CX01YPEF
CX01YPEF
    ILME
    ILME - CX01YPEF - Heavy Duty Connector, MIXO Series, Insert, 1+PE Contacts, Receptacle
CX01YPEF 数据手册
Part number CX 01 YPEF Brief description: female insert, 1 pole PE, crimp connections, 200A V, 200A female crimp contacts, 2 modules, modular units series MIXO Product description Approvals / Standards Model female insert Version Crimp connection Product type 200A female crimp contacts Style PE module for earth termination Family MIXO series, customizable inserts Size 2 modules N. of poles 1 pole PE Technical data Current 200 A (A.C. and D.C.) Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Insulation resistance ≥ 10 GΩ Quality mark Conformity , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747168076 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm Packaging width 117,00 mm Packaging weight 0,19 kg Packaging volume 1,24 dm³ Packaging description Carton box Packaging quantity 5 Pcs Packaging EAN code 8015747168403 Sub-packaging weight 0,04 kg Sub-packaging description Plastic bag 1 Pcs Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Sub-packaging quantity Weight 39,00 g Sub-packaging EAN barcode 8015747168410 Part number CX 01 YPEF Catalogue drawings Notes - ambient temperature limit: -40 °C ... +125 °C - are made of self-extinguishing thermoplastic resin UL 94 V0 the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX01YPEF
物料型号:CX 01 YPEF
器件简介:这是一个MIXO系列的模块化单元,包括200A的女性压接端子,用于接地终止的PE模块,具有可定制的插入件。
引脚分配:1个极点PE。
参数特性:能够承受200A的电流(交流和直流),工作温度范围从-40°C到+125°C,绝缘电阻至少为10GΩ,根据UL/CSA标准额定电压为600V,UL 94可燃性等级为V-0,重量为39.00克。
功能详解:该产品具有多种认证和标准,包括DNV GL、BV、EAC质量标志,CQC和CE合规性。
应用信息:适用于需要高电流承载能力和特定工作温度范围的应用。
封装信息:EAN13码为8015747168076,关税编号85369095。包装尺寸为长112mm、高95mm、宽117mm,包装重量为0.19kg,包装体积为1.24dm³,描述为纸盒,每箱5个单位,EAN码为8015747168403。次级包装为塑料袋,每个塑料袋1个单位,EAN码为8015747168410。
CX01YPEF 价格&库存
很抱歉,暂时无法提供与“CX01YPEF”相匹配的价格&库存,您可以联系我们找货
