ASE1E-2M-10-Z
ASE1E-2M-10-Z
    NIDEC(尼得科)
    插件,9.5x5mm
    滑动开关 插件,9.5x5mm 单刀双掷 直插
ASE1E-2M-10-Z 数据手册
ASE Washable RoHS Compliant Hyper-miniature Slide Switches UL ■Features 1. High Contact Reliability Twin-contact clip mechanism for high contact reliability 2. Immersion washable type 3. Gold-plated contacts suitable for low current applications 4. For PC board mounting 5. Improved operability The independent detent structure provides a light operating touch. 6. UL-recognized ■ Specifications Voltagr range 20mV∼60V Current range 1μA∼50mA 50mA 60VAC/DC Rating Max. Min. 1μA 20mVAC/DC UL 48VAC/DC 50mA Initial contact resistance 50mΩ max. (1.5mA 200μVAC) Dielectric strength 250VAC 1 minute Initial insulation resistance 500MΩ min. (500VDC) 10,000 cycles at max. rating. Electrical life 50,000 cycles at min. rating or 0.4VA Operating force 0.69∼4.9N Operating temperature range −20℃∼+85℃ Storage temperature range −40℃∼+85℃ 0.4VA AC/DC ■Part Numbering A  SE  2  D - 2  M - 10 - Z Series code Code Type SE Slide type Fig. Numberof poles 1 1 pole 2 2 poles Code Switching function Fig. Terminal styles D N ON ー ON E – ONーOFF ーON 2 PC terminal 5 Right angle(0.2inch pitch) 6 Right angle(0.3inch pitch) Code Actuator shape M Standard (Compact type) Terminal line for double poles are 2.54mm (0.1") Distance between two terminal rows : 5.08mm(0.2") ■ Actuator Shape ■Right Angle Terminals 0.2−inch pitch Standard (M) 0.2R/A 1−pole 2−pole :Optional Accessories. 0.3−inch pitch 0.3R/A Clip mechanism ASE SPDT Switching function PC Viewed from part No. marking side Part No.  ASE1D-2M-10-Z ☆ASE1E-2M-10-Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 Terminal numbers are not shown on the switch. DPDT Distance between two terminal rows : 2.54 mm Switching function PC Viewed from part No. marking side Part No.  ASE2D-2M-10-Z ★ASE2E-2M-10-Z Connecting terminals ON ON 2−1 5−4 − OFF − ON ON 2−3 5−6 Terminal numbers are not shown on the switch. DPDT PC Distance between two terminal rows : 5.08 mm Switching function Viewed from part No. marking side Part No. ☆ASE2N-2M-10-Z Connecting terminals ON 2−1 5−4 − − ON 2−3 5−6 Terminal numbers are not shown on the switch. SPDT Mounting height : 3.1 mm Switching function 0.2R/A Viewed from part No. marking side Part No.  ASE1D-5M-10-Z ON − ON Connecting terminals 2−1 − 2−3 Terminal numbers are not shown on the switch. DPDT Mounting height : 3.1 mm Switching function 0.2R/A Viewed from part No. marking side Part No.  ASE2D-5M-10-Z Connecting terminals ON 2−1 5−4 − − Terminal numbers are not shown on the switch. ★:Made to order products. ●The actuator is sealed with a white-colored packing. Remove the packing with tweezers after the washing process. 495 ON 2−3 5−6 ASE SPDT Mounting height : 3.1 mm Switching function 0.3R/A Viewed from part No. marking side Part No.  ASE1D-6M-10-Z ON − ON Connecting terminals 2−1 − 2−3 Terminal numbers are not shown on the switch. DPDT Mounting height : 3.1 mm Switching function 0.3R/A Viewed from part No. marking side Part No. ☆ASE2D-6M-10-Z Connecting terminals − ON 2−1 5−4 − ON 2−3 5−6 Terminal numbers are not shown on the switch. DPDT Mounting height : 5.15 mm Switching function 0.3R/A Viewed from part No. marking side Part No. ★ASE2N-6M-10-Z Connecting terminals − ON 2−1 5−4 − ON 2−3 5−6 Terminal numbers are not shown on the switch. ■ Mounting Height Switching function ■Optional Accessories 《Supplied separately》 D・E N Part Name Part No. Bracket 140000640324 3.4 Mounting Dimensions ■PC Hole Layouts Series P/C terminal Whithout bracket Right Angle terminal Whit bracket 0.2inch pitch 0.3inch pitch ASE1D ASE1E ASE2D ASE2E ASE2N ★:Made to order products. ☆:Semi-standard products. AS & ASE ■ Bracket Installation Procedure ■Handling Precautions (AS and ASE Series) 1.Soldering Specifications ⑴Manual Soldering Device : Soldering iron 380℃, Max.; 3 seconds, Max. ⑵Auto Soldering Device : Jet wave type or dip type 275℃, Max.; 6 seconds, Max. ・Pre-heating should be done at temperatures ranging from 80℃ to 120℃ and within 120 sec. 2. Flux Cleaning ⑴Solvent : Fluorine or Alcohol type. ⑵Cleaning after soldering should be done after the terminal temperature falls to 90℃ or below, or after leaving the switch for five minutes or longer at room temperature. AS series are not process sealed and are not washable. If the PC board is to be cleaned, clean the soldering surface of substrate with a brush so that the switch is not exposed to the cleaning solution. ⑶Do not use ultrasonic cleaning system. [℃] 3. Mounting of Switch 275 120 80 S 6 120 Pre-heating Soldering ■Packaging Specifications Plastick Pack PC terminals :100 pcs./pack KU 15 SO SO JI 231 JI FU FU KU 196 Right-angle terminals : 50 pcs./pack ⑴Use the PC boards of φ1 holes. ⑵Do not bend the terminals before mounting the switch on the PC board. ⑶After mounting the switch, do not place the device in such a way that the device weight will be applied on the knob, etc. of the switch. ⑷Do not apply load exceeding 12.7 N (1.3 kgf) to the knob. Use a bracket (optional accessory) if the load is expected to exceed 12.7 N (1.3 kgf). The strength of the knob will be reinforced to 29.4 N (3 kgf) max.. Certifications ■Handling Precautions 1.Soldering Specifications ⑴Manual Soldering Device : Soldering iron 350℃, Max.; 3 seconds, Max. 2.Flux Cleaning ⑴Solvent : Fluorine or Alcohol type. ⑵are not process sealed. If the PC board is to be cleaned, clean the soldering surface of the substrate with a brush so that the switch is not exposed to the cleaning solution. ■UL Recognized / CSA Certified Classification Part No. page Part No. page ASE1D−2M−10−Z ● 494 ASE1D−5M−10−Z ● 494 ASE1E−2M−10−Z ● 494 ASE2D−5M−10−Z ● 494 ASE2D−2M−10−Z ● 494 ASE1D−6M−10−Z ● 494 ASE2E−2M−10−Z ● 494 ASE2D−6M−10−Z ● 494 ASE2N−2M−10−Z ● 494 ASE2N−6M−10−Z ● 494 8SS1011−Z ● 501 Slide switches 8SS1012−Z ● 501 8SS1021−Z ● 501 8SS1022−Z ● 501 8SS2011−Z ● 501 8SS2012−Z ● 501 8SS2021−Z ● 501 8SS2022−Z ● 501 ●UL-recognized or CSA-certified products. ●:UL File No. E43275 CSA File No.LR38341 Note: Please refer to P.575 for more details on UL-recognized / CSA-certified products. Additional cost will be required. ■Table of Part Numbers Series ES (15A) ES (25A) Switching function OFF −  ON ON  −  ON ON−OFF−ON OFF −  ON ON  −  ON TAB terminals 1−pole ★ ES115A−Z ★ ES115D−Z ★ ES115E−Z − − 2−poles −   ES215N−Z ★ ES215P−Z − − ☆:Semi-standard products. ★:Made to order products. Screw terminls Solder terminals 1−pole − − − ★ ES125A10−Z − 1−pole 2−poles ★ ES115A12−Z − ★ ES115D12−Z − − − ★ ES125A12−Z − ★ ES125D12−Z ★ ES225N12−Z   ■Shorting (Make-Before-Break) A switch which momentarily connects both circuits when the actuator is moved from Point A to B in the below figure. All switches which are not marked as Shorting are Non-shorting (Break-Before-Make). Shorting Non-shorting 〔Fig.1.〕
ASE1E-2M-10-Z 价格&库存
很抱歉,暂时无法提供与“ASE1E-2M-10-Z”相匹配的价格&库存,您可以联系我们找货
ASE1E-2M-10-Z
    • 1+15.21720
    • 10+12.99240
    • 30+11.59920
    • 100+10.17360
    • 500+9.52560
    • 1000+9.25560
    ASE1E-2M-10-Z
    • 1+20.42154
    • 5+19.54678
    • 10+18.92195
    库存:4
