AABG25H12M2R2
AABG25H12M2R2
    COILANK(驰兴)
    SMD,2.5x2.2x1.25mm
    AEC-Q200
AABG25H12M2R2 数据手册
Power Inductors AABG-H Series Features        Qualified to AEC-Q200. Fe base metal material core provides large saturation current. Metallization on Ferrite Core results in excellent shock resistance and damage-free durability. Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference(EMI). Low DCR decreases power loss, small and slim take up less PCB real estate. Automatic production ensures high quality and consistency. RoHS compliance. Applications       LED Lighting & Smart phone. Blue -ray disc recorders, set top box. Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras. Flat-screen TVs,blue-ray disc recorders set top box. Notebooks,desktop computers,servers,graphic cards. Portable gaming devices,personal navigation systems,personal multimedia devices. Test Equipment and Conditions      Inductance is measured with IM3536 LCR meter or equivalent. Operating temperature range -40℃ to +125℃.(Including self - temperature rise). DC current(Irms)that will cause an approximate△T of 40℃. DC current(Isat)that will cause L0 to drop approximately 35%. For AABG02 & AABG25 size inductors, absolute maximum voltage: DC 25V; For AABG03 & AABG04 size inductors, absolute maximum voltage: DC 40V; External dimensions (Unit:m/m) B D C a E c F A E Type b b A B C D Typ. E Typ. F Typ. a Typ. b Typ. c Typ. Q’TY/Reel AABG02H10 2.1±0.3 1.7±0.3 1.05Max 1.7 0.7 0.7 0.4 1.0 2.0 2000 AABG25H10 2.5±0.3 2.2±0.3 1.05Max 1.65 0.8 0.9 0.6 1.1 1.95 2000 AABG25H12 2.5±0.3 2.2±0.3 1.25Max 1.65 0.8 0.9 0.6 1.1 1.95 2000 C B a D 100 E A F c E b Type b A B C D Typ. E Typ. F Typ. a Typ. b Typ. c Typ. Q’TY/Reel AABG03H12 3.0±0.2 3.0±0.2 1.35Max 2.55 0.9 1.2 1.1 1.0 3.4 2000 AABG04H12 4.0±0.2 4.0±0.2 1.35Max 3.5 1.3 1.4 1.1 1.6 3.8 4500 AABG04H20 4.0±0.2 4.0±0.2 2.00Max 3.5 1.0 2.0 1.3 1.5 3.8 3000 Http://www.coilank.com E-mail:sales@coilank.com Power Inductors Part Number Code AABG A A: B: C: D: E: F: 02 B H C 10 D N E Series Name Dimensions(mm) Materials Thickness(mm) Tolerance Inductance R24 F Power Inductors 02:2.1 x 1.7 H Type 10:1.05 Max N:±30% M:±20% R24=0.24uH AABG-H Series Part Number Inductance(µH) @1MHz/1V DC Resistance (Ω) Max. Min Self-resonant Frequency(MHz) Heat Rating Current Irms (A) Max. Saturation Current lsat (A) Max. AABG02H10NR24 0.24 0.039 145 3.02 4.54 AABG02H10NR39 0.39 0.053 104 4.10 4.10 AABG02H10NR47 0.47 0.055 102 2.72 4.03 AABG02H10NR68 0.68 0.064 77 2.53 3.53 AABG02H10M1R0 1.0 0.089 70 2.07 3.38 AABG02H10M1R5 1.5 0.128 45 1.72 1.97 AABG02H10M2R2 2.2 0.192 39 1.46 1.92 AABG02H10M4R7 4.7 0.423 25 0.91 1.21 AABG02H10M5R6 5.6 0.500 17 0.90 1.00 AABG02H10M6R8 6.8 0.540 16 0.53 0.73 AABG02H10M100 10.0 0.824 15 0.65 0.81 AABG25H10NR33 0.33 0.038 117 3.52 4.83 AABG25H10NR47 0.47 0.044 80 3.23 4.43 AABG02H10NR56 0.56 0.055 66 2.50 3.80 AABG25H10NR68 0.68 0.058 65 2.77 3.23 AABG25H10M1R0 1.0 0.075 46 2.51 3.12 AABG25H10M1R5 1.5 0.105 40 2.02 2.62 AABG25H10M2R2 2.2 0.153 26 1.51 1.91 AABG25H10M3R3 3.3 0.233 24 1.20 1.60 AABG25H10M4R7 4.7 0.300 19 1.11 1.31 AABG25H10M100 10.0 0.530 12 0.85 0.93 AABG25H12NR24 0.24 0.029 117 4.10 6.55 AABG25H12NR33 0.33 0.036 104 3.40 5.41 AABG25H12NR47 0.47 0.040 89 3.00 5.00 AABG25H12NR68 0.68 0.050 67 3.18 3.73 AABG25H12M1R0 1.0 0.060 52 3.03 3.70 AABG25H12M1R5 1.5 0.090 35 2.40 2.92 AABG25H12M2R2 2.2 0.117 32 1.96 2.60 AABG25H12M3R3 3.3 0.190 25 1.82 1.77 AABG25H12M4R7 4.7 0.256 23 1.26 1.66 Http://www.coilank.com E-mail:sales@coilank.com Power Inductors AABG-H Series Part Number Inductance(µH) @1MHz/1V DC Resistance (Ω) Max. Min Self-resonant Frequency(MHz) Heat Rating Current Irms (A) Max. Saturation Current lsat (A) Max. AABG25H12M6R8 6.8 0.364 16 0.97 1.20 AABG25H12M100 10.0 0.480 12 0.85 1.15 AABG03H12NR33 0.33 0.027 107 4.10 7.20 AABG03H12NR47 0.47 0.033 86 4.00 6.10 AABG03H12NR68 0.68 0.040 63 3.80 5.80 AABG03H12M1R0 1.0 0.054 51 2.80 4.00 AABG03H12M1R5 1.5 0.074 37 2.00 3.20 AABG03H12M2R2 2.2 0.108 28 1.90 2.20 AABG03H12M3R3 3.3 0.150 25 1.60 1.70 AABG03H12M4R7 4.7 0.230 20 1.40 1.50 AABG03H12M6R8 6.8 0.340 16 1.10 1.40 AABG03H12M100 10.0 0.460 12 0.90 1.00 AABG04H12NR33 0.33 0.032 113 4.50 8.00 AABG04H12NR47 0.47 0.040 96 4.20 7.50 AABG04H12NR68 0.68 0.040 70 4.10 5.00 AABG04H12M1R0 1.0 0.058 55 3.50 4.50 AABG04H12M1R2 1.2 0.064 48 3.20 4.00 AABG04H12M1R5 1.5 0.070 38 2.60 3.90 AABG04H12M2R2 2.2 0.079 28 2.50 2.80 AABG04H12M3R3 3.3 0.125 23 1.90 2.00 AABG04H12M4R7 4.7 0.166 19 1.70 1.80 6.8 0.226 17 1.50 1.60 AABG04H12M100 10.0 0.335 12 1.30 1.50 AABG04H12M220 22.0 0.679 7 0.85 0.90 AABG04H20NR47 0.47 0.022 72 7.00 10.0 AABG04H20NR68 0.68 0.035 57 5.00 8.70 AABG04H20M1R0 1.0 0.026 37 5.10 8.50 AABG04H20M1R5 1.5 0.036 30 4.50 7.20 AABG04H20M2R2 2.2 0.048 25 4.20 6.10 AABG04H20M3R3 3.3 0.072 19 3.50 4.20 AABG04H20M4R7 4.7 0.108 17 2.50 4.00 AABG04H20M6R8 6.8 0.156 13 2.10 3.00 AABG04H20M100 10.0 0.216 11 1.70 2.80 AABG04H12□-1 AABG04H12M6R8 Http://www.coilank.com E-mail:sales@coilank.com Power Inductors Reliability Test Item Specifications Test conditions Temperature: 125±2℃. Duration:1000hrs. Measured at room temperature after placing for 24±4 hrs. High temperature storage test No visible mechanical damage. Inductance change: Within ±10%. Tem p 125°C High tem perature 25°C 0°C 24H 1000H Test Tim e Condition for 1 cycle. Step1:-40±2℃ 30min Min. Step2:125±2℃, transition time 1min Max. Step3:125±2℃ 30min Min. Step4:Low temp, transition time 1min Max. Number of cycles:1000. Measured at room temperature after placing for 24±4 hrs. Temperature cycling test No visible mechanical damage. Inductance change: Within ±10%. Temp 125°C Change time
AABG25H12M2R2 价格&库存
很抱歉,暂时无法提供与“AABG25H12M2R2”相匹配的价格&库存,您可以联系我们找货
