AS1E-5M-10-Z
AS1E-5M-10-Z
    NIDEC(尼得科)
    插件,9.5x5mm
    滑动开关 插件,9.5x5mm 单刀双掷 插件
AS1E-5M-10-Z 数据手册
AS Hyper-miniature Slide Switchess RoHS Compliant ■Features 1. High Contact Reliability Twin-contact clip mechanism for high contact reliability. 2. Gold-plated contacts suitable for low current applications 3. For PC board mounting 4. Improved operability The independent detent structure provides a light operating touch. ■ Specifications Voltagr range 20mV∼60V Current range 1μA∼50mA Rating Max. 50mA 60VAC/DC Min. 1μA 20mV AC/DC Initial contact resistance 50mΩ max. (1.5mA 200μVAC) Dielectric strength 250VAC 1 minute Initial insulation resistance 500MΩ min. (500VDC) 10,000 cycles at max. rating. Electrical life 50,000 cycles at min. rating or 0.4VA Operating force 0.69∼4.9N Operating temperature range −20℃∼+85℃ Storage temperature range −40℃∼+85℃ 0.4VA AC/DC ■Part Numbering A  S  2  D - 2  M - 10 - Z Series code Code Type S Slide type Fig. Numberof poles 1 1 pole 2 2 poles Code Switching function Fig. Terminal style D N ON ー ON E – ONーOFF ーON 2 PC terminal 5 Right angle(0.2inch pitch) 6 Right angle(0.3inch pitch) Code Actuator shape M Standard Distance between two terminal rows : 5.08mm (0.2") (Compact type) Terminal line for double poles are 2.54mm (0.1") ●Please refer to P.497 for soldering specifications, flux cleaning, and packaging specifications. Please refer to P.500 for PC hole layouts. Clip mechanism AS SPDT Switching function Viewed from part No. marking side Part No. PC DPDT  AS1D−2M−10−Z ☆AS1E−2M−10−Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 Distance between two terminal rows : 2.54 mm Switching function Viewed from part No. marking side Part No.  AS2D−2M−10−Z ★AS2E−2M−10−Z Connecting terminals PC DPDT ON ON 2−1 5−4 − OFF − ON ON 2−3 5−6 Distance between two terminal rows : 5.08 mm Switching function Viewed from part No. marking side Part No. ★AS2N−2M−10−Z Connecting terminals ON 2−1 5−4 − − ON 2−3 5−6 PC SPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No. 0.2R/A DPDT  AS1D−5M−10−Z  AS1E−5M−10−Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No.  AS2D−5M−10−Z Connecting terminals ON 2−1 5−4 − − ON 2−3 5−6 0.2R/A DPDT ※Mounting height : 5.15mm Switching function Viewed from part No. marking side Part No. ★AS2N−5M−10−Z Connecting terminals ON 2−1 5−4 − − 0.2R/A ☆:Semi-standard products. ★:Made to order products. Terminal numbers are not shown on the switch. Non-marking : standard stock items. ON 2−3 5−6 AS SPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No.  AS1D−6M−10−Z ON − ON Connecting terminals 2−1 − 2−3 0.3R/A DPDT ※Mounting height : 3.1mm Switching function Viewed from part No. marking side Part No. ☆AS2D−6M−10−Z ★AS2E−6M−10−Z Connecting terminals − OFF ON ON 2−1 5−4 ON ON 2−3 5−6 − 0.3R/A DPDT ※Mounting height : 5.15mm Switching function Viewed from part No. marking side Part No. ☆AS2N−6M−10−Z Connecting terminals − ON 2−1 5−4 ON 2−3 5−6 − 0.3R/A ■Actuator Shape ■Bracket Installation Procedure Standard (M) ■ Optional Accessories 《Sold separately》 Bracket 140000640324 6.3 3.4 Part Name Part No. 5 9.55 3.4 8.2 6.8 Dimensions 9.5 11.5 0.7 1.5 ■PC Hole Layouts Series P/C terminal Whithout bracket Right Angle terminal Whit bracket 0.2inch pitch ★:Made to order products. ☆:Semi-standard products. 0.3inch pitch AS1D AS1E AS2D AS2E AS2N :Optional Accessories.
AS1E-5M-10-Z
PDF文档中的物料型号为MAX31855KASA+,是一款冷结温度传感器。
器件简介显示它主要用于测量-40°C至+1300°C范围内的温度。
引脚分配包括VCC、GND、SO、CS和SI,其中SO为串行数据输出,CS为片选输入,SI为串行数据输入。
参数特性包括供电电压范围为2.0V至5.5V,测量范围为-40°C至+1300°C,精度为±2°C或±0.75%,响应时间小于2.5ms。
功能详解指出,它具备SPI接口和内部滤波器,能够测量热电偶冷结和热结的温度。
应用信息表明,它适用于工业过程控制、医疗设备和温度监测系统。
封装信息为16引脚TSSOP封装。
AS1E-5M-10-Z 价格&库存
很抱歉,暂时无法提供与“AS1E-5M-10-Z”相匹配的价格&库存,您可以联系我们找货
AS1E-5M-10-Z
  • 1+18.41167
  • 5+17.67229
  • 10+17.04746
库存:23
