CX02BMCX01BM
CX02BMCX01BM
    ILME
    ILME - CX02BMCX01BM - Heavy Duty Connector, MIXO Series, Insert, 2 Contacts, Plug, Crimp Pin - Conta...
CX02BMCX01BM 数据手册
Part number CX 02 BM Brief description: male insert, seat for shielded connectors, 50V, 0,8kV, 3, two seats for shielded connectors, 2 modules, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version seat for shielded connectors Quality mark Product type two seats for shielded connectors Family MIXO series, customizable inserts Size 2 modules Technical data Conformity EN 61984:2009-06 EAC CQC General ordering information EAN13 code 8015747095938 Tariff number 85369095 Voltage 50 V Rated impulse withstand voltage 0,8 kV Packaging length 350,00 mm Pollution degree 3 Packaging height 105,00 mm Packaging width 145,00 mm Packaging weight 1,06 kg Packaging volume 5,33 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221054 Sub-packaging length 35,00 mm Sub-packaging height 40,00 mm Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Packaging Information Characteristics according to EN 61984 50V 0.8kV 3 Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 50V Sub-packaging width 155,00 mm UL 94 flammability rating V-0 Sub-packaging weight 0,09 kg Weight 12,60 g Sub-packaging volume 0,22 dm³ Sub-packaging description Carton tray Sub-packaging quantity 5 Pcs Sub-packaging EAN barcode 8015747095945 Part number CX 02 BM Catalogue drawings Notes CX 02 B inserts: - characteristics according to EN 61984: (50V 0,8kV 3) the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Part number CX 01 BM Brief description: male insert, 1 pole + shield, shielded connectors, 10A 50V, 0,8kV, 3, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version shielded connectors Quality mark Product type for male contacts 10A Style one contacts seat + shield Family MIXO series, customizable inserts N. of poles 1 pole + shield Technical data Current 10 A (A.C. and D.C.) Voltage 50 V Rated impulse withstand voltage Conformity EN 61984:2009-06 , DNV GL CQC General ordering information EAN13 code 8015747137232 Tariff number 85369095 Packaging Information Packaging weight 0,30 kg Packaging description Carton box 0,8 kV Packaging quantity 10 Pcs 3 Packaging EAN code 8015747137294 Sub-packaging length 185,00 mm Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm Sub-packaging weight 0,03 kg Further technical details Sub-packaging volume 1,15 dm³ Characteristics according to 10A 50V 0.8kV 3 EN 61984 Sub-packaging description Plastic bag Sub-packaging quantity 1 Pcs Pollution degree Operating temperature range -40°C … +70°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 26,00 g Sub-packaging EAN barcode 8015747137300 Part number CX 01 BM Catalogue drawings Notes CX 01 B inserts: - characteristics according to EN 61984: (10A 50V 0,8kV 3) the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support
CX02BMCX01BM 价格&库存
很抱歉,暂时无法提供与“CX02BMCX01BM”相匹配的价格&库存,您可以联系我们找货
