CDSHF09
CDSHF09
    ILME
    ILME - CDSHF09 - Heavy Duty Connector, CDSH Series, CDSH Class Series, Insert, 9 Contacts, Receptacl...
CDSHF09 数据手册
Item code CDSHF 09 Brief description: female insert, 9 poles, Spring connection contacts SQUICH, 10A, 400V, silver plated, size "44.27", CLASS inserts Product description Approvals / Standards Model female insert Reference standard Version Spring connection contacts SQUICH General ordering information Series CDSH EAN code 8015747222563 Product type with female contacts Tariff number 85369095 Family CLASS inserts Packaging Information Size size "44.27" Packaging length 245,00 mm Packaging height 165,00 mm Packaging width 215,00 mm Packaging weight 3,24 kg Packaging volume 8,69 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747222679 Sub-packaging length 197,00 mm Sub-packaging height 55,00 mm Sub-packaging width 113,00 mm 0,54 kg Nº of poles 9 poles + Technical data Current 10 A (A.C. and D.C.) Voltage 400 V Sustained impulse voltage 6kV Pollution degree 3 Wire section 0,14 mm² - 2,50 mm² AWG size 26 - 14 Operating temperature range -40°C … +125°C (min, max) EN 61984 (2001-11) Contact type silver plated Sub-packaging weight Plugging cycles ≥ 500 Sub-packaging volume 1,22 dm³ IP degree of protection IP20 without enclosure; IP65/IP66/IP67/IP68 with enclosure Sub-packaging description Carton Sub-packaging quantity 10 Pcs Wire cross section PE 0,14 - 4 mm2; AWG 20 - 12 Sub-packaging EAN barcode 8015747222686 Other technical details Insulation resistance ≥ 10 GΩ Weight 54,00 g Item code CDSHF 09 Notes actuator button connections Reopening
CDSHF09 价格&库存
很抱歉,暂时无法提供与“CDSHF09”相匹配的价格&库存,您可以联系我们找货
