CX05SHF
CX05SHF
    ILME
    ILME - CX05SHF - Heavy Duty Connector, MIXO Series, Insert, 5+PE Contacts, Receptacle, Spring Socket
CX05SHF 数据手册
Part number CX 05 SHF Brief description: female insert, 5 poles + PE, SQUICH® spring connection, 16 A, 400 V, 6 kV, 3, size 1 module, MIXO modular units Product description Approvals / Standards Model female insert Version SQUICH® Spring connection contacts Product type with female contacts Family MIXO series, customizable inserts Size 1 module N. of poles 5 poles + Technical data Quality mark , DNV GL, BV, EAC General ordering information EAN13 code 8015747263665 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm Packaging width 150,00 mm Current 16 A Packaging volume 3,51 dm³ Voltage 400 V Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747263672 Rated impulse withstand voltage 6 kV Pollution degree 3 Sub-packaging length 155,00 mm Wire cross-section 0,14 mm² - 2,50 mm² Sub-packaging height 48,00 mm AWG size 26 - 14 Sub-packaging width 35,00 mm Operating temperature range (min, max) -40°C … +125°C Sub-packaging volume 0,26 dm³ Contact material silver plated Mating cycles ≥ 500 IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Further technical details Characteristics according to EN 61984 16 A 400 V 6 kV 3 Insulation resistance ≥ 10 GΩ Contact resistance ≤ 3 mΩ Rated voltage according to 600 V UL/CSA UL 94 flammability rating UL 94V-0 Conductors stripping length 9...11 mm Weight 0,17 g Sub-packaging description Carton tray Sub-packaging quantity 10 Pcs Sub-packaging EAN barcode 8015747263689 Part number CX 05 SHF Catalogue drawings Notes the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Derating curves
CX05SHF 价格&库存
很抱歉,暂时无法提供与“CX05SHF”相匹配的价格&库存,您可以联系我们找货
