CX024AF
CX024AF
    ILME
    ILME - CX024AF - Heavy Duty Connector, MIXO Series, Insert, 2 Contacts, Receptacle, Screw Socket
CX024AF 数据手册
Part number CX 02 4AF Brief description: female insert, 2 poles, screw terminal connections, 40A 1000V, 8kV, 3, silver plated, 1 module, modular units series MIXO Product description Approvals / Standards Model female insert Reference standard Version screw connection Quality mark Product type with female contacts Family MIXO series, customizable inserts Size 1 module N. of poles 2 poles Technical data Current 40 A (A.C. and D.C.) Voltage 1000 V Rated impulse withstand voltage Conformity EN 61984:2009-06 DNV-GL, EAC CQC, CE General ordering information EAN13 code 8015747048149 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm 8 kV Packaging width 150,00 mm 3 Packaging weight 1,55 kg Wire cross-section 2,50 mm² - 8,00 mm² Packaging volume 3,51 dm³ AWG size 14 - 8 Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221108 Pollution degree Operating temperature range -40°C … +125°C (min, max) Contact type silver plated Sub-packaging length 35,00 mm IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm 7 mm Sub-packaging weight 0,26 kg Sub-packaging volume 0,22 dm³ Sub-packaging description Carton tray Sub-packaging quantity 10 Pcs PE terminal stripping length Further technical details Characteristics according to EN 61984 40A 1000V 8kV 3 Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 23,00 g Sub-packaging EAN barcode 8015747143653 Part number CX 02 4AF Catalogue drawings Catalogue drawings Notes Inserts CX 02 4AF - CX 02 4AM: (40A 1600V 12kV 2) - characteristics according to EN 61984: (40A 1000V 8kV 3) (40A 1600V 12kV 2 ) - inserts for Ø 4.8 mm cables, section: 6-10 mm2 - AWG 10-8 - footprint 1 module - use flexible cables with sections from 2.5 to 10 mm2 or extra flexible cables with sections from 2.5 to 6 mm2 - inserts for Ø 4mm cables, section: 2.5-8 mm2 - AWG 14-8 - footprint 1 module Inserts CX 02 4BF - CX 02 BM: - characteristics according to EN 61984: (40A 1000V 8kV 3) - do not twist the cables - fully insert the braids in the rear section of the contact the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support
CX024AF 价格&库存
很抱歉,暂时无法提供与“CX024AF”相匹配的价格&库存,您可以联系我们找货
