CX01UM
CX01UM
    ILME
    ILME - CX01UM - Connector Accessory, Insert, 1 Module USB Plug Connectors, MIXO Series
CX01UM 数据手册
Part number CX 01 UM Brief description: male insert, housing for USB male connectors,USB female - female connectors, male insert without USB male connector, 1 module, modular units series MIXO Product description Approvals / Standards Model male insert Version housing for USB connectors Product type male insert without USB male connector Family MIXO series, customizable inserts Size 1 module Technical data Operating temperature range -25°C … +80°C (min, max) Quality mark Conformity , DNV GL, BV, EAC Not applicable General ordering information EAN13 code 8015747175043 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Further technical details Packaging height 95,00 mm Characteristics according to EN 61984 Packaging width 117,00 mm 50V 0.8kV 3 Packaging weight 0,15 kg Insulation resistance ≥ 1 GΩ Packaging volume 1,24 dm³ Rated voltage according to UL/CSA 50V Packaging description Carton box Packaging quantity 10 Pcs UL 94 flammability rating V-0 Packaging EAN code 8015747175074 Weight 10,00 g Sub-packaging weight 0,02 kg Sub-packaging description Plastic bag Sub-packaging quantity 1 Pcs Sub-packaging EAN barcode 8015747175081 Part number CX 01 UM Catalogue drawings Notes CX 01 U insert: - 1 frame slot - enclosures: bulkhead mounting housings, high construction housings or high construction hoods the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX01UM 价格&库存
很抱歉,暂时无法提供与“CX01UM”相匹配的价格&库存,您可以联系我们找货
