CDFD0.3
CDFD0.3
    ILME
    ILME - CDFD0.3 - HEAVY DUTY CONTACT, SOCKET, CRIMP, 22AWG
CDFD0.3 数据手册
Item code CDFD 0.3 Brief description: 10A CD contacts, gold plated, 0,14mmq - 0,37mmq, AWG 26 - 22 Product description Approvals / Standards Model female contacts Version Crimp contacts CLASS series Series 10A CD contacts Family crimp contacts Nº of poles 1 pole Technical data Current 10 A Wire section 0,14 mm² - 0,37 mm² AWG size 26 - 22 Quality mark Conformity , EAC CQC, CE General ordering information EAN code 8015747014809 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm Packaging width 117,00 mm Packaging weight 1,31 kg Packaging volume 1,24 dm³ Other technical details Packaging description Carton box Weight Packaging quantity 1600 Pcs Packaging EAN code 8015747206808 Sub-packaging length 50,00 mm Sub-packaging height 44,00 mm Sub-packaging width 50,00 mm Sub-packaging weight 0,16 kg Sub-packaging volume 0,11 dm³ Sub-packaging description Plastic box Sub-packaging quantity 200 Pcs Operating temperature range -40°C … +125°C (min, max) Contact type gold plated 0,82 g Sub-packaging EAN barcode 8015747014816 Item code CDFD 0.3 Catalogue drawings
CDFD0.3
物料型号:CDFD 0.3
器件简介: - 型号:女性接触件 - 版本:Crimp contacts CLASS系列 - 系列:10A CD接触件 - 家族:压接接触件 - 极数:1极 - 技术数据: - 电流:10A - 导线截面:0.14mm²-0.37mm² - AWG尺寸:26-22 - 工作温度范围:-40°C... +125°C - 接触类型:镀金 - 重量:0.82g
认证/标准: - 质量标志:EAC CQC, CE
一般订购信息: - EAN码:8015747014809 - 关税编号:85369095
包装信息: - 包装长度:112.00 mm - 包装高度:95.00 mm - 包装宽度:117.00 mm - 包装重量:1.31kg - 包装体积:1.24dm² - 包装描述:纸盒 - 包装数量:1600件 - 包装EAN码:8015747206808
子包装信息: - 子包装长度:50.00 mm - 子包装高度:44.00 mm - 子包装宽度:50.00 mm - 子包装重量:0.16kg - 子包装体积:0.11dm² - 子包装描述:塑料盒 - 子包装数量:200件 - 子包装EAN条码:8015747014816
目录图纸: - CDM - DA 03,2 - B - 25 - 01.6 - 21.6 - 4 - B - 03,5 - OA - CDF
CDFD0.3 价格&库存
很抱歉,暂时无法提供与“CDFD0.3”相匹配的价格&库存,您可以联系我们找货
