ANT3216R24003KL1
ANT3216R24003KL1
    HEK(合康电子)
    ANT3216R24003KL1
ANT3216R24003KL1 数据手册
2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 Applications: WLAN, 802.11b/g, Bluetooth, etc… Features SMD, high reliability, ultra compact, Omni-directional…   Part number ANT 3216 R 2400 (1) (2) (3) 3K (4) L1 (5) (1) Size Code 3.2x1.6mm (2) Packing Tape and reel (3) Frequency 2.4GHz (4) Packing Number 3K (5) Code L1 Electrical Specification Working Frequency Range 2400 ~2484 MHz Peak Gain 1.5 dBi (Typ.) Impedance 50 Ohm VSWR Polarization Azimuth Beamwidth Operation Temperature(℃) 2.5 (Max) Linear Omni-directional -40 ~85℃ The specification is defined on EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 3.20+-0.15 1 Feeding W 1.60+-0.15 2 Soldering T 0.55+-0.10 D 0.50+-0.15   1 / 6    2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 Evaluation Board Reference PCB Dimension Matching  circuit    Antenna Layout Reference      Unit : mm : Chip Antenna : Land Pattern    2 / 6    2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 Electrical Characteristics VSWR&Efficiency Efficiency 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 10 9 8 7 6 5 4 3 2 1 Efficiency VSWR VSWR 2.3 2.4 2.5 Frequency (GHz) 2.3 2.6 2.4 2.5 Frequency (GHz) 2.6   Radiation Pattern   X  Y  Z   ZX-Plane X 0 0 10 10 315 0 dBi 315 45 -10 -10 -20 -20 dBi 45 -30 -30 270 0 270 90 -40 225 135 270° 90° 225 Horizontal Polarization 135 X Z 180 90 -40 Y 0° 180 Vertical Polarization   3 / 6    2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 ZY-Plane 0 0 10 315 270 0 10 dBi 315 45 -10 -10 -20 -20 -30 -30 270 90 -40 225 135 45 90 -40 90° 225 270° 180 dBi 0 135 Y Z Horizontal Polarization 0° 180 Vertical Polarization X XY-Plane 10 315 0 0 10 dBi 0 -10 -10 -20 -20 -30 -30 -40 270 315 45 0 270 90 dBi 45 90 -40 Z 225 135 180 Horizontal Polarization 90° 225 270° 135 Y X 0° 180 Vertical Polarization   4 / 6    2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 Taping Specifications Reel and Taping Specification Reel Specification TYPE SIZE 3216 7” 3K/Reel A ψB ψC ψD W ψM 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 Taping Specification Packaging Type A B W E F G H T ψD P +0.10 Paper Type 3216 1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1.50 4.0±0.1 -0   5 / 6    2.4GHz 3216 Chip Antenna: ANT3216R24003KL1 Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max. March 2020 Ver.H01   6 / 6
ANT3216R24003KL1 价格&库存
很抱歉,暂时无法提供与“ANT3216R24003KL1”相匹配的价格&库存,您可以联系我们找货
