CX3/4XDF
CX3/4XDF
    ILME
    ILME - CX3/4XDF - Heavy Duty Connector, MIXO Series, Insert, 3+4 Contacts, Receptacle
CX3/4XDF 数据手册
Part number CX 3/4 XDF Brief description: female insert, 3 poles, crimp connections, 40A 830V, (4 poles (10A max 830V/8kV/3)), 8kV, 3, for female contacts 40A and 10A, 1 module, modular units series MIXO Product description Approvals / Standards Model female insert Reference standard Version Crimp connection Quality mark Product type for female contacts 40A and 10A Family MIXO series, customizable inserts Size 1 module N. of poles 3 poles Auxiliary poles 4 poles (10A max - 830V/8kV/3) Technical data Conformity EN 61984:2009-06 , DNV GL, BV, EAC CQC, CE General ordering information EAN13 code 8015747176774 Tariff number 85369095 Packaging Information Packaging length 180,00 mm Packaging height 130,00 mm Packaging width 150,00 mm 8 kV Packaging weight 0,72 kg 3 Packaging volume 3,51 dm³ Packaging description Carton box Packaging quantity 60 Pcs Packaging EAN code 8015747221375 Sub-packaging length 35,00 mm Further technical details Sub-packaging height 40,00 mm Characteristics according to 40A 830V 8kV 3 (aux:10A 830V 8kV 3) EN 61984 Sub-packaging width 155,00 mm Sub-packaging weight 0,12 kg Sub-packaging volume 0,22 dm³ Current 40 A (A.C. and D.C.) Voltage 830 V Rated impulse withstand voltage Pollution degree Operating temperature range -40°C … +125°C (min, max) IP degree of protection IP20 without enclosure, IP65/IP66/IP68/IP69 with enclosure Insulation resistance ≥ 10 GΩ Rated voltage according to UL/CSA 600V Sub-packaging description Carton tray V-0 Sub-packaging quantity 10 Pcs 9,00 g Sub-packaging EAN barcode 8015747176781 UL 94 flammability rating Weight Part number CX 3/4 XDF Catalogue drawings Notes MIXO CX 3/4 X modular connectors: - Characteristcs according to EN 61984: 3 poles 40A 830V 8kV 3 4 poles 10A 830V 8kV 3 - male and female inserts protected from accidental contact. Finger proof (IP2X or IPXXB) upon connector unmated. the modular inserts must be installed in suitable frames which in turn are installed in traditional housings or COB panel support Catalogue drawings
CX3/4XDF 价格&库存
很抱歉,暂时无法提供与“CX3/4XDF”相匹配的价格&库存,您可以联系我们找货
