CX25IFCIFD0.5
CX25IFCIFD0.5
    ILME
    ILME - CX25IFCIFD0.5 - Heavy Duty Connector, MIXO, Insert, 25 Contacts, Receptacle, Crimp Socket
CX25IFCIFD0.5 数据手册
Part number CX 25 IF Brief description: female insert, 25 poles, crimp connections, 4A 50V, 3, for 5A female contacts, 1 module, modular units series MIXO Product description Approvals / Standards Model female insert Reference standard Version Crimp connection Quality mark Product type for 5A female contacts Family MIXO series, customizable inserts Size 1 module N. of poles 25 poles Technical data Current 4 A (A.C. and D.C.) Voltage 50 V Pollution degree 3 Conformity EN 61984:2009-06 , DNV GL, BV, EAC Not applicable General ordering information EAN13 code 8015747148313 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm Packaging width 150,00 mm Packaging weight 2,00 kg Packaging volume 3,51 dm³ Packaging description Carton box Further technical details Packaging quantity 60 Pcs Characteristics according to EN 61984 5A 50V 10A 3 Packaging EAN code 8015747221351 Sub-packaging length 35,00 mm Insulation resistance ≥ 10 GΩ Sub-packaging height 40,00 mm Rated voltage according to UL/CSA 50V Sub-packaging width 155,00 mm UL 94 flammability rating V-0 Sub-packaging weight 0,33 kg Weight 9,00 g Sub-packaging volume 0,22 dm³ Sub-packaging description Carton tray Sub-packaging quantity 10 Pcs Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Sub-packaging EAN barcode 8015747148337 Part number CX 25 IF Notes Inserts CX 25 IF/M - characteristics according to EN 61984: 4A 50V 0.8kV 3 4A 160V 2.5kV 2 - insulation resistance: > 10 GOhm - ambient temperature limit: -40 °C ... +125 °C - are made of self-extinguishing thermoplastic resin UL 94 V0 - mechanical life: > 500 cycles - for crimp contacts CI series using: CIPZ D crimping tool CITP D turret head CIES insertion / removal tool - we recommend the use of CRF / CRM code pins - 1 frame slot the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Part number CIFD 0.5 Brief description: CI female contacts, 5A, gold plated, 0,33 mmq - 0,52 mmq, AWG 22 - 20 Product description Approvals / Standards Model female contacts Quality mark Version Crimp contacts CLASS series Conformity Series CI 4A contacts General ordering information Family crimp contacts EAN13 code 8015747176729 N. of poles 1 pole Tariff number 85369095 Technical data Not applicable Packaging Information Current 5A Packaging weight 0,29 kg Wire cross-section 0,33 mm² - 0,52 mm² Packaging description Carton box AWG size 26 - 22 Packaging quantity 1000 Pcs Contact type gold plated Packaging EAN code 8015747258609 Sub-packaging length 75,00 mm Further technical details Conductors stripping length 4 mm Sub-packaging height 89,00 mm Weight 0,22 g Sub-packaging width 110,00 mm Sub-packaging volume 0,73 dm³ Sub-packaging description Plastic bag Sub-packaging quantity 25 Pcs Sub-packaging EAN barcode 8015747044080 Part number CIFD 0.5 Catalogue drawings
CX25IFCIFD0.5 价格&库存
很抱歉,暂时无法提供与“CX25IFCIFD0.5”相匹配的价格&库存,您可以联系我们找货
