CX027M
CX027M
    ILME
    ILME - CX027M - Heavy Duty Connector, MIXO Series, Insert, 2 Contacts, Plug, Crimp Pin - Contacts No...
CX027M 数据手册
Part number CX 02 7M Brief description: male insert, 2 poles, crimp connections, 70A 1000V, 8kV, 3, 2 modules, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version Crimp connection Quality mark Product type for 70A male contacts Family MIXO series, customizable inserts Size 1 module N. of poles 2 poles Technical data Current 70 A (A.C. and D.C.) Voltage 1000 V Rated impulse withstand voltage Pollution degree , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747182447 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm 8 kV Packaging width 150,00 mm 3 Packaging weight 0,80 kg Packaging volume 3,51 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221153 Sub-packaging length 35,00 mm Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm Sub-packaging weight 0,13 kg Operating temperature range -40°C … +125°C (min, max) IP degree of protection Conformity EN 61984:2009-06 IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Characteristics according to EN 61984 70A 1000V 8kV 3; 70A 1600V 12kV 2 Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V Sub-packaging volume 0,22 dm³ UL 94 flammability rating V-0 Sub-packaging description Carton tray 10,50 g Sub-packaging quantity 10 Pcs Weight Sub-packaging EAN barcode 8015747182539 Part number CX 02 7M Notes the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support
CX027M 价格&库存
很抱歉,暂时无法提供与“CX027M”相匹配的价格&库存,您可以联系我们找货
