CX08CM
CX08CM
    ILME
    ILME - CX08CM - Heavy Duty Connector, MIXO Series, Insert, 8 Contacts, Plug, Crimp Pin - Contacts No...
CX08CM 数据手册
Part number CX 08 CM Brief description: male insert, 8 poles, crimp connections, 16A, 400V, 6kV, 3, 1 module, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version Crimp connection Quality mark Product type for male contacts 16A Family MIXO series, customizable inserts Size 1 module N. of poles 8 poles Technical data Current 16 A (A.C. and D.C.) Voltage 400 V Rated impulse withstand voltage Pollution degree , EAC CQC, CE General ordering information EAN13 code 8015747129220 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm 6 kV Packaging width 150,00 mm 3 Packaging weight 0,71 kg Packaging volume 3,51 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221306 Sub-packaging length 35,00 mm Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm Sub-packaging weight 0,12 kg Operating temperature range -40°C … +125°C (min, max) IP degree of protection Conformity EN 61984:2009-06 IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Characteristics according to EN 61984 16A 400V 6kV 3; 16A 400/690V 6kV 2 Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V Sub-packaging volume 0,22 dm³ UL 94 flammability rating V-0 Sub-packaging description Carton tray Weight 8,60 g Sub-packaging quantity 10 Pcs Sub-packaging EAN barcode 8015747129251 Part number CX 08 CM Catalogue drawings Notes CX 08 C inserts: - characteristics according to EN 61984: (16A 400V 6kV 3) (16A 400/690V 6kV 2) - footprint 1 modules - for maximum current load, see the insert load curve section - for contact crimping instructions, please see the crimping tool section (16A contacts, CCF, CCM and CC...AN series) the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX08CM 价格&库存
很抱歉,暂时无法提供与“CX08CM”相匹配的价格&库存,您可以联系我们找货
