CX027F
CX027F
    ILME
    ILME - CX027F - Heavy Duty Connector, MIXO Series, Insert, 2 Contacts, Receptacle
CX027F 数据手册
Part number CX 02 7F Brief description: female insert, 2 poles, crimp connections, 70A 1000V, 8kV, 3, 2 modules, modular units series MIXO Product description Approvals / Standards Model female insert Reference standard Version Crimp connection Quality mark Product type for 70A female contacts Family MIXO series, customizable inserts Size 1 module N. of poles 2 poles Technical data Current 70 A (A.C. and D.C.) Voltage 1000 V Rated impulse withstand voltage Conformity EN 61984:2009-06 , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747182454 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm 8 kV Packaging width 150,00 mm 3 Packaging weight 0,78 kg Packaging volume 3,51 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221146 Further technical details Sub-packaging length 35,00 mm Characteristics according to 70A 1000V 8kV 3; 70A 1600V 12kV 2 EN 61984 Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm Sub-packaging weight 0,13 kg Pollution degree Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V Sub-packaging volume 0,22 dm³ UL 94 flammability rating V-0 Sub-packaging description Carton tray 10,00 g Sub-packaging quantity 10 Pcs Weight Sub-packaging EAN barcode 8015747182522 Part number CX 02 7F Notes the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support
CX027F 价格&库存
很抱歉,暂时无法提供与“CX027F”相匹配的价格&库存,您可以联系我们找货
