CDDM42
CDDM42
    ILME
    ILME - CDDM42 - Heavy Duty Connector, CDD Series, CDD Class, Insert, 42 Contacts, Plug
CDDM42 数据手册
Item code CDDM 42 Brief description: male insert, 42 poles + PE, crimp connections, 10A 250V, 4kV, 2, size "57.27", CLASS insert series Product description Approvals / Standards Model male insert Reference standard Version crimp connections Quality mark Series CDD Product type for male contacts 10A Family CLASS inserts Size size "57.27" Nº of poles 42 poles + Technical data Conformity EN 61984 (2001-11) , EAC CQC, CE General ordering information EAN code 8015747014113 Tariff number 85369095 Country of origin Made in EU (IT) ETIM classification EC000438 Current 10 A Packaging Information Voltage 250 V Packaging length 210,00 mm Sustained impulse voltage 4kV Packaging height 130,00 mm Pollution degree 2 Packaging width 240,00 mm Packaging weight 2,00 kg Packaging volume 6,55 dm³ Packaging description Carton box Packaging quantity 30 Pcs Packaging EAN code 8015747014120 Sub-packaging weight 0,33 kg Operating temperature range -50°C … +70°C (min, max) Plugging cycles ≥ 200 IP degree of protection IP20 without enclosure; IP65/IP66/IP67/IP68 with enclosure Connection type PE Screw Stripping length PE connection 7 mm Sub-packaging description Carton Wire cross section PE 0,14 - 4 mm2; AWG 20 - 12 Sub-packaging quantity 5 Pcs Tightening torque for PE connection (screwdriver) Sub-packaging EAN barcode 8015747014137 M4: 1,2 Nm, 10,6 lb,in (Ph2 or 1,0x5,5mm ) Other technical details Characteristics according to EN61984 10A 250V 4kV 2 Insulation resistance ≥ 1 GΩ Contact resistance ≤ 3 mΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Tightening torque for fixing screws (screwdriver) M3: 0.5 Nm; 4.4 lb.in (Ph1 or 0.8x4 mm) Weight 45,00 g Item code CDDM 42 Catalogue drawings Catalogue drawings
CDDM42 价格&库存
很抱歉,暂时无法提供与“CDDM42”相匹配的价格&库存,您可以联系我们找货
