EVL120C-10-K6-28GD24
    NIDEC(尼得科)
    CONTROL TECHNIQUES - EVL120C-10-K6-28GD24 - Gearbox, R/A Planetary, Helical Planetary, 10:1, 200 N-m...
EVL120C-10-K6-28GD24 数据手册
1/1 Page Execution date : 2020-01-30 Administration number : 44712553270 Drawing number : EL12B2A4073 To English Able reducer Specification sheet Reducer model EVL-120B-10-K6-28GD24 (Shaft with key) 1.Reducer specification Ratio Backlash Allowable nominal torque Allowable maximum torque Allowable average input speed Allowable maximum input speed Allowable radial load (Applied to the output shaft center.) Allowable axial load (Applied to the output side bearing.) Approx. weight Moment of inertia Lubrication type Color of the paint Powered by TCPDF (www.tcpdf.org) 10 6 arc-min 110 Nm 200 Nm 3000 rpm 6000 rpm 2000 N 2500 N 10.2 kg 6.05 kg·cm2 Grease Silver *The actual appearance might be different.
EVL120C-10-K6-28GD24 价格&库存
很抱歉,暂时无法提供与“EVL120C-10-K6-28GD24”相匹配的价格&库存,您可以联系我们找货
