CDDF108
CDDF108
    ILME
    ILME - CDDF108 - Heavy Duty Connector, CDD Series, CDD Class, Insert, 108 Contacts, Receptacle
CDDF108 数据手册
Item code CDDF 108 Brief description: female insert, 108 poles + PE, crimp connections, 10A, 250V, 4kV, 2, size "104.27", CLASS insert series Product description Approvals / Standards Model female insert Reference standard Version crimp connections Quality mark Series CDD Product type for female contacts 10A Family CLASS inserts Size size "104.27" Nº of poles 108 poles + Technical data Conformity EN 61984 (2001-11) , EAC CQC, CE General ordering information EAN code 8015747013598 Tariff number 85369095 Country of origin Made in EU (IT) ETIM classification EC000438 Current 10 A Packaging Information Voltage 250 V Packaging length 210,00 mm Sustained impulse voltage 4kV Packaging height 130,00 mm Pollution degree 2 Packaging width 240,00 mm Packaging weight 2,37 kg Packaging volume 6,55 dm³ Packaging description Carton box Packaging quantity 30 Pcs Packaging EAN code 8015747013604 Sub-packaging weight 0,40 kg Operating temperature range -40°C … +125°C (min, max) Plugging cycles ≥ 500 IP degree of protection IP20 without enclosure; IP65/IP66/IP67/IP68 with enclosure Connection type PE Screw Stripping length PE connection 7 mm Sub-packaging description Carton Wire cross section PE 0,14 - 4 mm2; AWG 20 - 12 Sub-packaging quantity 5 Pcs Tightening torque for PE connection (screwdriver) Sub-packaging EAN barcode 8015747013611 M4: 1,2 Nm, 10,6 lb,in (Ph2 or 1,0x5,5mm ) Other technical details Characteristics according to EN61984 10A 250V 4kV 2 Insulation resistance ≥ 10 GΩ Contact resistance ≤ 3 mΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Blade size for main contact 6 - 8 mm Tightening torque for fixing screws (screwdriver) M3: 0.5 Nm; 4.4 lb.in (Ph1 or 0.8x4 mm) Weight 80,00 g Item code CDDF 108 Catalogue drawings Catalogue drawings
CDDF108 价格&库存
很抱歉,暂时无法提供与“CDDF108”相匹配的价格&库存,您可以联系我们找货
