CDDM24
CDDM24
    ILME
    ILME - CDDM24 - Heavy Duty Connector, CDD Series, CDD Class, Insert, 24 Contacts, Plug
CDDM24 数据手册
Item code CDDM 24 Brief description: male insert, 24 poles +PE, crimp connections, 10A, 250V, 4kV, 2, size "44.27", CLASS insert series Product description Approvals / Standards Model male insert Reference standard Version crimp connections Quality mark Series CDD Product type for male contacts 10A Family CLASS inserts Size size "44.27" Nº of poles 24 poles + Technical data Conformity EN 61984 (2001-11) , EAC CQC, CE General ordering information EAN code 8015747013994 Tariff number 85369095 Country of origin Made in EU (IT) ETIM classification EC000438 Current 10 A Packaging Information Voltage 250 V Packaging length 210,00 mm Sustained impulse voltage 4kV Packaging height 130,00 mm Pollution degree 2 Packaging width 240,00 mm Packaging weight 2,90 kg Packaging volume 6,55 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747014007 Sub-packaging weight 0,48 kg Operating temperature range -50°C … +70°C (min, max) Plugging cycles ≥ 200 IP degree of protection IP20 without enclosure; IP65/IP66/IP67/IP68 with enclosure Connection type PE Screw Stripping length PE connection 7 mm Sub-packaging description Carton 0,14 - 4 mm2; AWG 20 - 12 Sub-packaging quantity 10 Pcs Wire cross section PE Tightening torque for PE connection (screwdriver) Sub-packaging EAN barcode 8015747014014 M4: 1,2 Nm, 10,6 lb,in (Ph2 or 1,0x5,5mm ) Other technical details Characteristics according to EN61984 10A 250V 4kV 2 Insulation resistance ≥ 1 GΩ Contact resistance ≤ 3 mΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Tightening torque for fixing screws (screwdriver) M3: 0.5 Nm; 4.4 lb.in (Ph1 or 0.8x4 mm) Weight 40,00 g Item code CDDM 24 Catalogue drawings Catalogue drawings
CDDM24
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V-1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817的主要功能是发射红外线,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为5.7mm x 2.8mm。
CDDM24 价格&库存
很抱歉,暂时无法提供与“CDDM24”相匹配的价格&库存,您可以联系我们找货
