C200-01200017
C200-01200017
    NIDEC(尼得科)
    CONTROL TECHNIQUES - C200-01200017 - AC MOTOR DRIVE, 1-PH, 0.33HP, 240VAC
C200-01200017 数据手册
Commander C200 AC Drives Enhance throughput with machine safety, communications, and built-in PLC The Commander C200 delivers benchmark functionality at no added cost to the base drive itself. Plug-in options, dynamic performance, PLC functionality and other advanced features such as fieldbus, Ethernet, and Modbus RTU communications ensure that in more complex applications Commander C200 can deliver more than the average general purpose drive - giving you lower cost solutions and better productivity in your motor control applications. Enhance up-time and system flexibility • Flexible system integration and remote diagnostics through optional industrial Ethernet and fieldbus communication • Flexible I/O expandable with SI-I/O option module • Enhanced functionality and onboard PLC programming provides a low-cost system solution, minimizing the need for additional equipment such as PLCs High performance open-loop motor control • RFC-A (Rotor Flux Control) algorithm for exceptional induction motor control of demanding applications • Closed loop current control without a position feedback device • Speed control for conveyors, fans, pumps, and mixers, where their function is controlled remotely with fieldbus or Ethernet communications Key data Heavy Duty Ratings: Normal Duty Ratings: Supply phases: Commander C200 Frame Size 3 Voltage ratings 100 / 120 VAC ± 10% ü 200 / 240 VAC ± 10% ü 380 / 480 VAC ± 10% ü Control mode Open loop vector or V/Hz induction motor control Open loop Rotor Flux Control for induction motors (RFC-A) 0.33 hp to 150 hp (0.25 kW to 110 kW) 0.33 hp to 200 hp (0.25 kW to 132 kW) Frame size 1 and 2: 110 V drives 1Ø, 230 V drives 1Ø or 3Ø; Frame size 7 and larger 3Ø; 460 V drives 3Ø Control connections: 2x Analog inputs, 4x Digital inputs, 1x Analog output, 1x Digital I/O, 1x Relay Drive rating: IP21 / UL open class as standard Keypad: Fixed LED Option slots: 1 (frame size 2 and above) Parameter cloning via: PC tools, SD card ü ü How to select a drive (Consult online catalog for complete drive information) 1. Electrical Considerations • What is the supply voltage? • Single or 3Ø input power? • What is the motor rating? • Continuous current – FLA (Full Load Amps) • Select the drive based on motor Amps rather than horsepower 2. Load Type (choose one) • Normal Duty: Peak current is 110% of drive rating (fans, pumps, etc.) • Heavy Duty: Peak current is 180% (mixers, conveyors, etc.) 3. Drive Mechanical Mounting • Panel mounting – as standard • Wall mounting – UL conduit kits are available • Through panel mounting – frames 5 and up 900 SO 1 SIL3 I V Safety Integrity Level O 9002 E171230 L P RO IS AP AL Visit www.Drive-Setup.com for step by step guides, videos, software, product support documentation & 5 year warranty registration. COMMANDER C200 AC Drives for Industrial Applications Order Information & Ratings 115 VAC, Single Phase 50/60 Hz Input, 230 VAC 3-Phase Output Commander C200 Order Code* Input Phase C200-01100017A C200-01100024A C200-02100042A C200-02100056A 1 1 1 1 Normal Duty HP Amps 0.33 1.7 0.5 2.4 1 4.2 1.5 5.6 Heavy Duty HP Amps 0.33 1.7 0.5 2.4 1 4.2 1.5 5.6 230 VAC, Single & 3-Phase Input, 3-Phase Output, 50/60 Hz Input C200-01200017A C200-01200024A C200-01200033A C200-01200042A C200-02200024A C200-02200033A C200-02200042A C200-02200056A C200-02200075A C200-03200100A C200-04200133A C200-04200176A C200-05200250A C200-06200330A C200-06200440A C200-07200610A C200-07200750A C200-07200830A C200-08201160A C200-08201320A C200-09201760x** C200-09202190x** 1 1 1 1 1, 3 1, 3 1, 3 1, 3 1, 3 1, 3 1, 3 3 3 3 3 3 3 3 3 3 3 3 0.33 0.5 0.75 1 0.5 0.75 1 1.5 2 3 3 5 10 15 20 25 30 40 50 60 75 100 1.7 2.4 3.3 4.2 2.4 3.3 4.2 5.6 7.5 10 13.3 17.6 30 50 58 75 94 117 149 180 216 266 0.33 0.5 0.75 1 0.5 0.75 1 1.5 2 3 3 5 7.5 10 15 20 25 30 40 50 60 75 1.7 2.4 3.3 4.2 2.4 3.3 4.2 5.6 7.5 10 13.3 17.6 25 33 44 61 75 83 116 132 176 219 460 VAC, Three Phase Input, 3-Phase Output, 50/60 Hz Input C200-02400013A C200-02400018A C200-02400023A C200-02400032A C200-02400041A C200-03400056A C200-03400073A C200-03400094A C200-04400135A C200-04400170A C200-05400270A C200-05400300A C200-06400350A C200-06400420A C200-06400470A C200-07400660A C200-07400770A C200-07401000A C200-08401340A C200-08401570A C200-09402000x** C200-09402240x** 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 0.5 0.75 1 1.5 2 3 3 5 7.5 10 20 20 25 30 50 60 75 75 125 150 150 200 1.3 1.8 2.3 3.2 4.1 5.6 7.3 9.4 13.5 17 30 30 38 48 63 79 94 112 155 184 221 255 0.5 0.75 1 1.5 2 3 3 5 7.5 10 20 20 25 30 30 50 60 75 100 125 150 150 1.3 1.8 2.3 3.2 4.1 5.6 7.3 9.4 13.5 17 27 30 35 42 47 66 77 100 134 157 180 211 *Add 10101AB100 to the base order code when ordering standard US (60Hz) default products **x= A or E (9E frame requires an external AC Line Reactor) Order String - Frame Size Key Example: C200-XX_ _ _ _ _ _ _ XX = Frame Size (01-09 above) W Dimensions & Weights Frame Size 01 02 03 04 05 06 07 08 09E 09A Dimensions H x W x D (in) 6.3 x 3.0 x5.1 8.1 x 3.1 x 5.9 8.9 x 3.5 x 6.3 10.9 x 4.5 x 6.9 15.4 x 5.6 x 7.9 15.4 x 8.3 x 9.0 21.9 x 10.6 x 11.0 31.7 x 12.2 x 11.4 39.8 x 12.2 x 11.4 43.6 x 12.2 x 11.4 Weight (lbs) 1.7 2.2 3.3 6.9 16.3 30.9 61.7 114.6 101.4 146.6 H Additional distance should be added to the height dimension (H) when the AI options are fitted. D OPTIONS AT-A-GLANCE Option Description Order Code Configuration software CONNECT Drive to PC USB cable CT-USB-CABLE (requires a 485 adaptor) Parameter cloning 4 GB Drive Configuration AI-SMART-ADAPTOR (includes 4 GB SD card) & Programming Parameter cloning AI-BACKUP-ADAPTOR (requires an SD card) 8 GB SD card CTSD8GB Remote LCD display REMOTE-KEYPAD Remote LCD display Operator Interfaces REMOTE-KEYPAD-RTC with real-time clock Remote display cable UM-LCD-485-XXX**** Input / Output*** Extended I/O SI-I/O Modbus RTU AI-485-ADAPTOR Modbus RTU with 24 V AI-485-24V-ADAPTOR PROFIBUS DP SI-PROFIBUS DeviceNet SI-DEVICENET Communications*** CANopen SI-CANOPEN PROFINET RT SI-PROFINET-V2 EtherCAT SI-ETHERCAT EtherNet/IP, Modbus TCP SI-ETHERNET Application Programming PLC programming MACHINE-CONTROL-STUDIO Software & Diagnostics Digital oscilloscope CTSCOPE External EMC filter See the General Purpose Power Accessories Line & load reactors AC Drives brochure Dynamic braking resistors UL Type 1 conduit kits Environmental Protection Retrofit for See the General Purpose & Cable Management Commander SK AC Drives brochure Fan replacement kits ***frame sizes 2 and up accept 1 SI option ****Shielded RS485 patch cable, CAT5e, conductive metal RJ45 connectors, XXX=cable length in 5 foot increments (max 330 ft), standard lengths are (005, 010, 015, 025 and 050) Diagnostic Software Our Drive Diagnostics APP allows users to quickly diagnose faults. In the unlikely event that you get a drive error, download our complimentary Diagnostics Tool app. Just input the error code on your device and you’ll be given a solution. P/N SEL-C200 09/19 Download our Diagnostics Tool App at: www.ctdrives.com/diagnotics SOFTWARE INCLUDED 5-year warranty Terms & Conditions apply Call us at: +1 800 893-2321
C200-01200017
物料型号:Commander C200 AC Drives
器件简介:Commander C200 提供了机器安全、通信和内置PLC的增强功能,具有灵活的I/O扩展能力,并通过板载PLC编程提供低成本的系统解决方案。
引脚分配:具有2个模拟输入、4个数字输入、1个模拟输出、1个数字I/O和1个继电器的控制连接。
参数特性:包括RFC-A(转子磁通控制)算法,适用于要求苛刻的感应电机控制,以及无需位置反馈设备的闭环电流控制。
功能详解:适用于输送带、风扇、泵和混合器等应用,这些设备的功能可以通过现场总线或以太网通信远程控制。
应用信息:Commander C200 通过可选的工业以太网和现场总线通信增强了系统的可用性和灵活性,以及远程诊断。
封装信息:提供了多种框架尺寸和电压等级的驱动器,以及多种订单代码,以适应不同的应用需求。
C200-01200017 价格&库存
很抱歉,暂时无法提供与“C200-01200017”相匹配的价格&库存,您可以联系我们找货
