CX01YPEM
CX01YPEM
    ILME
    ILME - CX01YPEM - Heavy Duty Connector, MIXO Series, Insert, 1+PE Contacts, Plug, Crimp Pin - Contac...
CX01YPEM 数据手册
Part number CX 01 YPEM Brief description: male insert, 1 pole PE, crimp connections, 200A V, 200A male crimp contacts, 2 modules, modular units series MIXO Product description Approvals / Standards Model male insert Version Crimp connection Product type 200A male crimp contacts Style PE module for earth termination Family MIXO series, customizable inserts Size 2 modules N. of poles 1 pole PE Technical data Current 200 A (A.C. and D.C.) Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Insulation resistance ≥ 10 GΩ Quality mark Conformity , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747168083 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm Packaging width 117,00 mm Packaging weight 0,19 kg Packaging volume 1,24 dm³ Packaging description Carton box Packaging quantity 5 Pcs Packaging EAN code 8015747168427 Sub-packaging weight 0,04 kg Sub-packaging description Plastic bag 1 Pcs Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Sub-packaging quantity Weight 39,00 g Sub-packaging EAN barcode 8015747168434 Part number CX 01 YPEM Catalogue drawings Notes - ambient temperature limit: -40 °C ... +125 °C - are made of self-extinguishing thermoplastic resin UL 94 V0 the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX01YPEM 价格&库存
很抱歉,暂时无法提供与“CX01YPEM”相匹配的价格&库存,您可以联系我们找货
