ATE
Washable
Subminiature Toggle Switch
RoHS Compliant
UL
■Features
■ Specifications
1. Twin-contact clip mechanism for high reliability.
2. Process sealed structure
3. Gold-plated contacts.
4. Terminal pin pitch: 2.54 mm.
5. Independent detent mechanism ensures light
operational feel.
6. UL recognized (Excluding ATE-J series with
plastic cap/rocker)
Rating
Max.
Min.
50mA 60VAC/DC 0.4VA AC/DC
1μA 20mVAC/DC
UL
48VAC/DC 50mA
Initial contact resistance
50mΩ Max.
Insulation resistance
500MΩ min.
Dielectric strength
250VAC 1 minute
(1.5mA 200μVAC)
(500VDC)
10,000 cycles at 0.4VA rating.
50,000 cycles at 0.4VA rating.(D.E type)
30,000 cycles at 0.4VA rating.(F.G.H type)
Electrical life
D.E type 50,000 cycles
F.G.H type 30,000 cycles
Mechanical life
Operating
temperature range
Storage
temperature range
−20℃∼+85℃
−40℃∼+85℃
■Part Numbering
A TE 2 D - 2 M 3 - 10 - Z
Series code
Actuator shape Number of poles
Switching function
Code Switching function
Code
Type
Fig.
Number
of poles
TE
Toggle type
1
1 pole
D
2
2 poles
F
Terminal style
Actuator shape
Bracket style
Code Actuator shape
Fig.
Terminal style
2
PC Straight
M
Standard
ー (ON)
5
Right angle
(0.2 inch pitch)
F
Flat toggle
G (ON)ーOFFー(ON)
6
Right angle
(0.3 inch pitch)
E
H
ON
ー
ON
ONーOFF ーON
ON
Clip mechanism
Fig.
Bracket
3
Without bracket
ONーOFFー(ON)
Compact type
Space between terminal rows (Double pole): 2.54 mm
(ON)
:Momentary.
ATE
■Right Angle Terminals
(0.2-inch pich)
(0.3-inch pich)
●The space between the terminal rows are
available in two dimensions: 0.2 inches (5.08
mm) and 0.3 inches (7.62 mm).
1-pole
[Example] 0.2-inch pitch: ATE1D-5M3-10-Z
0.3-inch pitch: ATE1D-6M3-10-Z
2-poles
0.2 R/A
Type
ATE−2M・5M・6M
Part name
Color Cap
0.3 R/A
■Optional Accessories
Gloss finish
Refer to P.371 for PC Hole Layouts.
Bracket
Part name
Poles
Single pole
Box size
5 mm
Double poles
Dimensions
7.5 mm
5 mm
ATE-2M・2F
Type
Vinyl chloride
4.12
4.12
4.12
Dimensions
140000640314
Part number
SPDT
140000640315
0.6
2.54 2.54
26゚
9.5
6
8
4
(2)
140000470173
Gray
140000470179
Viewed from part No. marking side
(1)
3.3
0.3
ATE1D-2M3-10-Z
ATE1E-2M3-10-Z
ATE1F-2M3-10-Z
ATE1G-2M3-10-Z
☆ATE1H-2M3-10-Z
ON
ON
ON
(ON)
ON
OFF
OFF
OFF
ON
ON
(ON)
(ON)
(ON)
Connecting terminals
2−3
2−1
Distance between two terminal rows : 2.54mm
5
φ4
Switching
function
2.54 2.54
0.6
Part number marking side
26゚
9.5
Black
Part No.
Terminal numbers are not shown on the switch.
φ2.5
140000470175
φ2.5
PC Straight
Red
Switching
function
5
φ4
(3)
DPDT
140000470174
140000640318
Standard Toggle
PC Straight
White
6
4
8
3.3
(6)
(3)
(5)
(2)
(4)
(1)
Part No.
ATE2D-2M3-10-Z
☆ATE2E-2M3-10-Z
☆ATE2G-2M3-10-Z
0.3
2.54
ON
ON
(ON)
2−3
5−6
★:Made to order products.
☆:Semi-standard products.
(ON)
:Momentary.
:Optional Accessories.
OFF
OFF
ON
ON
(ON)
2−1
5−4
ATE
(Mounting height : 3.1mm)
6
4
(0.7)
8
5.6
(3)
(2)
(1)
26゚
9.5
Part No.
0.7
3.1
φ2.5
ATE1D-5M3-10-Z
☆ATE1E-5M3-10-Z
☆ATE1G-5M3-10-Z
★ATE1H-5M3-10-Z
ON
ON
(ON)
ON
OFF
OFF
OFF
ON
ON
(ON)
(ON)
2−3
2−1
0.3
Switching
function
4
6
8
5.6
(2.9)
(3)
(1)
(2)
(5) (6)
(4)
26゚
9.5
Part No.
0.7
3.1
☆ATE2D-5M3-10-Z
☆ATE2G-5M3-10-Z
φ2.5
Switching
function
4
8
(0.7)
(2)
(1)
9.5
Part No.
0.7
3.1
φ2.5
Partnumbermarkingside
OFF
ON
(ON)
2−1
5−4
0.4
7.62
3.3
(3)
5.6
0.6
6
2.54 2.54
5
φ4
1.5
Right angle(0.3 inch pitch)
ON
(ON)
2−3
5−6
0.3
0.3
5.08 2.54
26゚
SPDT
0.4
3.3
0.6
5
φ4
1.8
Right angle(0.2 inch pitch)
2.54 2.54
DPDT
0.4
5.08
3.3
0.6
5
φ4
1.8
Switching
function
2.54 2.54
SPDT
0.3
(ON)
:Momentary.
ATE1D-6M3-10-Z
ATE1E-6M3-10-Z
ATE1F-6M3-10-Z
☆ATE1G-6M3-10-Z
☆ATE1H-6M3-10-Z
ON
ON
ON
(ON)
ON
OFF
OFF
OFF
ON
ON
(ON)
(ON)
(ON)
2−3
2−1
ATE
DPDT
(2.9)
8
(3)
(2)
(6)
(4)
(1)
(5)
26゚
9.5
Switching
function
3.3
5.6
0.6
4
1.5
6
2.54 2.54
5
φ4
Part No.
ATE2D-6M3-10-Z
0.7
ON
2−3
5−6
ON
2−1
5−4
φ2.5
0.4
SPDT
0.3
7.62
0.3
2.54
Switching
function
Flat Toggle
PC Straight
5
φ4
φ2.7
(3)
2.54 2.54
26゚
9.5
0.6
4
10
4
8
3.3
(2)
(1)
0.3
☆:Semi-standard products. (ON)
:Momentary.
Part No.
ATE1D-2F3-10-Z
ATE1E-2F3-10-Z
ON
ON
OFF
ON
ON
2−3
2−1
ATE
DPDT
(Space between terminal rows (Double pole): 2.54 mm)
PC Straight
5
φ4
Switching
function
2.54 2.54
4
26゚
9.5
0.6
4
10
φ2.7
8
(6)
(3)
(5)
(2)
(4)
(1)
0.3
3.3
Part No.
☆ATE2D-2F3-10-Z
☆ATE2G-2F3-10-Z
ON
(ON)
2−3
5−6
OFF
ON
(ON)
2−1
5−4
2.54
SPDT
5
φ4
Switching
function
4
8
(0.7)
5.6
2.54 2.54
(2)
(1)
9.5
26゚
Part No.
0.7
4
3.1
3.3
(3)
1.8
10
0.6
(ON)
ON
OFF
OFF
(ON)
(ON)
2−3
2−1
φ2.7
★ATE1G-5F3-10-Z
★ATE1H-5F3-10-Z
DPDT
0.4
5.08
0.3
4
8
5.6
(2.9)
(3)
(2)
(6)
(4)
(1)
(5)
26゚
9.5
0.7
4
3.3
Part No.
2.54 2.54
10
Switching
function
0.6
5
φ4
1.8
3.1
★ATE2D-5F3-10-Z
ON
2−3
5−6
ON
2−1
5−4
φ2.7
0.4
0.3
0.3
5.08 2.54
(ON)
:Momentary.
ATE
SPDT
4
8
(0.7)
5.6
(3)
(2)
(1)
26゚
9.5
Part No.
0.7
4
3.1
3.3
1.5
10
Switching
function
0.6
5
φ4
2.54 2.54
☆ATE1G-6F3-10-Z
(ON)
OFF
(ON)
2−3
2−1
φ2.7
DPDT
0.4
7.62
0.3
8
5.6
(2.9)
(4) (5) (6)
26゚
9.5
0.7
4
3.1
φ2.7
0.4
(ON)
:Momentary.
0.3
0.3
7.62
2.54
3.3
Part No.
0.6
4
1.5
10
Switching
function
2.54 2.54
5
φ4
(1) (2) (3)
☆ATE2D-6F3-10-Z
ON
2−3
5−6
ON
2−1
5−4
ATE-J(Plastic type)
■Part Numbering
(Plastic cap・Rocker type)
A TE 1 D - 2 J 3 - 10 - Z
Series code
Code
Type
Fig.
Number
of poles
TE
Toggle type
1
1 pole
2
2 poles
Switching function
D
E
ON
ー
ON
ONーOFF ーON
Terminal style
Actuator shape
Fig.
Terminal style
2
P/C terminal
7
Vertical mounting
SPDT
Bracket style
Code Actuator shape
J
Plastic Knob type
Switching
function
PC Straight
Clip mechanism
Fig.
Bracket
3
Without bracket
Part No.
☆ATE1D-2J3-10-Z
★ATE1E-2J3-10-Z
ON
ON
OFF
ON
ON
2−3
2−1
Mount with CAP
●Color cap and Rocker accessories are
sold separately.
(ON)
:Momentary.
ATE−J
SPDT
Switching
function
Vertical mounting
Part No.
Mount with CAP
★ATE1D-7J3-10-Z
ON
ON
2−3
2−1
《Sold separately》
Type
ATE−2J・7J
ATE−2J・7J
Part name
Color Cap
Rocker
Matte finish
Matte finish
Dimensions
ABS resin
ABS resin
White
140000050884
140000481541
Red
140000050886
140000481543
Black
140000050885
140000481542
★:Made to order products. (ON)
:Momentary.
■Color Cap and Rocker
Installation Procedure for ATE−J type
ATE
■PC Hole Layouts
PC terminal
(Top voew)
Series code
ATE−2M・2F・2J
Installation
Whithout bracket
ATE−2M・2F
When optional bracket is used
140000640314
140000640315
140000640318
1−pole
2−poles
2.54mm
Tow terminal rows
Right Angle terminal・Vertical Mount terminal
(Top view)
Series code
ATE−5M・5F
ATE−6M・6F
ATE−7J
Terminal
R/A
0.2−inch pich
R/A
0.3−inch pich
Vertical mount
1−pole
2−poles
■Bracket Mounted Dimensions.
Type
Dimensions
ATE−2M
ATE−2F
Standard
Flat
ATE
■Soldering Specifications
■Flux Cleaning
⑴Manual Soldering
⑴Solvent : Fluorine or Alcohol type.
Device : Soldering iron
⑵Cleaning after soldering should be done after the terminal
380℃, Max.; 3 seconds, Max.
temperature falls to 90℃ or below, or after leaving the switch
⑵Auto Soldering
for five minutes or longer at room temperature.
Device : Jet wave type or dip type
275℃, Max.; 6 seconds, Max.
275
120
80
120
Pre-heating
S
6
Soldering
●Pre-heating should be done at temperatures ranging from 80℃
to 120℃ and within 120 seconds
⑶Install the cap/rocker accessory after soldering and cleaning.
■Packaging Specifications
■Mounting of Switch
Plastick Pack
PC terminals
: 100 pcs./pack
KU
15
SO
Plastick Pack
SO
JI
231
JI
●Do not bend the terminal pins before mounting the switch on
the PC board.
FU
FU
●Use PC boards with hole diameter of 1mm.
KU
196
Right angle terminals
: 50 pcs./pack
Vertical mounting terminals
100 pcs./pack
●After mounting the switch, do not place the device in such a
way that the device weight will be applied on to the actuator of
the switch.
●Do not apply load exceeding 12.7 N to the actuator.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nidec:
ATE1D-2F3-10-Z ATE1D-2J3-10-Z ATE1D-2M3-10-Z ATE1D-5M3-10-Z ATE1D-6M3-10-Z ATE1D-7J3-10-Z
ATE2D-5F3-10-Z ATE2D-5M3-10-Z ATE2D-6M3-10-Z ATE2E-2M3-10-Z ATE1F-6M3-10-Z ATE1G-2M3-10-Z
ATE1G-5M3-10-Z ATE1H-5M3-10-Z ATE2D-2F3-10-Z ATE2D-2M3-10-Z ATE1E-2F3-10-Z ATE1E-2J3-10-Z
ATE1E-2M3-10-Z ATE1E-5M3-10-Z ATE1E-6M3-10-Z ATE1F-2M3-10-Z
很抱歉,暂时无法提供与“ATE1E-2M3-10-Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+21.82741
- 5+20.99430
- 10+20.26533
- 国内价格 香港价格
- 1+24.949601+3.22050
- 10+22.6735010+2.92670
- 50+21.2728250+2.74590
- 国内价格
- 25+20.05705
- 50+19.32600
- 100+18.41583
- 250+17.50983
- 国内价格
- 1+31.37400
- 10+30.71520
- 30+30.27240
- 100+29.84040
