EVL090C-5-K6-19EB19
EVL090C-5-K6-19EB19
    NIDEC(尼得科)
    CONTROL TECHNIQUES - EVL090C-5-K6-19EB19 - Gearbox, R/A Planetary, Helical Planetary, 5:1, 90 N-m, 3...
EVL090C-5-K6-19EB19 数据手册
1/1 Page Execution date : 2020-01-30 Administration number : 44709529290 Drawing number : EL09B2A3071 To English Able reducer Specification sheet Reducer model EVL-090B-5-K6-19EB19 (Shaft with key) 1.Reducer specification Ratio Backlash Allowable nominal torque Allowable maximum torque Allowable average input speed Allowable maximum input speed Allowable radial load (Applied to the output shaft center.) Allowable axial load (Applied to the output side bearing.) Approx. weight Moment of inertia Lubrication type Color of the paint Powered by TCPDF (www.tcpdf.org) 5 6 arc-min 65 Nm 90 Nm 3000 rpm 6000 rpm 960 N 1200 N 4.9 kg 2.13 kg·cm2 Grease Silver *The actual appearance might be different.
EVL090C-5-K6-19EB19 价格&库存
很抱歉,暂时无法提供与“EVL090C-5-K6-19EB19”相匹配的价格&库存,您可以联系我们找货
