CX12DF
CX12DF
    ILME
    ILME - CX12DF - Heavy Duty Connector, MIXO, Insert, 12 Contacts, Receptacle, Crimp Socket - Contacts...
CX12DF 数据手册
Part number CX 12 DF Brief description: female insert, 12 poles, crimp connection, 10A, 250V, 1 module, modular units MIXO series Product description Approvals / Standards Model female insert Reference standard Version Crimp connection Quality mark Product type for female contacts 10A Family MIXO series, customizable inserts Size 1 module N. of poles 12 poles Technical data Current 10 A (A.C.) Voltage 250 V Rated impulse withstand voltage Pollution degree Conformity EN 61984:2009-06 DNV-GL, EAC CQC, CE General ordering information EAN13 code 8015747042048 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm 4 kV Packaging width 150,00 mm 3 Packaging weight 0,78 kg Packaging volume 3,51 dm³ Packaging description Carton box Operating temperature range -40°C … +125°C (min, max) Contacts material Silver plated, gold plated Packaging quantity 60 Pcs Mating cycles ≥ 500 Packaging EAN code 8015747221313 IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Sub-packaging length 35,00 mm Sub-packaging height 40,00 mm Sub-packaging width 155,00 mm Sub-packaging weight 0,13 kg Sub-packaging volume 0,22 dm³ Sub-packaging description Carton tray Sub-packaging quantity 10 Pcs Further technical details Characteristics according to EN 61984 10A 250V 4kV 3 Insulation resistance ≥ 10 GΩ Contact resistance ≤ 3 mΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 10,00 g Sub-packaging EAN barcode 8015747042055 Part number CX 12 DF Catalogue drawings Notes the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Derating curves
CX12DF 价格&库存
很抱歉,暂时无法提供与“CX12DF”相匹配的价格&库存,您可以联系我们找货
