ANT5020R24001KM1
ANT5020R24001KM1
    HEK(合康电子)
    SMD,2x5mm
    ANT5020R24001KM1
ANT5020R24001KM1 数据手册
2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 Application: WLAN, 802.11b/g, Bluetooth, etc… Features SMD, high reliability, ultra compact, Omni-directional… Part number ANT 5020 R 2400 (1) (2) (3) 1K (4) M1 (5) (1) Size Code 5.0x2.0mm (2) Packing Tape and reel (3) Frequency 2400MHz (4) Packing Number 1K (5) Code M1 Electrical Specification Working Frequency Range 2400~2484 MHz Peak Gain 0.9 dBi (Typ.) Impedance 50 Ohm VSWR Polarization Azimuth Beamwidth Operation Temperature(℃) 2.5 ( Max) Linear Omni-directional -40 ~85℃ The specification is defined on HEK EVB. Dimension and Terminal Configuration Dimension (mm) No. Terminal Name L 5.0+-0.15 1 Feeding W 2.0+-0.15 2 Soldering T 1.0+-0.10 D 1.0+-0.15 2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 Evaluation Board Reference PCB Dimension Matching  circuit      Antenna Layout Reference     Unit : mm :Chip Antenna : Land Pattern 2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 Electrical Characteristics Return Loss & Radiation VSWR&Efficiency Efficiency 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% Efficiency(%) VSWR VSWR 10 9 8 7 6 5 4 3 2 1 2.3 2.4 2.5 2.6 2.3 Frequency (GHz) 2.4 2.5 Frequency (GHz) 2.6   Radiation Pattern Z Y  X   Frequency=2440MHz ZX-Plane 10 315 270 0 0 10 315 45 0 -10 -10 -20 -20 -30 -30 90 -40 225 135 180 Horizontal Polarization 270 Y 270° 0 dBi 45 90 -40 90° 225 135 X Z 0° 180 Vertical Polarization 2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 ZY-Plane 10 315 270 0 0 10 dBi 315 45 0 -10 -10 -20 -20 -30 -30 270 90 -40 225 135 dBi 45 90 -40 90° 225 270° 135 Y Z 180 0 0° 180 X Horizontal Polarization Vertical Polarization XY-Plane 10 315 270 0 10 dBi 0 315 45 0 -10 -10 -20 -20 -30 -30 270 90 -40 225 135 180 Horizontal Polarization 0 dBi 45 90 -40 Z 90° 225 270° 135 Y X 0° 180 Vertical Polarization 2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 Taping Specifications Reel and Taping Specification Reel Specification TYPE 5020 SIZE 7” 1K/Reel A ψB ψC ψD 2.0±0.5 13.0±1.0 21±1.0 60±1.0 W ψM 16.5±2.0 178±2.0 Taping Specification Packaging Type Paper Type 5020 A B W E F 2.30±0.20 5.30±0.20 12.0±0.20 1.75±0.10 5.5±0.05 G 4.0±0.10 H T ψD +0.10 2.0±0.05 0.30±0.10 1.50 P 10±0.1 -0 2.4GHz 5020 Chip Antenna: ANT5020R24001KM1                 Recommended Reflow Profile Pb free solder Soaking Temp. Working Soldering Peak Time Temp. Time Temp. Time Temp. T1 T2 t1 T3 t2 T4 t3 T5 150°C 180°C 60 to 120sec 230°C more than 30sec 247 to 253°C within 10sec 260°C Max.
ANT5020R24001KM1 价格&库存
很抱歉,暂时无法提供与“ANT5020R24001KM1”相匹配的价格&库存,您可以联系我们找货
