EVL155C-10-K6-38JA32
    NIDEC(尼得科)
    CONTROL TECHNIQUES - EVL155C-10-K6-38JA32 - Gearbox, R/A Planetary, 10:1, Stainless Steel, 3000 rpm,...
EVL155C-10-K6-38JA32 数据手册
1/1 Page Execution date : 2020-01-30 Administration number : 44715541290 Drawing number : EL15B2A5033 To English Able reducer Specification sheet Reducer model EVL-155B-10-K6-38JA32 (Shaft with key) 1.Reducer specification Ratio Backlash Allowable nominal torque Allowable maximum torque Allowable average input speed Allowable maximum input speed Allowable radial load (Applied to the output shaft center.) Allowable axial load (Applied to the output side bearing.) Approx. weight Moment of inertia Lubrication type Color of the paint Powered by TCPDF (www.tcpdf.org) 10 6 arc-min 200 Nm 400 Nm 2000 rpm 4000 rpm 4700 N 4100 N 19.8 kg 19.03 kg·cm2 Grease Silver *The actual appearance might be different.
EVL155C-10-K6-38JA32 价格&库存
很抱歉,暂时无法提供与“EVL155C-10-K6-38JA32”相匹配的价格&库存,您可以联系我们找货
