CDMA1.5
CDMA1.5
    ILME
    ILME - CDMA1.5 - Heavy Duty Connector Contact, CD, Pin, 16 AWG, Crimp, 10 A
CDMA1.5 数据手册
Item code CDMA 1.5 Brief description: 10A CD contacts, silver plated, 1,50mmq, AWG 16 Product description Approvals / Standards Model male contacts Version Crimp contacts CLASS series Series 10A CD contacts Family crimp contacts Nº of poles 1 pole Technical data Current 10 A Wire section 1,50 mm² AWG size 16 Quality mark Conformity , EAC CQC, CE General ordering information EAN code 8015747015400 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm Packaging width 117,00 mm Packaging weight 1,17 kg Packaging volume 1,24 dm³ Other technical details Packaging description Carton box Contact resistance ≤ 0,3 mΩ Packaging quantity 1600 Pcs Blade size for main contact 100A: 15mm; 16A: 7,5mm Packaging EAN code 8015747104050 Weight 0,73 g Sub-packaging length 50,00 mm Sub-packaging height 44,00 mm Sub-packaging width 50,00 mm Sub-packaging weight 0,15 kg Sub-packaging volume 0,11 dm³ Sub-packaging description Plastic box Sub-packaging quantity 200 Pcs Operating temperature range -40°C … +125°C (min, max) Contact type silver plated Sub-packaging EAN barcode 8015747015417 Item code CDMA 1.5 Catalogue drawings
CDMA1.5
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40至85度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1x3.6mm。
CDMA1.5 价格&库存
很抱歉,暂时无法提供与“CDMA1.5”相匹配的价格&库存,您可以联系我们找货
