CXM4/0
CXM4/0
    ILME
CXM4/0 数据手册
Part number CXM 4/0 Brief description: male insert, 4 poles + PE, screw terminal connection, 80A, 830V, size "77.27", CLASS inserts Product description Approvals / Standards Model male insert Reference standard Version screw terminal connections Quality mark Series CX Product type with male contacts Family CLASS inserts Size size "77.27" N. of poles 4 poles + Technical data Conformity EN 61984:2009-06 DNV-GL, EAC CQC, CE General ordering information EAN13 code 8015747042581 Tariff number 85369095 Country of origin Made in EU (IT) ETIM classification EC000438 Current 80 A (A.C. and D.C.) Packaging Information Voltage 830 V Packaging length 245,00 mm Rated impulse withstand voltage 8 kV Packaging height 165,00 mm Packaging width 215,00 mm Pollution degree 3 Packaging weight 3,82 kg Wire cross-section 4,00 mm² - 16,00 mm² Packaging volume 8,69 dm³ AWG size 12 - 6 Packaging description Carton box Packaging quantity 30 Pcs Packaging EAN code 8015747191821 Sub-packaging length 87,00 mm Sub-packaging height 36,00 mm Sub-packaging width 180,00 mm Further technical details Sub-packaging weight 0,64 kg Characteristics according to EN 61984 Sub-packaging volume 0,56 dm³ 80A 830V 8kV 3 Sub-packaging description Carton tray Insulation resistance ≥ 10 GΩ Sub-packaging quantity 5 Pcs Contact resistance ≤ 0.3 mΩ Sub-packaging EAN barcode 8015747042598 Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 113,50 g Operating temperature range -40°C … +125°C (min, max) Contact type silver plated Mating cycles ≥ 500 IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Part number CXM 4/0 Catalogue drawings Derating curves
CXM4/0 价格&库存
很抱歉,暂时无法提供与“CXM4/0”相匹配的价格&库存,您可以联系我们找货
