1                     Return Loss & Radiation VSWR&Efficiency Efficiency 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% Efficiency(%) VSWR VSWR 10 9 8 7 6 5 4 3 2 1 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 3.5 Frequency (GHz) 4 4.5 5 5.5 6 6.5 7 Frequency (GHz) 7.5 8 8.5   Radiation Pattern Z Y X Frequency=5500MHz ZX-Plane 0 0 10 315 270 10 0 0 -10 -10 -20 -20 -30 -30 270 90 -40 225 135 180 Horizontal Polarization ZY-Plane 315 45 dBi 45 90 -40 Y 270° 90° 225 135 X Z 0° 180 Vertical Polarization UWB 8060 Chip Antenna: ANT8060R55001KM1    0 0 10 315 270 0                  10 dBi 315 45 -10 -10 -20 -20 -30 -30 270 90 -40 225 135 45 90 -40 90° 225 270° 135 Y Z 180 dBi 0 0° 180 X Horizontal Polarization Vertical Polarization XY-Plane 10 315 0 0 10 dBi 0 0 -10 -10 -20 -20 -30 -30 -40 270 315 45 270 90 dBi 45 90 -40 Z 225 135 180 Horizontal Polarization Taping Specifications 90° 225 270° 135 Y X 0° 180 Vertical Polarization UWB 8060 Chip Antenna: ANT8060R55001KM1                     Reel and Taping Specification Reel Specification TYPE 8060 A ψB ψC ψD 2.0±0.5 13.0±1.0 21±1.0 67±1.0 SIZE 13” 1K/Reel W ψM 20.5±2.0 178±2.0 Taping Specification Packaging Type A B W E F G H T ψD P +0.10 Paper Type 8060 6.30±0.20 8.30±0.20 16.0±0.20 1.75±0.10 7.5±0.05 4.0±0.10 2.0±0.05 0.30±0.10 1.50 12±0.1 -0 Recommended Reflow Profile UWB 8060 Chip Antenna: ANT8060R55001KM1                     Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March 2020 Ver.H01
ANT8060R55001KM1 价格&库存
很抱歉,暂时无法提供与“ANT8060R55001KM1”相匹配的价格&库存,您可以联系我们找货
