CX02GM
CX02GM
    ILME
    ILME - CX02GM - Heavy Duty Connector, MIXO Series, Insert, 2 Contacts, Plug, Crimp Pin - Contacts No...
CX02GM 数据手册
Part number CX 02 GM Brief description: male insert, 2 poles, crimp connections, 100A 1000V, 8kV, 3, for male contacts 100A, 2 modules, modular units series MIXO Product description Approvals / Standards Model male insert Reference standard Version Crimp connection Quality mark Product type for male contacts 100A Family MIXO series, customizable inserts Size 2 modules N. of poles 2 poles Technical data EN 61984:2009-06 DNV-GL, EAC General ordering information EAN13 code 8015747122818 Tariff number 85369095 Packaging Information Packaging length 112,00 mm Packaging height 95,00 mm Packaging width 117,00 mm 8 kV Packaging weight 0,19 kg 3 Packaging volume 1,24 dm³ Packaging description Carton box Packaging quantity 5 Pcs Packaging EAN code 8015747122849 Sub-packaging weight 0,04 kg Further technical details Sub-packaging description Plastic bag Characteristics according to 100A 1000V 8kV 3 (100A 920/1600V 8kV 2) EN 61984 Sub-packaging quantity 1 Pcs Current 100 A (A.C. and D.C.) Voltage 1000 V Rated impulse withstand voltage Pollution degree Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Insulation resistance ≥ 10 GΩ Contact resistance ≤ 0,3 mΩ Rated voltage according to UL/CSA 600V UL 94 flammability rating V-0 Weight 28,80 g Sub-packaging EAN barcode 8015747122856 Part number CX 02 GM Catalogue drawings Notes the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX02GM 价格&库存
很抱歉,暂时无法提供与“CX02GM”相匹配的价格&库存,您可以联系我们找货
