CX01YM
CX01YM
    ILME
    ILME - CX01YM - Heavy Duty Connector, MIXO Series, Insert, 1 Contact, Plug, Crimp Pin - Contacts Not...
CX01YM 数据手册
Part number CX 01 YM Brief description: male insert, 1 pole, crimp connections, 200A 1000V, 8kV, 3, 200A male crimp contacts, 2 modules, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version Crimp connection Quality mark Product type 200A male crimp contacts Family MIXO series, customizable inserts Size 2 modules N. of poles 1 pole Technical data Current 200 A (A.C. and D.C.) Voltage 1000 V Rated impulse withstand voltage Conformity EN 61984:2009-06 , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747168069 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm 8 kV Packaging width 117,00 mm 3 Packaging weight 0,20 kg Packaging volume 1,24 dm³ Packaging description Carton box Packaging quantity 5 Pcs Packaging EAN code 8015747168380 Further technical details Sub-packaging weight 0,04 kg Characteristics according to 200A 1000V 8kV 3; 200A 920/1600V 8kV 2 EN 61984 Sub-packaging description Plastic bag Sub-packaging quantity 1 Pcs Pollution degree Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 31,00 g Sub-packaging EAN barcode 8015747168397 Part number CX 01 YM Catalogue drawings Notes CX 01 Y inserts: - characteristics according to EN 61984: (200A 1000V 8kV 3) - 2 frame slots - rated voltage according to UL/CSA: 600V - insulation resistance: > 10 GOhm - ambient temperature limit: -40 °C ... +125 °C - are made of self-extinguishing thermoplastic resin UL 94 V0 - mechanical life: > 500 cycles - contact resistance: < 0,2 mOhm the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support
CX01YM 价格&库存
很抱歉,暂时无法提供与“CX01YM”相匹配的价格&库存,您可以联系我们找货
