CMS-2202TA
CMS-2202TA
    NIDEC(尼得科)
    SMD
    滑动开关 SMD
CMS-2202TA 数据手册
SLIDE SWITCHES (SMD) RoHS compliant CMS INTERNAL STRUCTURE ① ② ⑦ ③ ⑥ ④ ⑧ ⑤ Part name ■ FEATURES ① Cover ● RoHS compliant ● Excellent contact stability by twin Gold-plated contact mechanism ● Load life of 30,000 cycles ● Compatible with automatic mounting ● Withstands high soldering temperature ② Slider ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin ⑦ Click spring ⑧ Ground terminal Material Flammability Steel (SPCC), Tin-plated — Polyamide UL94V-0 Copper alloy, Gold-plated — Copper alloy Steel (SPCC), Tin-plated ■ PART NUMBER DESIGNATION CMS - 2 2 0 2 T B Series name Shape of terminal No. of poles A:J-hook B:Gull wing C:Through hole pins 2:2 poles 4:4 poles No. of contacts 2:2 contacts 3:3 contacts 4:4 contacts Form of packaging T:Taping (Reel) W:Tray packaging (Through hole pins only) Blank:Bulk in plastic bag Setting position Knob length 0:Top setting 1:Side setting 2:2 mm 4:4 mm(2 poles · Side setting only) 6:6 mm(4 poles · Side setting only) ※ Please refer to the LIST OF PART NUMBERS when placing orders. CMS SLIDE SWITCHES (SMD) ■ LIST OF PART NUMBERS ● 2 poles Setting position Shape of terminals Knob length A(J-hook) Top setting B(Gull wing) 2 mm C(Through hole pins) 2 mm A(J-hook) 4 mm 2 mm Side setting B(Gull wing) 4 mm ( ) 2 mm C          Through hole pins 4 mm Form of packaging No. of contacts 2 3 Shape of terminals Knob length A(J-hook) Top setting B(Gull wing) 2 mm C(Through hole pins) A(J-hook) Side setting B(Gull wing) C(Through hole pins) 6 mm Pieces in package Taping CMS-2202TA CMS-2302TA CMS-2402TA 900 pcs./reel Plastic bag CMS-2202A CMS-2302A CMS-2402A 50 pcs./pack Taping CMS-2202TB CMS-2302TB CMS-2402TB 900 pcs./reel Plastic bag CMS-2202B CMS-2302B CMS-2402B 50 pcs./pack Tray packaging CMS-2202WC CMS-2302WC CMS-2402WC 50 pcs./tray Plastic bag CMS-2202C CMS-2302C CMS-2402C 50 pcs./pack Taping CMS-2212TA CMS-2312TA CMS-2412TA 900 pcs./reel Plastic bag CMS-2212A CMS-2312A CMS-2412A 50 pcs./pack Taping CMS-2214TA CMS-2314TA CMS-2414TA 900 pcs./reel Plastic bag CMS-2214A CMS-2314A CMS-2414A 50 pcs./pack Taping CMS-2212TB CMS-2312TB CMS-2412TB 900 pcs./reel Plastic bag CMS-2212B CMS-2312B CMS-2412B 50 pcs./pack Taping CMS-2214TB CMS-2314TB CMS-2414TB 900 pcs./reel Plastic bag CMS-2214B CMS-2314B CMS-2414B 50 pcs./pack Tray packaging CMS-2212WC CMS-2312WC CMS-2412WC 50 pcs./tray Plastic bag CMS-2212C CMS-2312C CMS-2412C 50 pcs./pack Tray packaging CMS-2214WC CMS-2314WC CMS-2414WC 50 pcs./tray Plastic bag CMS-2214C CMS-2314C CMS-2414C 50 pcs./pack ● 4 poles Setting position 4 Form of packaging No. of contacts 2 Pieces in package Taping CMS-4202TA 500 pcs./reel Plastic bag CMS-4202A 25 pcs./pack Taping CMS-4202TB 500 pcs./reel Plastic bag CMS-4202B 25 pcs./pack Tray packaging CMS-4202WC 50 pcs./tray Plastic bag CMS-4202C 25 pcs./pack Taping CMS-4216TA 500 pcs./reel Plastic bag CMS-4216A 25 pcs./pack Taping CMS-4216TB 500 pcs./reel Plastic bag CMS-4216B 25 pcs./pack Tray packaging CMS-4216WC 50 pcs./tray Plastic bag CMS-4216C 25 pcs./pack ※ Verify the above part numbers when placing orders. Taping and tray version can be supplied only in reel or tray unit. CMS SLIDE SWITCHES (SMD) ■ STANDARD SPECIFICATIONS Operating temp. range Storage temp. range Sealing Net weight ■ ELECTRICAL CHARACTERISTICS Contact rating − 40 ~ 85 °C Non- Washable 0.42 g (CMS-2214) 0.48 g (CMS-2314) 0.54 g (CMS-2414) 0.80 g (CMS-4202) 0.84 g (CMS-4216) 0.40 g (CMS-2202) 0.45 g (CMS-2302) 0.50 g (CMS-2402) 0.42 g (CMS-2212) 0.48 g (CMS-2312) 0.54 g (CMS-2412) 2, 3, 4 Stroke 2 mm 1.5 ± 1 N {0.15 ± 0.1 kgf} Stop strength 30N{3.06 kgf} 15 s(Top setting) 10N{1.02 kgf} 15 s(Side setting) Soldering heat 245 ± 3 °C Non-shorting 70 m Ω maximum Insulation resistance 100 M Ω minimum (DC500 V) Dielectric strength AC500 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS Shock Load life 2~3s Humidity (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 10 cycles each 490 m/s2, 11 ms, sinusoidal wave half cycle, 6 directions for 3 times each Continuous load 30000 cycles, DC12 ± 0.5 V, 100 ± 10 mA 40 °C, Relative humidity 90 ~ 95 %, 240 h, No load Reflow:255 °C (Peak temperature) (Please refer to the profile below) High temp. exposure 85 °C, 96 h, No load Flow:260 ± 3 °C、5~ 6 s Low temp. exposure − 40 °C, 96 h, No load Manual soldering:350 ± 10 °C, 3 ~ 4 s Shear (Adhesion) 50 N {5.09 kgf} 10 s Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength Contact timing Vibration Operating force Solderability DC50 V 100 mA DC12 V 100 mA DC20 mV 1 μ A Contact resistance ■ MECHANICAL CHARACTERISTICS No. of positions Non-switching Switching Minimum Thermal shock 50 N {5.09 kgf} 10 s { } : Reference only 〈Reflow profile for soldering heat evaluation〉 Temperature (℃) 250 200 150 100 50 Peak : 250 +5 0 ℃ Over 230 ℃ 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Reflow : two times maximum Soldering Zone − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CMS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS ● CMS-2202A Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) C ⑤ ⑥ ④ 13 10.8 ● CMS-2202B 13 10.8 ① ② ③ C Schematic ① C ⑤ ⑥ ④ 0.2 0.3 0 0.2 0.6 0.6 10.8 0.6 3 1 2 4.3 ● CMS-2212A 4.2 2 ● CMS-2202C φ 0.6 0. 2 0. 1 3 φ 0.9 8 5 2 C C 0.6 3 1 2 4.3 4.2 φ 0.6 Travel 2 2 0.3 5.5 3.5 2 0 0.1–0.1 2 Terminal No.1 +0.3 0 0.1 –0.1 5.4 5 2 5.5 3.5 2 Travel 2 ② ③ C Schematic Production date code Production date code Terminal No.1 φ 0.9 0.6 min. 1 13 10.8 ② ③ C Schematic ① 5 2 Travel 2 0.3 0.6 3 1 2 4.3 4.2 ● CMS-2212C 13 10.8 φ 0.9 10.8 C ⑤ ⑥ ④ C ⑤ ⑥ ④ +0.3 0 1 3 2 ● CMS-2212B φ 0.6 0. 3 1 2 2.2 0.6 2.5 3.5 0 0.1–0.1 5.5 3.5 2 3 0.2 1 5.2 C 0.3 5.4 5 2 0.2 2 2 0.6 ② ③ C Schematic Production date code Terminal No.1 Travel 2 C ⑤ ⑥ 1.6 1.5 Terminal No.1 0.6 min. ④ ① Production date code C ⑤ ⑥ ④ ① ② ③ C Schematic 0.1 0.3 0.6 min. ● CMS-2214B 13 10.8 C ⑤ ⑥ ④ 5 0.2 1 5.2 0.6 1 2 2.2 3 13 10.8 C ⑤ ⑥ ④ ① ① ② ③ C Schematic Production date code ② ③ C Schematic Terminal No.1 φ 0.6 4.3 4.2 φ 0.9 8 5 0.6 min. 0.2 1.6 1.5 0.3 0.6 3 1 2 2 1 3 4 3.5 0 0.1 –0.1 0.2 0.1 2 2 0. 2 0. φ 0.9 Travel +0.3 0 C C 0.6 3 1 2 4.3 4.2 5.4 5 1.6 1.5 4 0.3 0 –0.1 2 2 0.6 Travel 3.5 3.5 0.2 1 Terminal No.1 0.6 2 3 φ 0.9 0.6 min. Production date code φ 0.6 2 2 1.6 1.5 0 –0.1 3.5 0.3 2 0.6 3 1 2 4.3 4.2 ● CMS-2214A 8 5 2 0. 0.6 Travel 2 C φ 0.6 Terminal No.1 Travel 2 ② ③ C Schematic 2.5 1.6 1.5 Terminal No.1 Production date code ① Production date code 1 0.6 min. CMS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS ● CMS-2214C 10.8 ④ Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CMS-2302A C ⑤ ⑥ 15 12.8 ① ② ③ C Schematic Production date code ① ② Terminal No.1 Travel 2 15 12.8 C ⑦ ⑧ ⑤ ⑥ ● CMS-2302C 1 3 2 ● CMS-2302B 2 5.2 0. 0.6 0.6 2 4 5.3 φ 0.6 C 3 1 2 2.2 φ 0.9 12.8 ① ② ③ ④ C Schematic Production date code Terminal No.1 2 2 2 2 5 2 0.3 3 2 5.2 2 ● CMS-2312A 0. 2 4 5.3 C 0.6 0.6 φ 0.6 0.2 0.3 5.5 3.5 2 0 0.1 –0.1 2 Travel 2 8 5 2 φ 0.9 0.6 min. 1 0.6 min. ● CMS-2312B C ⑦ ⑧ ⑤ ⑥ 0.2 1 5.2 0.6 2 15 12.8 2.5 Travel 4 2 2.2 15 12.8 ⑤ ⑥ ① ② ③ ④ C Schematic Production date code ③ ④ C Schematic 5.5 3.5 2 Terminal No.1 C ⑦ ⑧ ⑤ ⑥ ① ② Production date code +0.3 0 0.3 0 0.2 1 5.2 2 0.1 –0.1 5.5 3.5 2 3.5 3 0.3 0.6 5 2.5 1.6 1.5 4 5.4 5 2 2 0.2 Travel 2 ③ ④ C Schematic Production date code Terminal No.1 2 C ⑦ ⑧ ⑤ ⑥ C ⑦ ⑧ ① ② ③ ④ C Schematic Production date code Terminal No.1 Terminal No.1 0.6 ⑤ ⑥ C ⑦ ⑧ ● CMS-2314A 2 4 5.3 0.6 2 5.2 2 4 5.3 2 5.2 φ 0.9 +0.3 0 0.2 0.3 0.6 φ 0.6 5.4 5 1.6 1.5 4 3.5 0 0.1 –0.1 0.2 1 5.2 0.6 3 2 2.2 2 2 2 0. 4 2 C 0.3 2 C ⑦ ⑧ ⑤ ⑥ ① ② ③ ④ C Production date code Schematic 5 2.5 1.6 1.5 2 0.6 0.6 min. Travel 2 3.5 2 1 Terminal No.1 Travel 2 0.2 15 12.8 ③ ④ C Schematic Terminal No.1 0.6 min. φ 0.9 ① ② Production date code 8 5 1.6 1.5 0.3 0.2 12.8 φ 0.6 2 0. φ 0.9 2 C 1 3 2 ● CMS-2312C 2 5.2 0. 2 4 5.3 Travel 2 2 2 +0.3 0 1.6 1.5 0.3 2 0.6 φ 0.6 5.4 5 C 0.6 2 2 3.5 0 0.1–0.1 2 3.5 0 0.1 –0.1 Travel 1 3 CMS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS 15 12.8 C ⑦ ⑧ ⑤ ⑥ ● CMS-2314C 12.8 ③ ④ C Schematic ① ② Production date code Terminal No.1 Production date code φ 0.9 2 4 3.5 2 0.3 3 0.2 1.6 1.5 0.3 3.5 0 0.1–0.1 0.6 0.6 min. 2 2 5.2 2 8 5 4 0. ● CMS-2402A 1 17 14.8 0.6 0.6 min. C ⑧ ⑨ ⑩ ⑥ ⑦ 2 0.2 1 5.2 2 2.2 4 ● CMS-2402B 5 17 14.8 ① ② ③ ④ ⑤ C Schematic 2 0.3 0 2 6.3 0.6 3 1 2 2 6.2 ● CMS-2412A φ 0.9 Travel ③ ④ ⑤ C Schematic Terminal No.1 5 2 Travel 0.2 3 ● CMS-2412B 1 2 2 2.2 17 14.8 0.3 φ 0.6 ⑥ ⑦ C ⑧ ⑨ ⑩ 2 6.3 ● CMS-2412C 0.6 3 1 2 2 6.2 φ 0.9 14.8 ⑥ ⑦ C ⑧ ⑨ ⑩ ① ② ① ② ③ ④ ⑤ C Schematic Production date code +0.3 0 1 3 2 0. 2 C 1 5.2 5.4 5 2 0 3.5 2.5 3 0.3 0.6 2 0.1–0.1 2 2 2 0.2 2 Production date code 1.6 1.5 2 C ⑧ ⑨ ⑩ ① ② 0.6 2 5.5 3.5 2 2 0.6 min. ⑥ ⑦ ① ② ③ ④ ⑤ Production date code C Schematic Terminal No.1 1 17 14.8 C ⑧ ⑨ ⑩ ⑥ ⑦ 0.6 min. 2 φ 0.6 14.8 8 5 2 2 0.2 2 0.1–0.1 2 0. ● CMS-2402C 1 3 φ 0.9 Travel Terminal No.1 C 0.6 3 1 2 2 6.3 6.2 2 2 0. φ 0.6 ③ ④ ⑤ C Schematic Production date code 0.6 0 0.3 0.1 –0.1 2 +0.3 0 0.2 2 2 C 0.6 5.5 3.5 2 2 5.4 5 2 5.5 3.5 2 Travel C ⑧ ⑨ ⑩ ⑥ ⑦ ① ② Production date code Terminal No.1 ③ ④ C Schematic Travel C 2 4 5.3 φ 0.6 ① ② Terminal No.1 Travel 2 2 2 0.6 C ⑦ ⑧ ⑤ ⑥ 2.5 1.6 1.5 ● CMS-2314B Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ③ ④ ⑤ C Schematic Production date code Terminal No.1 φ 0.9 2 2 0.3 3 0.2 0.3 2 0.6 3 1 2 2 6.3 6.2 0. 2 C 0.6 2 2 2 2 8 5 3.5 2 1.6 1.5 2 2 3.5 0 0.1 –0.1 2 φ 0.6 Travel Travel 0.6 min. 1 0.6 min. 0.6 2 3 1 2 2 2.2 5 2.5 1.6 1.5 Terminal No.1 0.2 1 5.2 CMS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS ● CMS-2414A 17 14.8 Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) C ⑧ ⑨ ⑩ ⑥ ⑦ ① ② ● CMS-2414B 17 14.8 ③ ④ ⑤ C Schematic Production date code C ⑧ ⑨ ⑩ ⑥ ⑦ ① ② ③ ④ ⑤ C Schematic Production date code Terminal No.1 Terminal No.1 0.6 ● CMS-2414C 14.8 C ⑧ ⑨ ⑩ ⑥ ⑦ 2 0.6 3 1 2 2 6.3 6.2 2 φ 0.6 φ 0.9 0.6 min. C ⑦⑧⑨ Production date code Travel C ⑩⑪⑫ ①②③ ④⑤⑥ C C Schematic 0.2 1 5.2 2 3 1 2 2 2.2 ● CMS-4202B 0.6 5.4 5 2 φ 0.6 0.6 6.1 2 2 φ 0.9 6 6 Production date code C ⑩⑪⑫ ①②③ ④⑤⑥ C C Schematic Terminal No.1 0.6 min. 1 2 2.5 6.7 4.7 2 5 2 3 0.2 0.3 6.7 4.7 2 0 0.1–0.1 6 C ⑩⑪⑫ ④⑤⑥ Production date code ① ② ③ C C Schematic 2 C φ 0.9 6 C ⑦⑧⑨ 17.8 8 5 2 2 0.6 2 Travel Travel 6.1 2 2 0. 2 2 Terminal No.1 2 C 1 3 ● CMS-4202C C ⑦⑧⑨ 20 17.8 +0.3 0 0.3 2.5 1.6 1.5 3 0.3 5 6.7 4.7 2 0 0.1–0.1 4 2 2 0.2 2 3.5 2 2 0.6 0. 2 0.6 0.6 min. ● CMS-4216A 0.2 0.3 2 2 2 2 6 1 5.2 2 2 ● CMS-4216B 20 17.8 C ⑦⑧⑨ 20 17.8 C ⑩⑪⑫ C ⑦⑧⑨ ④⑤⑥ Production date code ① ② 3 C C Schematic Terminal No.1 Production date code Terminal No.1 Travel Travel φ 0.9 6 6 2 2 1 3 C 0. 2 2 0.3 φ 0.6 C 0.6 6.1 2 2 φ 0.9 6 6 8 5 0.2 6 4.7 0 0.1–0.1 2 0.6 0.3 0.6 6.1 2 2 5.4 5 2.3 2 6 +0.3 0 0.2 2 4.7 0 0.1–0.1 2 C ⑩⑪⑫ ①②③ ④⑤⑥ C C Schematic 2.3 2 0.6 1 20 17.8 Travel 2 0.6 0.6 min. Terminal No.1 Terminal No.1 φ 0.6 8 5 ● CMS-4202A ① ② ③ ④ ⑤ C Production date code Schematic φ 0.6 4 0.2 0.3 0.2 0.3 0.6 2 φ 0.9 0. 1 3 0. 6.3 2 C 0.6 3 1 2 2 6.2 2 Travel 2 2 2 1.6 1.5 4 +0.3 0 C φ 0.6 5.4 5 3.5 0 0.1–0.1 2 3.5 0 0.1–0.1 2 2 1.6 1.5 Travel 2 2 2 0.6 min. 1 0. 2 0.6 min. CMS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CMS-4216C C ⑦⑧⑨ 17.8 Production date code Terminal No.1 C ⑩⑪⑫ ①②③ ④⑤⑥ C C Schematic Travel 6 5 0.6 2 2 6 0.3 2 2 2.5 3 2.3 4.7 2 2 2 1 5.2 0.2 ■ SIZE OF P.C.B. PROCESSING ● CMS-22□□C (Unit : mm) ● CMS-23□□C 1 2 2.2 2 5.2 0 φ 1.2 6 – φ 0.8 CMS housing ● CMS-24□□C 4 2 2.2 0 5.2 3 φ 1.2 8 – φ 0.8 CMS housing ● CMS-42□□C CMS housing 3 1 2 0 2 2.2 2 φ 1.2 10 –φ 0.8 2 6 0 5.2 5.2 2 CMS housing 2 2 1.7 φ 1.2 12 – φ 0.8 CMS-22□□B ランドパターン CMS SLIDE SWITCHES (SMD) CMS-23□□B ランドパターン ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● CMS-22□□A 2 ● CMS-22□□B 2 3 1 2 2 2 2 (Unit : mm) 2 3 1 2 2 2 1 2 1.5 1 2 6 2 0 2 2.6 0 φ 0.9 hole φ 1.2 hole 4.2 4.3 CMS-24□□B ランドパターン ● CMS-23□□B 2 2 4 2 2 4.2 φ 0.9 hole ● CMS-23□□A 2 φ 1.2 hole 1.5 4.3 2 2 2 2 2 4 2 2 1 2 1.5 1 2 6 2 0 2 2.6 0 φ 0.9 hole φ 1.2 hole 5.2 φ 1.2 hole 1.5 5.3 5.3 5.2 φ 0.9 hole ● CMS-24□□A 2 2 ● CMS-24□□B 2 3 1 2 2 2 2 2 2 2 3 1 2 2 2 2 1 2 1.5 1 2 6 2 0 2 2.6 0 φ 0.9 hole φ 1.2 hole 6.2 φ 1.2 hole 1.5 6.3 6.3 6.2 φ 0.9 hole ● CMS-42□□A 1.5 2 2 6 2 2 1.5 1 2 2 1.5 2 2 6 2 2 1.5 1 2 2 1.5 2 ● CMS-42□□B 2 6 2 0 6.1 6 φ 1.2 hole φ 0.9 hole Note) The zero point is the center of mounting. 1.5 2 2.6 0 6.1 φ 0.9 hole 6 φ 1.2 hole CMS SLIDE SWITCHES (SMD) ■ PACKAGING SPECIFICATIONS ● CMS-2 □□□□ type is packaged in 900 pcs. per reel. Orders will be accepted for units of 900 pcs., i.e., 900, 1800, 2700 pcs., etc. CMS-4 type is packaged packaged in 500 pcs. per reel. CMS in リール Orders will be accepted for units of 500 pcs. ● Taping version is boxed with one reel. Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806) (In accordance with EIAJ ET-7200A) 25.4±1 (CMS-2□□□□ type) 33.4±1 (CMS-4□□□□ type) Empty Filled Empty End φ 21±0.8 40 mm min. Direction of feed 2±0.5 φ 330±2 φ 80±1 Head 20 pitches min. Leader 400 mm min. φ 13±0.2 29.4±1 (CMS-2□□□□ type) 37.4±1 (CMS-4□□□□ type) ● CMS-2202TA, TB 12 ± 0.1 Terminal No.1 2 ± 0.1 0.4 ± 0.1 (CMS-2202B) Installation example (CMS-2202B) 24 4 ± 0.1 11.5 ± 0.1 0 φ 1.5 +0.1 1.75 ± 0.1 (Unit : mm) (Conforms to JIS C 0806) Direction of feed 7 CMS SLIDE SWITCHES (SMD) ● CMS-2302TA, TB ● CMS-2402TA, TB 2TA,TB 外形図 0.4 ± 0.1 φ 1.5 +0.1 0 (CMS-2302B) Installation example (CMS-2302B) 2 ± 0.1 Terminal No.1 0.4 ± 0.1 (CMS-2402B) Installation example (CMS-2402B) 24 24 11.5 ± 0.1 7 Direction of feed ● CMS-2212 • 2214TA, TB ● CMS-2312 • 2314TA, TB 4 ± 0.1 2 ± 0.1 0.4 ± 0.1 16 ± 0.1 (CMS-2214B) Installation example (CMS-2214B) φ 1.5 4 ± 0.1 +0.1 0 2 ± 0.1 Terminal No.1 24 ● CMS-4202TA, TB (CMS-2412B) Installation example (CMS-2412B) φ 1.5 +0.1 0 12 ± 0.1 4 ± 0.1 2 ± 0.1 0.2 ± 0.05 24 Direction of feed 5 0.5 ± 0.1 (CMS-4202B) Installation example (CMS-4202B) 14.2 ± 0.1 28.4 ± 0.1 32 Terminal No.1 11.5 ± 0.1 2 ± 0.1 0.4 ± 0.1 1.75 ± 0.1 16 ± 0.1 (Conforms to JIS C 0806) 1.75 ± 0.1 (Conforms to JIS C 0806) Terminal No.1 5 Direction of feed ● CMS-2412 • 2414TA, TB 4 ± 0.1 (CMS-2312B) Installation example (CMS-2312B) 5 Direction of feed φ 1.5 +0.1 0 0.4 ± 0.1 24 11.5 ± 0.1 Terminal No.1 (Conforms to JIS C 0806) 11.5 ± 0.1 16 ± 0.1 1.75 ± 0.1 (Conforms to JIS C 0806) 0 φ 1.5 +0.1 7 Direction of feed 1.75 ± 0.1 Terminal No.1 12 ± 0.1 4 ± 0.1 1.75 ± 0.1 2 ± 0.1 11.5 ± 0.1 12 ± 0.1 4 ± 0.1 1.75 ± 0.1 φ 1.5 +0.1 0 (Unit : mm) (Conforms to JIS C 0806) (Conforms to JIS C 0806) R 0.75 +0.05 0 Direction of feed 8.3 CMS SLIDE SWITCHES (SMD) ● CMS-4216TA, TB φ 1.5 +0.1 0 20 ± 0.1 4 ± 0.1 2 ± 0.1 0.2 ± 0.05 R 0.75 +0.05 0 0.5 ± 0.1 (CMS-4216B) Installation example (CMS-4216B) 14.2 ± 0.1 28.4 ± 0.1 32 Terminal No.1 1.75 ± 0.1 (Unit : mm) (Conforms to JIS C 0806) Direction of feed 6.3 ● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in plastic bag is performed with 50 pcs. (standard 100 pcs. / CMS-2 □□□□ , 50 pcs. / CMS-4 □□□□ ) per box.
CMS-2202TA 价格&库存
很抱歉,暂时无法提供与“CMS-2202TA”相匹配的价格&库存,您可以联系我们找货
