CQEM18
CQEM18
    ILME
    ILME - CQEM18 - Heavy Duty Connector, CQE Series, CQE Class Series, Insert, 18 Contacts, Plug
CQEM18 数据手册
Item code CQEM 18 Brief description: male insert, 18 poles + PE, crimp connections, 16A 500V, 6kV, 3, size "57.27", CLASS insert series Product description Approvals / Standards Model male insert Reference standard Version crimp connections Quality mark Series CQE Product type for male contacts 16A Family CLASS inserts Size size "57.27" Nº of poles 18 poles + Technical data Conformity EN 61984 (2001-11) , EAC CQC, CE General ordering information EAN code 8015747037181 Tariff number 85369095 Country of origin Made in EU (IT) ETIM classification EC000438 Current 16 A (A.C. and D.C.) Packaging Information Voltage 500 V Packaging length 210,00 mm Sustained impulse voltage 6kV Packaging height 130,00 mm Pollution degree 3 Packaging width 240,00 mm Packaging weight 1,80 kg Packaging volume 6,55 dm³ Packaging description Carton box Packaging quantity 30 Pcs Packaging EAN code 8015747208802 Sub-packaging weight 0,30 kg Sub-packaging description Carton 5 Pcs Operating temperature range -50°C … +70°C (min, max) Plugging cycles ≥ 200 IP degree of protection IP20 without enclosure; IP65/IP66/IP67/IP68 with enclosure Wire cross section PE 0,14 - 4 mm2; AWG 20 - 12 Other technical details Characteristics according to EN61984 16A 500V 6kV 3; 16A 830V 8kV 2 Sub-packaging quantity Insulation resistance ≥ 1 GΩ Sub-packaging EAN barcode 8015747037198 Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 50,00 g Item code CQEM 18 Catalogue drawings Catalogue drawings Notes CQEF/M 18 inserts: - characteristics according to EN 61984: (16A 500V 6kV 3) (16A 830V) 8kV 2) - rated voltage according to UL/CSA: 600V - insulation resistance: > 10 GOhm - ambient temperature limit: -40 °C ... +125 °C - are made of self-extinguishing thermoplastic resin UL 94 V0 - mechanical life: > 500 cycles - contact resistance: < 1 mOhm - for contact crimping instructions, please see the crimping tool section (16A contacts, CCF, CCM and CC...AN series) . - enclosures:size "57.27": C-TYPE IP65/IP66 C7 IP67 stainless steel lever V-TYPE IP65/IP66 stainless steel lever T-TYPE IP65 insulating JEI zinc-plated steel lever BIG hoods W-TYPE aggressive environments EMC central lever IP68 panel supports: page:COB
CQEM18 价格&库存
很抱歉,暂时无法提供与“CQEM18”相匹配的价格&库存,您可以联系我们找货
