DPX1608R24554K65
DPX1608R24554K65
    HEK(合康电子)
    DPX1608R24554K65
DPX1608R24554K65 数据手册
2.4/5GHz 1608 Diplexer: DPX1608R24554K65                           Applications: WLAN, 802.11b/g, ISM Band… Features SMD, high reliability, ultra Impact… Part number DPX 1608 R (1) (2) 2455 (3) 4K (4) 65 (5) (1)Size Code 1.6x0.8mm (2) Packing Tape and reel (3) Frequency 2.4/5GHz (4) Packing Number 4K (5)Type 65 Electrical Specification DESCRIPTION VALUE LOW Band High Band 2400~2500MHz 4900~6000MHz Insertion Loss 0.50dB (Max) 0.75dB (Max) Return Loss 12.0dB(Min) 12.0dB(Min) Pass Band Attenuation Isolation Operating Temperature The specification is defined on EVB. 27dB(Min).@2400~2500MHz 30dB(Min).@4800~5000MHz 27dB(Min).@10300~11700MHz 32dB(Min).@7200~7500MHz 20dB(Min).@15450~16200MHz 32dB(Min).@2400~2500MHz 32dB(Min).@4800~5950MHz -40 ~ +85 °C 2.4/5GHz 1608 Diplexer: DPX1608R24554K65                           Dimension and Terminal Configuration Dimension (mm) No. Terminal Name 1.60±0.15 P1 GND W (mm) 0.80±0.15 P2 Common T (mm) 0.60±0.15 P3 GND D1 (mm) 0.25±0.10 P4 Low band D2 (mm) 0.125±0.10 P5 GND D3 (mm) 0.30±0.10 P6 L (mm) E1 (mm) 0.15±0.10 P.S : Symmetrical, No direction Evaluation Board Reference High band 2.4/5GHz 1608 Diplexer: DPX1608R24554K65  Electrical Characteristics                          2.4/5GHz 1608 Diplexer: DPX1608R24554K65                           Taping Specifications Reel and Taping Specification Reel Specification TYPE SIZE 1608 7” 4K/Reel A ψB ψC ψD 2.0±0.5 13.5±1.0 21±1.0 60±1.0 ψM W 11.5±2.0 178±2.0 Tapping Specification maker Packaging Type Paper Type 1608 A B W E F 1.40±0.20 2.20±0.20 8.0±0.20 1.75±0.10 3.0±0.05 G 4.0±0.10 H T ψD +0.10 2.0±0.05 0.75±0.10 1.50 P 4.0±0.1 -0 2.4/5GHz 1608 Diplexer: DPX1608R24554K65                           Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March 2020 Ver.H01
DPX1608R24554K65 价格&库存
很抱歉,暂时无法提供与“DPX1608R24554K65”相匹配的价格&库存,您可以联系我们找货
