1/1 Page
Execution date : 2020-01-29
Administration number : 44709526460
Drawing number : EL09B2A2121
To English
Able reducer
Specification sheet
Reducer model
EVL-090B-5-K6-14CA14
(Shaft with key)
1.Reducer specification
Ratio
Backlash
Allowable nominal torque
Allowable maximum torque
Allowable average input speed
Allowable maximum input speed
Allowable radial load
(Applied to the output shaft center.)
Allowable axial load
(Applied to the output side bearing.)
Approx. weight
Moment of inertia
Lubrication type
Color of the paint
Powered by TCPDF (www.tcpdf.org)
5
6 arc-min
65 Nm
90 Nm
3000 rpm
6000 rpm
960 N
1200 N
4.9 kg
1.80 kg·cm2
Grease
Silver
*The actual appearance might be different.
EVL090C-5-K6-14CA14 价格&库存
很抱歉,暂时无法提供与“EVL090C-5-K6-14CA14”相匹配的价格&库存,您可以联系我们找货
