Commander C300 AC Drives
Enhance throughput with machine safety, communications, and built-in PLC
Commander C300 provides flexible integration with safety and communications.
Commander C300 is ideal for applications that require cost-effective integration into
safety systems. With two Safe Torque Off (STO) inputs, onboard PLC and an SI interface
for industry standard fieldbuses, Ethernet or extended I/O options, this feature set
ensures Commander C300’s flexible integration with any system.
Enhance up-time and system flexibility
• Flexible system integration and remote diagnostics through optional industrial
Ethernet and fieldbus communication
• Flexible I/O that is expandable with SI-I/O option module
• Enhanced functionality and onboard PLC programming provides a low-cost system
solution, minimizing the need for additional equipment such as PLCs
High performance open loop motor control
• RFC-A (Rotor Flux Control) algorithm for exceptional induction motor control
of demanding applications
• Closed loop current control without a position feedback device
• Speed control for conveyors, fans, pumps, and mixers, where their function
is controlled remotely with fieldbus or Ethernet communications
Key data
Heavy Duty Ratings:
Normal Duty Ratings:
Supply phases:
Commander C300 Frame Size 3
Voltage ratings
100 / 120 VAC ± 10%
ü
200 / 240 VAC ± 10%
ü
380 / 480 VAC ± 10%
ü
How to select a drive (Consult online catalog for complete drive information)
Control mode
Open loop vector or V/Hz induction
motor control
Open loop Rotor Flux Control for
induction motors (RFC-A)
0.33 HP to 150 HP (0.25 kW to 110 kW)
0.33 HP to 200 HP (0.25 kW to 132 kW)
Frame size 1 and 2: 110 V drives 1Ø,
230 V drives 1Ø or 3Ø; Frame size 7 and larger 3Ø;
460 V drives 3Ø
Control connections:
3x Analog I/O, 5x Digital I/O, 2x STO, 1x Relay
Drive rating:
IP21 / UL open class as standard
Keypad:
Fixed LED
Option slots:
1 (frame size 2 and above)
Parameter cloning via: PC tools, SD card
ü
ü
1. Electrical Considerations
• What is the supply voltage?
• Single or 3Ø input power?
• What is the motor rating?
• Continuous current – FLA (Full Load Amps)
• Select the drive based on motor Amps rather than horsepower
2. Load Type (choose one)
• Normal Duty: Peak current is 110% of drive rating (fans, pumps, etc.)
• Heavy Duty: Peak current is 180% (mixers, conveyors, etc.)
3. Drive Mechanical Mounting
900
SO 1
SIL3
I
V
Safety Integrity Level
O
9002
E171230
L
P RO
IS
AP
AL
Visit www.Drive-Setup.com
for step by step guides, videos,
software, product support
documentation & 5 year
warranty registration.
• Panel mounting – as standard
• Wall mounting – UL conduit kits are available
• Through panel mounting – frames 5 and up
COMMANDER C300
AC Drives for Industrial Applications
Order Information & Ratings
115 VAC, Single Phase 50/60 Hz Input, 230 VAC 3-Phase Output
Commander C300
Order Code*
Input
Phase
C300-01100017A
C300-01100024A
C300-02100042A
C300-02100056A
1
1
1
1
Normal Duty
HP
Amps
0.33
1.7
0.5
2.4
1
4.2
1.5
5.6
Heavy Duty
HP
Amps
0.33
1.7
0.5
2.4
1
4.2
1.5
5.6
230 VAC, Single & 3-Phase Input, 3-Phase Output, 50/60 Hz Input
C300-01200017A
C300-01200024A
C300-01200033A
C300-01200042A
C300-02200024A
C300-02200033A
C300-02200042A
C300-02200056A
C300-02200075A
C300-03200100A
C300-04200133A
C300-04200176A
C300-05200250A
C300-06200330A
C300-06200440A
C300-07200610A
C300-07200750A
C300-07200830A
C300-08201160A
C300-08201320A
C300-09201760x**
C300-09202190x**
1
1
1
1
1, 3
1, 3
1, 3
1, 3
1, 3
1, 3
1, 3
3
3
3
3
3
3
3
3
3
3
3
0.33
0.5
0.75
1
0.5
0.75
1
1.5
2
3
3
5
10
15
30
40
50
60
75
100
1.7
2.4
3.3
4.2
2.4
3.3
4.2
5.6
7.5
10
13.3
17.6
30
50
58
75
94
117
149
180
216
266
0.33
0.5
0.75
1
0.5
0.75
1
1.5
2
3
3
5
7.5
10
15
30
40
50
60
75
1.7
2.4
3.3
4.2
2.4
3.3
4.2
5.6
7.5
10
13.3
17.6
25
33
44
61
75
83
116
132
176
219
460 VAC, Three Phase Input, 3-Phase Output, 50/60 Hz Input
C300-02400013A
C300-02400018A
C300-02400023A
C300-02400032A
C300-02400041A
C300-03400056A
C300-03400073A
C300-03400094A
C300-04400135A
C300-04400170A
C300-05400270A
C300-05400300A
C300-06400350A
C300-06400420A
C300-06400470A
C300-07400660A
C300-07400770A
C300-07401000A
C300-08401340A
C300-08401570A
C300-09402000x**
C300-09402240x**
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
0.5
0.75
1
1.5
2
3
3
5
7.5
10
30
50
60
75
75
125
150
150
200
1.3
1.8
2.3
3.2
4.1
5.6
7.3
9.4
13.5
17
30
30
38
48
63
79
94
112
155
184
221
255
0.5
0.75
1
1.5
2
3
3
5
7.5
10
30
30
50
60
75
100
125
150
150
1.3
1.8
2.3
3.2
4.1
5.6
7.3
9.4
13.5
17
27
30
35
42
47
66
77
100
134
157
180
211
*Add 10101AB100 to the base order code when ordering standard US (60Hz) default products
**x= A or E (9E frame requires an external AC Line Reactor)
Order String - Frame Size Key
Example: C300-XX_ _ _ _ _ _ _
XX = Frame Size (01-09 above)
W
Dimensions & Weights
Frame Size
01
02
03
04
05
06
07
08
09E
09A
Dimensions
H x W x D (in)
6.3 x 3.0 x5.1
8.1 x 3.1 x 5.9
8.9 x 3.5 x 6.3
10.9 x 4.5 x 6.9
15.4 x 5.6 x 7.9
15.4 x 8.3 x 9.0
21.9 x 10.6 x 11.0
31.7 x 12.2 x 11.4
39.8 x 12.2 x 11.4
43.6 x 12.2 x 11.4
Weight
(lbs)
1.7
2.2
3.3
6.9
16.3
30.9
61.7
114.6
101.4
146.6
H
D
Additional distance should be added to the height
dimension (H) when the AI options are fitted.
OPTIONS AT-A-GLANCE
Option
Drive Configuration
& Programming
Operator Interfaces
Input / Output***
Communications***
Application Programming
Software & Diagnostics
Power Accessories
Environmental Protection
& Cable Management
Description
Order Code
Configuration software
Drive to PC USB cable
(requires a 485 adaptor)
Parameter cloning 4 GB
(includes 4 GB SD card)
Parameter cloning
(requires an SD card)
8 GB SD card
Remote LCD display
Remote LCD display
with real-time clock
Remote display cable
Extended I/O
Modbus RTU
Modbus RTU with 24 V
PROFIBUS DP
DeviceNet
CANopen
PROFINET RT
EtherCAT
EtherNet/IP, Modbus TCP
PLC programming
Digital oscilloscope
External EMC filter
Line & load reactors
Dynamic braking resistors
UL Type 1 conduit kits
Retrofit for
Commander SK
Fan replacement kits
CONNECT
CT-USB-CABLE
AI-SMART-ADAPTOR
AI-BACKUP-ADAPTOR
CTSD8GB
REMOTE-KEYPAD
REMOTE-KEYPAD-RTC
UM-LCD-485-XXX****
SI-I/O
AI-485-ADAPTOR
AI-485-24V-ADAPTOR
SI-PROFIBUS
SI-DEVICENET
SI-CANOPEN
SI-PROFINET-V2
SI-ETHERCAT
SI-ETHERNET
MACHINE-CONTROL-STUDIO
CTSCOPE
See the General Purpose
AC Drives brochure
AC Drives brochure
***frame sizes 2 and up accept 1 SI option
****Shielded RS485 patch cable, CAT5e, conductive metal RJ45 connectors, XXX=cable length in
5 foot increments (max 330 ft), standard lengths are (005, 010, 015, 025 and 050)
Diagnostic Software
Our Drive Diagnostics APP allows
users to quickly diagnose faults. In
the unlikely event that you get a drive
error, download our complimentary
Diagnostics Tool app. Just input the
error code on your device and you’ll
be given a solution.
P/N SEL-C300 09/19
Download our Diagnostics Tool App at:
www.ctdrives.com/diagnotics
SOFTWARE
INCLUDED
5-year warranty
Terms & Conditions apply
Call us at: +1 800 893-2321
