ANT4005B4G0006K00
ANT4005B4G0006K00
    HEK(合康电子)
    SMD,5x40mm
    LTE天线
ANT4005B4G0006K00 数据手册
4G Chip Antenna: ANT4005B4G0006K00                                                        Application: 698~2690MHz 4G Antenna, Navigation, etc… Features high reliability, ultra Impact, Omni-directional… Part number ANT 4005 (1) R (2) 4G00 (3) 06K (4) 00 (5) (1) Size Code 40x5mm (2) Packing Tape and reel (3) Frequency 698~2690MHz (4) Packing Number 0.6K (5) Code 00 Type Electrical Specification Working Frequency Bandwidth 698-960 /1710-2690 GHz 260/980 MHz(Typ.) V.S.W.R 3.0 ( Max) Polarization Linear Azimuth Beamwidth Omni-directional Peak Gain 3.2/4.0 dBi (Typ.) Impedance 50 Ohm Operating Temperature - 40~105 ℃ Maximum Power Termination Resistance to Soldering Heats 1W Ag (Environmentally-Friendly Leadless) 260℃ , 5sec. The specification is defined on EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 40.0±0.5 F Feeding point W 5.0±0.30 S Soldering Point T 6.0±0.30 S 2.4±0.2 F 1.6±0.2 4G Chip Antenna: ANT4005B4G0006K00                                                        Evaluation Board Reference - Regular Layout PCB Dimension Antenna Layout Reference unit :mm Electrical Characteristics Return Loss Return Loss&VSWR   Frequency (MHz) S11 (dB) 698 -7.91 960 -7.26 1710 -7.03 2170 -20.17 2300 -18.34 2400 -13.70 2490 -13.00 2690 -11.26 4G Chip Antenna: ANT4005B4G0006K00          Efficiency                                               4G Chip Antenna: ANT4005B4G0006K00                                                        4G Chip Antenna: ANT4005B4G0006K00                                                        4G Chip Antenna: ANT4005B4G0006K00                                                        4G Chip Antenna: ANT4005B4G0006K00                                                        Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. MAY 2022 Ver.H01
ANT4005B4G0006K00 价格&库存
很抱歉,暂时无法提供与“ANT4005B4G0006K00”相匹配的价格&库存,您可以联系我们找货
